Gernash 19 Posted January 11, 2016 Posted January 11, 2016 (edited) @spietrza Mono v4.2.1.102-6 is current from synocommunity @mittedude I do not know that your Synology is. Enabling SSH would not slow your system. if you have a slow NAS and Mono and emby are running it will take some time to settle down. Web access is slow if it's using 100%cpu @Luke link working as intended Edited January 11, 2016 by Gernash
mittedude 0 Posted January 11, 2016 Posted January 11, 2016 @Gernash i have a DS411j not the fastet NAS, but the problem is...i have install everthing i need i think, Emby-beta, ffmpeg, imagemagick, mono-beta and these are up and running. But it can't connect to server/ip of my nas it says "The connection failed". Must be some settnings i have forget to check?
Gernash 19 Posted January 12, 2016 Posted January 12, 2016 You cannot connect to your Synology dashboard or the emby wizard at 1st start? If it's the wizard then you may have to uninstall emby then reinstall then run it and complete the 1st run wizard then update it.
Wopperr 2 Posted January 14, 2016 Posted January 14, 2016 How can i run Emby on my DS216play? monaco x16 SeriesDS216play - synology_monaco_216playI have to use the monaco version, is it available yet? Is it possible to use a different version? 2
SantiagoJoe 0 Posted January 31, 2016 Posted January 31, 2016 I have a DS413 with a FREESCALE QorIQ P1022 CPU and 1024MB of total Physical memory. When I followed the instructions under “Pre-Installation” and “Installation” in the original post I could not install “Mono” from the Package Centre as it did not appear there. The other packages “Mediainfo” and “ImageMagick” were listed and available for installation. A bit of research seemed to indicate to me that “mono” was not compatible with the Freescale Architecture. Does anyone know if Mono can be installed on my machine? Also, there did not seem to be any Installation instructions for the Freescale CPU – does this mean even after the Package moves from Beta, I will not be able to install on my machine? Many Thanks
KRULL 10 Posted February 6, 2016 Posted February 6, 2016 Updating 4. Copy the contents of the zip file into /volume1/@appstore/emby/share/emby (or wherever it has been installed, the contents of the zip should look like the contents of the folder you are copying into) I am having trouble doing this, I get an error with Terminal on OS X. I have downloaded and unzipped the update folder. Moved that folder to the folder I keep Emby Metadata in (/volume1/Media/Emby/Emby.Mono), and the run the following which should be correct, but no go. DiskStation> cd /volume1/Media/Emby DiskStation> cp Emby.Mono /volume1/@appstore/emby/share/emby cp: omitting directory 'Emby.Mono' DiskStation> Should I change the Emby.Mono folder name to something else, or am I doing something else wrong?
Luke 42243 Posted February 6, 2016 Author Posted February 6, 2016 You don't need to rename anything if that's what you're asking. You should just find the folder that has the same files and overwrite them. What is the issue you are having?
KRULL 10 Posted February 6, 2016 Posted February 6, 2016 I assumed the unzipped Emby.Mono folder was the same name and structure and thus you simply copied that over in its entirety. If I am not copy the entire update folder, exactly what am I supposed to copy, individual files multiple times? When I do this: ls -all /cp /volume1/@appstore/emby/share/emby It shows a list of files as per the unzipped folder, plus a few more folder too. So do I copy across all of the individual files one at a time? DiskStation> ls -all /cp /volume1/@appstore/emby/share/emby ls: /cp: No such file or directory /volume1/@appstore/emby/share/emby: drwxr-xr-x 5 emby root 4096 Sep 30 09:09 . drwxr-xr-x 3 emby root 4096 Sep 30 09:10 .. -rw-r--r-- 1 emby root 78336 Jan 12 2015 BDInfo.dll -rw-r--r-- 1 emby root 18432 Jan 12 2015 DvdLib.dll -rw-r--r-- 1 emby root 261632 Sep 21 19:26 Emby.Drawing.dll -rw-r--r-- 1 emby root 100864 Apr 28 2015 ImageMagickSharp.dll -rw-r--r-- 1 emby root 296 Sep 30 09:09 ImageMagickSharp.dll.config -rw-r--r-- 1 emby root 295 Mar 25 2015 ImageMagickSharp.dll.config.orig -rw-r--r-- 1 emby root 5120 Apr 15 2015 Interfaces.IO.dll -rw-r--r-- 1 emby root 780800 Sep 21 19:26 MediaBrowser.Api.dll -rw-r--r-- 1 emby root 134144 Sep 21 19:26 MediaBrowser.Common.Implementations.dll -rw-r--r-- 1 emby root 45056 Sep 21 19:26 MediaBrowser.Common.dll -rw-r--r-- 1 emby root 475648 Sep 21 19:26 MediaBrowser.Controller.dll -rw-r--r-- 1 emby root 621056 Sep 21 19:26 MediaBrowser.Dlna.dll -rw-r--r-- 1 emby root 11776 Jan 12 2015 MediaBrowser.IsoMounting.Linux.dll -rw-r--r-- 1 emby root 55808 Sep 21 19:26 MediaBrowser.LocalMetadata.dll -rw-r--r-- 1 emby root 141824 Sep 21 19:26 MediaBrowser.MediaEncoding.dll -rw-r--r-- 1 emby root 12800 Sep 21 19:26 MediaBrowser.MediaInfo.dll -rw-r--r-- 1 emby root 180 Jan 12 2015 MediaBrowser.MediaInfo.dll.config -rw-r--r-- 1 emby root 467456 Sep 21 19:26 MediaBrowser.Model.dll -rw-r--r-- 1 emby root 55808 May 27 2015 MediaBrowser.Naming.dll -rw-r--r-- 1 emby root 620032 Sep 21 19:26 MediaBrowser.Providers.dll -rw-r--r-- 1 emby root 1713664 Sep 21 19:26 MediaBrowser.Server.Implementations.dll -rw-r--r-- 1 emby root 19456 Sep 21 19:26 MediaBrowser.Server.Mono.exe -rw-r--r-- 1 emby root 890 Jan 12 2015 MediaBrowser.Server.Mono.exe.config -rw-r--r-- 1 emby root 90624 Sep 21 19:26 MediaBrowser.Server.Startup.Common.dll -rw-r--r-- 1 emby root 46592 Sep 21 19:26 MediaBrowser.WebDashboard.dll -rw-r--r-- 1 emby root 60416 Sep 21 19:26 MediaBrowser.XbmcMetadata.dll drwxr-xr-x 3 emby root 4096 Apr 15 2015 MediaInfo -rw-r--r-- 1 emby root 47104 May 8 2015 Mono.Nat.dll -rw-r--r-- 1 emby root 187392 Jan 12 2015 Mono.Posix.dll -rw-r--r-- 1 emby root 64000 Jan 12 2015 MoreLinq.dll -rw-r--r-- 1 emby root 420352 May 8 2015 NLog.dll -rw-r--r-- 1 emby root 101888 Sep 21 19:26 OpenSubtitlesHandler.dll -rw-r--r-- 1 emby root 5120 Feb 10 2015 Patterns.Logging.dll -rw-r--r-- 1 emby root 649216 Jan 12 2015 ServiceStack.Api.Swagger.dll -rw-r--r-- 1 emby root 137216 Jan 12 2015 ServiceStack.Client.dll -rw-r--r-- 1 emby root 153088 Jan 12 2015 ServiceStack.Common.dll -rw-r--r-- 1 emby root 117248 Jan 12 2015 ServiceStack.Interfaces.dll -rw-r--r-- 1 emby root 286720 Jan 12 2015 ServiceStack.Text.dll -rw-r--r-- 1 emby root 1396736 Jan 12 2015 ServiceStack.dll -rw-r--r-- 1 emby root 420864 Jan 12 2015 SharpCompress.dll -rw-r--r-- 1 emby root 311808 May 8 2015 SimpleInjector.dll -rw-r--r-- 1 emby root 128512 Jun 15 2015 SocketHttpListener.dll -rw-r--r-- 1 emby root 273920 Jan 12 2015 System.Data.SQLite.dll -rw-r--r-- 1 emby root 94 Jan 12 2015 System.Data.SQLite.dll.config -rw-r--r-- 1 emby root 164352 Jan 12 2015 UniversalDetector.dll -rw-r--r-- 1 emby root 140800 Apr 14 2015 WebMarkupMin.Core.dll drwxr-xr-x 13 emby root 4096 Sep 21 19:26 dashboard-ui -rw-r--r-- 1 emby root 2095140 Jan 12 2015 libsqlite3.0.dylib -rw-r--r-- 1 emby root 18 Jan 12 2015 libsqlite3.dylib drwxr-xr-x 5 emby root 4096 Sep 21 19:26 swagger-ui -rw-r--r-- 1 emby root 443392 Jan 12 2015 taglib-sharp.dll DiskStation>
Luke 42243 Posted February 6, 2016 Author Posted February 6, 2016 @@KRULL, what you need to do is look at the contents of the zip and find the corresponding directory in your installation, and then unzip there. I apologize if that seems clunky. We are working on getting listed in the synology catalog. You can voice your opinion and help move that along here: https://github.com/SynoCommunity/spksrc/pull/1673 Thanks.
KRULL 10 Posted February 6, 2016 Posted February 6, 2016 (edited) I have no clue what to type to unzip in SSH to extract the contents and not create a folder. I have copied across the zip file, what do I tell it next? DiskStation> cd /volume1/Media/Emby DiskStation> cp EmbyMono.zip /volume1/@appstore/emby/share/emby Edit: Got it cd /volume1/Media/Emby cp EmbyMono.zip /volume1/@appstore/emby/share/emby unzip /volume1/@appstore/emby/share/emby/EmbyMono.zip Then select "A" to replace All. Edit 2: that didn't work, it shows I am still on Version 3.0.5724.5 Edit 3: Third time lucky, maybe it wasn't shut down completely last time. cd /volume1/Media/Emby mv Emby.Mono.zip /volume1/@appstore/emby/share/emby unzip /volume1/@appstore/emby/share/emby/Emby.Mono.zip Then select "A" to replace All. Version 3.0.5821.0 Now to figure out why it isn't working with Kodi properly, off to read those forums. Edited February 6, 2016 by KRULL
cytec 11 Posted February 6, 2016 Posted February 6, 2016 4. Copy the contents of the zip file into /volume1/@appstore/emby/share/emby (or wherever it has been installed, the contents of the zip should look like the contents of the folder you are copying into) like i said on the github issue already, you may should change that to /usr/local/emby/share/emby as it is not save that @appstore is saved on volume1 all the time... anyways like i already written in my mail i've got a huge step closer to finally get all this merged in and published on the website currently im waiting for code review and hopefully when that's done i can finally push empy to the repo *yeah* 3
RobsterUK 23 Posted February 8, 2016 Posted February 8, 2016 like i said on the github issue already, you may should change that to /usr/local/emby/share/emby as it is not save that @appstore is saved on volume1 all the time... anyways like i already written in my mail i've got a huge step closer to finally get all this merged in and published on the website currently im waiting for code review and hopefully when that's done i can finally push empy to the repo *yeah* & a big thanks for all the hard work in getting that far! Can't wait to see Emby as a one-click-package installer 1
scyto 0 Posted February 10, 2016 Posted February 10, 2016 like i said on the github issue already, you may should change that to /usr/local/emby/share/emby as it is not save that @appstore is saved on volume1 all the time... anyways like i already written in my mail i've got a huge step closer to finally get all this merged in and published on the website currently im waiting for code review and hopefully when that's done i can finally push empy to the repo *yeah* Just discovered emby (last time i looked at live TV solutions was 9+mo ago) this looks awesome, testing with my HDHomeRun and windows version of server. I assume the quote above means i should probably wait for this to appear on the offical synology package source rather than a community one? (sorry for being gum, but its my first post ;-) )
RobsterUK 23 Posted February 12, 2016 Posted February 12, 2016 (edited) Just discovered emby (last time i looked at live TV solutions was 9+mo ago) this looks awesome, testing with my HDHomeRun and windows version of server. I assume the quote above means i should probably wait for this to appear on the offical synology package source rather than a community one? (sorry for being gum, but its my first post ;-) ) Not sure whether this will be 'an official' package from the synology repo. It may still be a one-click package from the community repo. But a one-click package will resolve the multi-step current install method. Which will make the install/upgrade a much simpler process. You can still install Emby as per the guide on page 1 of this thread. Full functionality from installing in this way. Edited February 12, 2016 by RobsterUK
scyto 0 Posted February 12, 2016 Posted February 12, 2016 Not sure whether this will be 'an official' package from the synology repo. It may still be a one-click package from the community repo.But a one-click package will resolve the multi-step current install method. Which will make the install/upgrade a much simpler process. You can still install Emby as per the guide on page 1 of this thread. Full functionality from installing in this way. Thanks! I will wait for the one click from community repro. I bought a NAS so i didn't have to mess around too much (i had a disaster of a home made NAS - i do have some SAS adapters around if anyone wants them - hahahahah). The Homerun DVR SW is about as close as i want to get to messing with my NAS via SSH.
fantaxp7 191 Posted February 15, 2016 Posted February 15, 2016 I have a friend who installed the Syno package, he is reporting that all his watch statuses are not saving and changes to metadata and posters are not saving as well. What could be wrong? It would seem to me that the directory that the database and images are possibly incorrect or something.... Thanks for any input.
hMeco 0 Posted February 18, 2016 Posted February 18, 2016 (edited) Worked like a charm, every step Im on a Synology DS414 Edited February 19, 2016 by hMeco
darkbluesun 0 Posted February 25, 2016 Posted February 25, 2016 Can we please see a monaco version for the D216play? I'd really love to get this working. DS216play - synology_monaco_216play Thanks!
cytec 11 Posted February 29, 2016 Posted February 29, 2016 well there are technically some flaws on low cpu models... when it comes to transcoding.. basically if it's done you'll should be able to install emby on any device which can run mono/ffmpeg/imagemagick but transcoding might not work for all devices
Guest Posted March 1, 2016 Posted March 1, 2016 Did anyone manage to install Emby on the DS716+? It has an x64 Celeron processor (N3150), but the x64 packages can't be installed. There are no specific packages yet for the braswell architecture.
Guest Posted March 1, 2016 Posted March 1, 2016 (edited) Ok, I added the braswell architecture to the x64 packages for ImageMagick, ffmpeg and emby. All packages installed ok and the initial setup of emby went through without hickups. EDIT: Update doesn't work. After copying the files from Emby.Mono the package won't start. EDIT2: While setting everything up emby server stops randomly. Also Mono is using almost 5 GB of memory (and growing). So I'd say emby is not yet ready for use on DS716+ ... except as a Docker container, which runs fine. EDIT3: And stopped running fine because of some permission error. :\ Edited March 2, 2016 by peroksid
horstepipe 423 Posted March 9, 2016 Posted March 9, 2016 hey sorry for multipost, but I'm getting really frustrated. Emby doesn't start here, either. Hope somebody got a hint how I can find out what's going wrong. http://emby.media/community/index.php?/topic/32388-emby-just-doesnt-start/
horstepipe 423 Posted March 12, 2016 Posted March 12, 2016 people who can't start Emby on a DS414 or a armadaxp machine please report here: http://emby.media/community/index.php?/topic/32554-dsm-6-ds414-armadaxp/ thank you
ciss 4 Posted March 12, 2016 Posted March 12, 2016 hey guys, I have syno DS716+ but cant seem to find ImageMagick anywhere. Any help? Would love to try emby out!
