Luke 42243 Posted October 25, 2015 Author Posted October 25, 2015 Followed all directions in first post for this and it's just not working very well for me. Stalls out.. doesn't respond. I have this in my debug log. 2015-10-25 15:58:35.3763 Error - App: Error loading ImageMagick. Will revert to GDI. *** Error Report *** Version: 3.0.5724.6 Command line: /usr/local/emby/share/emby/MediaBrowser.Server.Mono.exe -programdata /usr/local/emby/var -ffmpeg /usr/local/ffmpeg/bin/ffmpeg -ffprobe /usr/local/ffmpeg/bin/ffprobe Operating system: Unix 3.10.35.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /usr/local/emby/var Mono: 4.0.4 (Stable 4.0.4.1/5ab4c0d Sun Oct 11 12:21:26 CEST 2015) Application Path: /volume1/@appstore/emby/share/emby/MediaBrowser.Server.Mono.exe libMagickWand-6.Q8.so System.DllNotFoundException at (wrapper managed-to-native) ImageMagickSharp.WandInterop:MagickWandGenesis () at ImageMagickSharp.Wand.InitializeEnvironment () [0x00000] in :0 at ImageMagickSharp.Wand..ctor () [0x00000] in :0 at ImageMagickSharp.Wand.<.cctor>b__5 () [0x00000] in :0 at System.Lazy`1[imageMagickSharp.Wand].CreateValue () [0x00000] in :0 Can anyone help? image magick isn't loading so something must not have gotten installed right.
Timmons 0 Posted October 25, 2015 Posted October 25, 2015 (edited) image magick isn't loading so something must not have gotten installed right. Just went and undid everything.. rebooted.. and redid it all again. Debug is showing the same thing. Have put full log in attachement server-63581388974.txt Edited October 25, 2015 by Timmons
Luke 42243 Posted October 26, 2015 Author Posted October 26, 2015 Just went and undid everything.. rebooted.. and redid it all again. Debug is showing the same thing. Have put full log in attachement You're fine. that error is just the server performing a feature test. i will change the log message on that going forward. at this point, is there an issue? your log looks fine other than some 404's to TheMovieDb.
Timmons 0 Posted October 26, 2015 Posted October 26, 2015 (edited) You're fine. that error is just the server performing a feature test. i will change the log message on that going forward. at this point, is there an issue? your log looks fine other than some 404's to TheMovieDb. Yeah still having issues. I left it running all night.. and it crashed this morning. The android app and playing through browser just times out when trying to access any movie or tv file. I have a DS1812+ that i'm trying this on. To be clear i've done the following: Package center-->Settings-->General choose-Trust Level any publisher Package center-->Settings-->Beta choose-Yes, I want to see beta version! Add http://packages.synocommunity.com/ and http://cytec.us/spk/ to Package center -->Package Source (not sure what cytec.us/spk serves here)? Check the what CPU/architecture you have in your synology https://github.com/S...r-Synology-mode so you can use the right Package for your base install.(#Shell command uname -a) Installation Install Mono from Package center --> Community Tab Install Mediainfo from Package center --> Community Tab Install ImageMagick from Package center --> Community Tab Download and Install ffmpeg from here: http://cytec.us/syno/test-spk/ffmpeg/ (using ffmpeg_x64-5.1_2.6-3.spk) Download and Install emby from here: http://cytec.us/syno/test-spk/emby/ (using emby_cedarview-5.1_3.0.5724.5-5.spk) Updating (i did this the first 2 times but didn't this last time) 1. Download and extract MediaBrowser.Mono.zip into a folder 2. Download and install winSCP http://winscp.net/eng/download.php login as root to synology 3. Make sure the Emby service is stopped 4. Copy the contents of the MediaBrowser.Mono folder into /volume1/@appstore/emby/share/emby (or wherever it has been installed, the contents of your MediaBrowser.Mono.zip should look like the contents of the folder you are copying into) Edited October 26, 2015 by Timmons
Luke 42243 Posted October 26, 2015 Author Posted October 26, 2015 Yeah still having issues. I left it running all night.. and it crashed this morning. The android app and playing through browser just times out when trying to access any movie or tv file. I have a DS1812+ that i'm trying this on. To be clear i've done the following: Package center-->Settings-->General choose-Trust Level any publisher Package center-->Settings-->Beta choose-Yes, I want to see beta version! Add http://packages.synocommunity.com/ and http://cytec.us/spk/ to Package center -->Package Source (not sure what cytec.us/spk serves here)? Check the what CPU/architecture you have in your synology https://github.com/S...r-Synology-mode so you can use the right Package for your base install.(#Shell command uname -a) Installation Install Mono from Package center --> Community Tab Install Mediainfo from Package center --> Community Tab Install ImageMagick from Package center --> Community Tab Download and Install ffmpeg from here: http://cytec.us/syno/test-spk/ffmpeg/ (using ffmpeg_x64-5.1_2.6-3.spk) Download and Install emby from here: http://cytec.us/syno/test-spk/emby/ (using emby_cedarview-5.1_3.0.5724.5-5.spk) Updating (i did this the first 2 times but didn't this last time) 1. Download and extract MediaBrowser.Mono.zip into a folder 2. Download and install winSCP http://winscp.net/eng/download.php login as root to synology 3. Make sure the Emby service is stopped 4. Copy the contents of the MediaBrowser.Mono folder into /volume1/@appstore/emby/share/emby (or wherever it has been installed, the contents of your MediaBrowser.Mono.zip should look like the contents of the folder you are copying into) Ok, please provide a bit more info: http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
litenin 0 Posted October 27, 2015 Posted October 27, 2015 First of all thank you for all your work. I looked forward to Emby server on our Synology devices. I started to install it for for my new DS 415+ but on SPK Package List, the aria2-avoton 1.17.1-2.spk link refers to aria2-Cedarview-1.17.1-2.spk. Is this normal? Thanks for your answer.
m-joy 15 Posted November 3, 2015 Posted November 3, 2015 Huhu, any chance for a monaco CPU Version ? I am using ds216play =) 1
beechlj 0 Posted November 3, 2015 Posted November 3, 2015 Hi, Having issues adding both the package sources for a new install onto a DS215J. I've added http://packages.synocommunity.com/ successfully, but when trying to add http://cytec.us/spk it throws an "Invalid location" error. I've tried adding https://cytec.us/spk as suggested by another user in this thread but this also fails. Any ideas?
Gernash 19 Posted November 4, 2015 Posted November 4, 2015 try using google dns (8.8.8.8) in DNS setting under networking I've found this to be an issue every now and then. But... you should be able to Download everything you need from http://cytec.us/syno/test-spk/
chambonito 0 Posted November 5, 2015 Posted November 5, 2015 I have it all setup according to the instructions with the exception of putting the zip file on the synology in the emby folder. I can't find the folder anywhere logging in through WINSCP or synology console. Please help..where is this folder?
Gernash 19 Posted November 6, 2015 Posted November 6, 2015 /volume1/@appstore/emby/share/emby (if you don't have a volume1 folder then it will be called whatever you named it when you created it - check storage manager, volume for it's name) you need to go to the root directory 1st in the syonology click the /.. in winscp to move up a directory.
m-joy 15 Posted November 6, 2015 Posted November 6, 2015 You should check if you have set your user to have the access rights for the emby folder. Go to your user panel and set all folders to full control.
chambonito 0 Posted November 6, 2015 Posted November 6, 2015 ok..thanks..but I still don't see any of these. I have this ... I don't have any app folder....
Gernash 19 Posted November 7, 2015 Posted November 7, 2015 (edited) hmmm, that looks like you are logging in via FTP and Not SSH. you need to connect using SSH you enable this in control Panel--> Terminal & SNMP --> enable SSH Service.(in the 1st tab) of the Synology And in Winscp you use SFTP or SCP and use your configured port i.e.22 (not 21) Edited November 7, 2015 by Gernash
RalT 0 Posted November 7, 2015 Posted November 7, 2015 (edited) so I'm not to smart when it comes to Linux...I was finally able to follow all the instructions to use WinSCP and access /volume1/@appstore/emby/share/emby I've Stopped Emby in Synology. I have downloaded and extracted MediaBrowser.Mono.zip into a folder and I can see both folders in WinSCP. and I select the contents of the MediaBrowser.Mono folder and click upload. it trys to overright then says permission denied. I've looked in the synology interface for someplace that suggests admin does not have full access to a folder but I don't really know what I'm looking for?? any help would be much appreciated!! FYI - I did try and change permissions iwth WinSCP and Synology returned Operation not permitted Edited November 7, 2015 by RalT
rabbit1543 106 Posted November 8, 2015 Posted November 8, 2015 You should log in with root and use the same password as your admin account.
RalT 0 Posted November 8, 2015 Posted November 8, 2015 Thank you Rabbit1543, again...fairly uneducated when it comes to linux so I was logging on TO root as Admin. I didn't realize root was the user name.
rabbit1543 106 Posted November 9, 2015 Posted November 9, 2015 No worries, in linux root is the super admin if you will. Synology will sync your admin pass with the root password. The way I look at it is that the admin account is the admin for anything gui or dsm related. Root is the admin you need when connecting to ssh ,scp , the things you can't do through the web interface. Be very cautious when and where you use root as this account will have full control over every aspect of a linux box
ReD-BaRoN 0 Posted November 15, 2015 Posted November 15, 2015 Any way to install on a 4.3 DSM based NAS (DS109)? ffmpeg is bombing out, requiring DSM 5.0, but 109 doesn't support that. Thanks!
Guest Damienouebe Posted November 23, 2015 Posted November 23, 2015 Hi folks, I'd love to test Emby on my DS213j but can't seem to be able to set it up... I downloaded the ffmpeg & emby Armada370 packages but when I do a manual installation (from my computer's hard drive), I get the wizard but no result page. And no entry in the packages (ffmpeg nor emby) list (no "Cytek" category either athough I added the source with HTTPs). Anything I'm doing wrong? Thanks in advance! Damien
Bernie V 7 Posted December 6, 2015 Posted December 6, 2015 I would like to install Emby on my Synology NAS model DS213+ (Qoriq architecture). I can't find 2 packages for my NAS model: ffmpeg and the mono package. The mono package isn't listed in the Synology Community packages tab, the ffmpeg (Qoriq) package isn't listed in this list http://cytec.us/syno/test-spk/ffmpeg/ Does this mean these packages aren't supported for my NAS? An Emby Qoriq package exist so I suppose that an Emby installation is possible on my NAS model?
miket5au 0 Posted December 7, 2015 Posted December 7, 2015 There is a Mono(beta) V3.12.1-0063 available from Synology in the package centre on my Synology 1815+. I have the V4.2.1 mono (beta) installed from Synocommunity. Will emby (I have 3.0.5724.5 installed) work with the Synology mono? Which is the best one to use?
David Derolez 0 Posted December 8, 2015 Posted December 8, 2015 Dear Team ! I've installed today emby on my new DS415+ Previously i experienced emby (since the first realease of media browser :-)) on my htpc and after on my synology ds412+ I've just upgraded my naps with a new ds415+ and more storage capacity :-))) But i experienced a big issue on the second page of configuration. I can add a a new media folder (i.e My Movies - Content type : movies but I can't add a a media location. But when selecting the Path, i select first /volume1 and the when selecting the next folder named "Médiathèque" i go back to the home screen ! Damn ! Of course i've tested on three different browsers Any idea ?
Luke 42243 Posted December 8, 2015 Author Posted December 8, 2015 Dear Team ! I've installed today emby on my new DS415+ Previously i experienced emby (since the first realease of media browser :-)) on my htpc and after on my synology ds412+ I've just upgraded my naps with a new ds415+ and more storage capacity :-))) But i experienced a big issue on the second page of configuration. I can add a a new media folder (i.e My Movies - Content type : movies but I can't add a a media location. But when selecting the Path, i select first /volume1 and the when selecting the next folder named "Médiathèque" i go back to the home screen ! Damn ! Of course i've tested on three different browsers Any idea ? It needs to be a path the Emby Server process has access to. That is probably the issue, although you can also check out how to report a problem so that we can give a more accurate assessment.
Gernash 19 Posted December 11, 2015 Posted December 11, 2015 @miket5au Mono 4.1.2 works fine. Only issue I have experienced (with all versions of mono) is the 1st time you start emby is stops after 30min or so once you start it again it runs normally. @David Derolez You can only use absolute path to media not UNC pathing as per the guide.
