KRULL 10 Posted September 18, 2015 Posted September 18, 2015 I installed Emby for the first time on my DS415+, I have not done the update part of the front page installation. I am using this with Kodi running on my Nvidia Shield TV. Two things I noticed, it runs library updates constantly. I was expecting to see the popup on Kodi when something new was added to the library folders as happens with the Watchdog add on (this add on was disabled). Any time I accessed the media to watch anything, as soon as I stopped, the Emby would scan the library again. It would then happen at other time frequently when I could not associate a reason for it to occur. Is there a setting I have missed that controls the frequency of these scans? Secondly, and a greater concern. It causes the RAM (I have 2GB) usage to double. Traditionally when I watch a program, both Mono and Python use about 120MB each. Emby is causing another process of Mono to run using RAM of about 240-260MB. Here are some screen shots to show usage and the effect of Emby and you can clearly see when I disable it. These were all taken playing back the same media file at rouchly the same time frame. I installed Emby for the first time on my DS415+, I have not done the update part of the front page installation. I am using this with Kodi running on my Nvidia Shield TV. Two things I noticed, it runs library updates constantly. I was expecting to see the popup on Kodi when something new was added to the library folders as happens with the Watchdog add on (this add on was disabled). Any time I accessed the media to watch anything, as soon as I stopped, the Emby would scan the library again. It would then happen at other time frequently when I could not associate a reason for it to occur. Is there a setting I have missed that controls the frequency of these scans? Secondly, and a greater concern. It causes the RAM (I have 2GB) usage to double. Traditionally when I watch a program, both Mono and Python use about 120MB each. Emby is causing another process of Mono to run using RAM of about 240-260MB. Here are some screen shots to show usage and the effect of Emby and you can clearly see when I disable it. These were all taken playing back the same media file at rouchly the same time frame. Shield with Kodi (no Emby) Shield Kodi with Emby Shield Kodi Emby being turned off.
Luke 42243 Posted September 18, 2015 Author Posted September 18, 2015 Hi @@KRULL, welcome. What version of the server are you running?
Luke 42243 Posted September 19, 2015 Author Posted September 19, 2015 Ok, yea that's getting a little old now. That version is from a few months ago and there have been a lot of improvements since then regarding library scanning. i'll see if i can get the package builder to build the latest. 1
66LUX 6 Posted September 20, 2015 Posted September 20, 2015 (edited) 2. Download and install winSCP http://winscp.net/eng/download.php login as root to synology I had trouble at this point. It might be worthwhile adding that you first need to enable SSH from within DSM5. To do this, go to Control Panel -> Terminal and SNMP -> Terminal tab and tick the "Enable SSH Service" box. Click apply. Edited September 20, 2015 by 66LUX 1
AdrianPal 0 Posted September 20, 2015 Posted September 20, 2015 Hello. Thanks for this tutorial, but I can't access to emby... When I go to http://my-nas-ip:8096 , it's very very very slow, and the page does't load (it redirects me on /web/wizardstart.html but I can't see it.....). Why ? What to do ?
Luke 42243 Posted September 20, 2015 Author Posted September 20, 2015 what do you mean you can't see it? what browser?
AdrianPal 0 Posted September 20, 2015 Posted September 20, 2015 Safari, or Chrome... In fact, I have finally been able to see the page, which tells me to choose the language... But the language list doesn't load.... It's EXTREMLY slow.... EXTREMLY !...
schumi2004 9 Posted September 27, 2015 Posted September 27, 2015 Is there also a ffmpeg package for Alpine architecture (DS715) or can i use package provided by SynoCommunity?
fodbrothers 1 Posted September 27, 2015 Posted September 27, 2015 Is there also a ffmpeg package for Alpine architecture (DS715) or can i use package provided by SynoCommunity? hi i used the x64 which installed ok but I have an issue play anything. if you find it works fine for you or have the same issue please let me know
Luke 42243 Posted September 27, 2015 Author Posted September 27, 2015 hi i used the x64 which installed ok but I have an issue play anything. if you find it works fine for you or have the same issue please let me know Hi, please see here for info that is needed: http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Darkjeje 11 Posted September 28, 2015 Posted September 28, 2015 Hello, What should I do to update Emby ?My version is 3.0.5597.1 Evansport .Should I follow this : Updating 1. Go to https://github.com/M...e/master/Server and download MediaBrowser.Mono.zip then extract into a folder 2. Download and install winSCP http://winscp.net/eng/download.php login as root to synology 3. Make sure the Emby service is stopped 4. Copy the contents of the MediaBrowser.Mono folder into /volume1/@appstore/emby/share/emby (or wherever it has been installed, the contents of your MediaBrowser.Mono.zip should look like the contents of the folder you are copying into) 5. At this point (till there is a new build) you need to edit /volume1/@appstore/emby/chare/emby/ImageMagicSharp.dll.config Change the Q8 to Q16 so the thumbnails work. <configuration> <dllmap dll="CORE_RL_Wand_.dll" target="libMagickWand-6.Q16.so" os="linux"/> <dllmap dll="CORE_RL_Wand_.dll" target="libMagickWand-6.so" os="freebsd,openbsd,netbsd"/> <dllmap dll="CORE_RL_Wand_.dll" target="./MediaInfo/osx/libmediainfo.dylib" os="osx"/></configuration> 5. Start Emby This is the procedure to update automatically Emby ? Thanks for your help. Jérémy
fodbrothers 1 Posted September 29, 2015 Posted September 29, 2015 no probs you may come accross the same problem as me find a fix in my other post "getting booted out when adding folders"
schumi2004 9 Posted September 29, 2015 Posted September 29, 2015 hi i used the x64 which installed ok but I have an issue play anything. if you find it works fine for you or have the same issue please let me know That wouldn't make sense imo. Since there is a emby package for alpine. On the other hand , there isn't a emby package for x64
AlwinHummels 134 Posted September 29, 2015 Posted September 29, 2015 (edited) New versions are on http://cytec.us/syno/test-spk/emby/ Thanks and all credits goes to Cytec Edited September 29, 2015 by AlwinHummels
Luke 42243 Posted September 29, 2015 Author Posted September 29, 2015 New versions are on http://cytec.us/syno/test-spk/emby/ Thanks and all credits goes to Cytec Well done!
schumi2004 9 Posted September 30, 2015 Posted September 30, 2015 New versions are on http://cytec.us/syno/test-spk/emby/ Thanks and all credits goes to Cytec Do you know if there will also be a updated ffmpeg package?
AlwinHummels 134 Posted September 30, 2015 Posted September 30, 2015 (edited) Do you know if there will also be a updated ffmpeg package? AFAIK not but maybe Cytec will pick this up when he have some spare time ;-) https://github.com/SynoCommunity/spksrc/issues/1346#issuecomment-144200827 and https://github.com/SynoCommunity/spksrc/pull/1673 Edited September 30, 2015 by AlwinHummels
schumi2004 9 Posted September 30, 2015 Posted September 30, 2015 (edited) AFAIK not but maybe Cytec will pick this up when he have some spare time ;-) https://github.com/SynoCommunity/spksrc/issues/1346#issuecomment-144200827 and https://github.com/SynoCommunity/spksrc/pull/1673 Thanks, monitoring pages now.Meanwhile i'll just try to compile ffmpeg myself and hopefully it won't throw errors /edit Okay, no more errors after fixing and applying patch, now the compiling part. Alpine ffmpeg package [not yet tested] https://www.dropbox.com/s/200nwxqnfsrxv1g/ffmpeg_alpine-5.2_2.6-3.spk?dl=0 /edit2: Almost there for 5.1 toolchain, if someone can give me a hint on what is going on? (above is 5.2) CC libavdevice/v4l2.o CC libavdevice/v4l2enc.o AR libavdevice/libavdevice.a /home/ubuntu/github/spksrc/toolchains/syno-alpine-5.1/work/arm-cortex_a15-linux-gnueabi/bin/arm-cortex_a15-linux-gnueabi-ranlib: '-D': No such file make[3]: *** [libavdevice/libavdevice.a] Error 1 make[3]: Leaving directory `/home/openelec/github/spksrc/spk/ffmpeg/work-alpine-5.1/ffmpeg-2.6' make[2]: *** [compile_target] Error 2 make[2]: Leaving directory `/home/openelec/github/spksrc/cross/ffmpeg' make[1]: *** [depend_target] Error 2 make[1]: Leaving directory `/home/openelec/github/spksrc/spk/ffmpeg' make: [arch-alpine-5.1] Error 2 (ignored) Edited September 30, 2015 by schumi2004
Lonald 10 Posted October 3, 2015 Posted October 3, 2015 (edited) Hi all, I successfully have emby server up on my DS2413+ and currently am scanning my libraries. I am using Emby Server 3.0.574.5 and installed the x64 version of ffmpeg. One installation instruction item that I'd like to point out - on the initial instructions from 2015-06-30 the address for cytec.us is incorrect as it is an https site, not http. I tried playing a Blu-Ray movie that I have on the server (while the library is being scanned) and the movie pegged the CPU utilization and so the playback was halting - 5 seconds of play and 15 sec of pause. I wonder if I have this installed correctly... The movie library is relatively large - and the scan is about 55% complete after 30-40 minutes. Thanks in advance! Lon Hmm... I'm watching the DSM resource monitor and the library scan alone is pinning the CPU at 99% and the memory use is also high. Edited October 3, 2015 by Lonald
bry 12 Posted October 5, 2015 Posted October 5, 2015 (edited) Hey guys! Thanks for this - i've hit a bit of a snag. Install ImageMagick from Package center --> Community Tab is not available in the package center. Edited October 5, 2015 by bry
