Tranquil 95 Posted June 30, 2015 Posted June 30, 2015 Hello Devs. Yesterday, something very confusing happened to me. Our Internetconnection was down for a while, haven't noticed that. I started KODI, which was working fine since the last weeks, but now I was not able to start a media file. It just keeps saying "A video plugin is need to work: EMBY". I then clicked on "install it" and nothing happened. The Entry "Video Add-Ons" was also missing in my Add-On overview. Manual installation was also not possible due to the missing inet connection. So far, then my girlfriend noticed the internet downtime, so I restarted the router and also restarted KODI which was then completely messed up. Internet was now available again. I wondered that all profiles (my girlfriends and mine) were deleted and just a single master user was available in KODI. All Skin settings also got reset. Unfortunately, I did not have a backup of my KODI setup so I had to reinstall everything. Can you reproduce that? I thought I read another post somewhere here on the forum also mentioned problems with Emby for KODI when there is not internet available, cant find it right now.
CBers 7554 Posted June 30, 2015 Posted June 30, 2015 Did you mean this: http://emby.media/community/index.php?/topic/22231-no-internet-no-emby-access-probably/ With Kodi installed on my Fire TV and Nexus Player, it was inaccessible.
Tranquil 95 Posted June 30, 2015 Author Posted June 30, 2015 Oh yes, thats the thread. But my KODI installation is on a normal windows 7 machine. Should not be affected as its not installed as an "app". Or?
