Luke 42241 Posted January 19, 2014 Posted January 19, 2014 Just to rule it out, make sure you're not testing with IE because we do have some known issues with streaming video to it.
ernstgot 17 Posted January 19, 2014 Posted January 19, 2014 I have tried it on Chrome, IE9, IE11, Firefox and I must say Chrome tends to be the best. but I do see some problems with jerky video and audio. Most likely a coding problem with the stream to the web interface. I can see the file in the WMC recoreded folder and can play it there just fine in media player but as soon as it streams to the website it glitches out. If anyone has an idea why please let me know. I have a 6core CPU 6100, and 8GB DDR3 Gaming memory. (localhost)
ernstgot 17 Posted January 19, 2014 Posted January 19, 2014 I am sure others are having this problem where the guide changes sizes. Just a quick heads up @Luke
Tikuf 663 Posted January 19, 2014 Posted January 19, 2014 The guide changes size as you get towards the end of the day as it is showing the programs for the day. Click on the today button and select tomorrow you will see what i mean.
DavidS1977 9 Posted January 19, 2014 Posted January 19, 2014 Aha - that fixed it! It works in Chrome, but is pretty jerky on HD. Assume this is due to my server only being dual core. Thanks for this so much! Gareth
jasonmcroy 320 Posted January 19, 2014 Posted January 19, 2014 (edited) Hello. Ok, so I have been testing the new plugin and serverwmc tonight. I had it working when I first installed it. It showed me all of my epg data, recordings, scheduled, etc. It all looked awesome. Then I tried to play a channel. The first one I played worked fine. Then I stopped that channel (with the stop button) and tried to play another one. It would not play so I hit the stop button. It went away and I tried another- same deal. I then uninstalled everything to give it another try. Now I am not getting the epg data to show up but my recordings show up when I view via the web browser. I have restarted my computer a couple of times but nothing is changing now. I am running Windows 7, MBS version 3.0.5131.18923, Server WMC version #1.0.0.21 Build 1114. I have pasted my log file here: http://paste2.org/K6a65sYt This is the log file from serverwmc. Let me know if there is anything else you need from me. By the way, when it was working it looked completely awesome btw! Thanks for all the work you guys have put into this! edit: I am using the Chrome browser if you need that data. Edited January 19, 2014 by jasonmcroy
grousie26 1 Posted January 19, 2014 Posted January 19, 2014 Hi I am getting the error "Invalid Source" and "There was an error playing the video. Please ensure there is an open tuner availalble." Here is the extract from ServerWMC log: 2014/01/19 19:51:53.950 OpenLiveStream> -----------------start------------------------ 2014/01/19 19:51:53.950 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 19:51:53.951 StreamProc> live-tv started 2014/01/19 19:51:53.954 SetChannel> Tuner: Hauppauge WinTV-7164 BDA DVBT Tuner #2 / 91e13a51-6718-4fde-b51d-f882792d58b9 2014/01/19 19:51:53.954 SetChannel> > Digital: True 2014/01/19 19:51:53.954 SetChannel> > Encrypted: False 2014/01/19 19:51:53.954 StreamProc> process start error: System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490) at ehiProxy.RecorderMgrClass.FindRecorderByID(Guid guid, IRecorderInfo& ppRecorder) at ServerWMC.Worker.RecordToWTV.SetChannel(Channel newC) at ServerWMC.Worker.RecordToWTV.ChangeChannel(Channel c, String newFileName) at ServerWMC.Worker.RecordToWTV.StartNewRecording(Channel c, String fileName, String clientName) at ServerWMC.Worker.StreamProc..ctor(String clientName, Channel c) 2014/01/19 19:51:53.955 StreamProc> calling Close() 2014/01/19 19:51:53.955 StreamProc::Close> remuxer was not running 2014/01/19 19:51:53.955 StreamProc::Close> wtv was not running 2014/01/19 19:51:53.955 StreamProc::Close> closed in 0.00 sec 2014/01/19 19:51:53.955 OpenLiveStream> error: System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490) at ServerWMC.Worker.StreamProc..ctor(String clientName, Channel c) at ServerWMC.Worker.StreamProc.StartStream(String clientName, Channel c, Boolean& alreadyStreaming) at ServerWMC.Worker.RecService.OpenLiveStream(String[] args) 2014/01/19 19:51:53.955 Finished request OpenLiveStream in 0.01s Any idea how I can get this working? I have tried in IE9 and Chrome. Thanks - Looks amazing!
wallaceff 3 Posted January 19, 2014 Posted January 19, 2014 If I am trying to run from the internet (not home network) and I have enabled the media browser ports (and confirmed they work -8096 and the other one)... Do I need to enable any other ports for live TV?
Danee 57 Posted January 19, 2014 Posted January 19, 2014 Yes, in hindsight tempxbmc has been become unfortunate naming on my part . Anyway, you just did what I was going to ask you to try. So now try to play one of these channels and then look at the server log (debug tab in serverwmc). Find the part of the log between OpenLiveStream and OpenLiveStream 'done' and paste it here. Or do you guys every use pastebin.com? You can post the whole log there and paste a link to it here. Hi Krusty, thanks for your reply. I seem to have wrecked my Media Center when trying to solve this (it's a test machine luckily), I first have to get it to play Live tv again before I can test again with ServerWMC and post the logs.
jcain 7 Posted January 19, 2014 Posted January 19, 2014 (edited) I'm having a bit of trouble with live tv. I've included the log link (https://www.dropbox.com/s/ytkesuvm6v4wmpy/ServerWMC.log) and some screen captures. Setup: Server: win7 pro, flexraid (v:), dual 6core cpus, 32gigs ram, dual 1gbps intel nics, MBS w/ live tv, serverwmc, and HDhomerun Prime 3tuner cable card setup. When using the server to stream live tv, no matter the quality of video chosen, the video/audio stutter very bad, every 5 seconds or so. Transcoding is set to Auto for the log. setting transcode to max does nothing. I'm really not even sure if the transcode tab even affects livetv, doesn't seem to. When using the server to push livetv to the extenders assigned to it, there is NOT an issue. When watching live TV from any pc, wireless or wired, in WMC throughout the house, there is NOT an issue. I can't watch live tv on the server itself to rule out any streaming issues, because it's headless. I'll also attach some screenshots. After reading through this thread, y'all are saying ffmpeg is the middle man for transcoding, yet i see no instance of ffmpg running on the server. Edited January 19, 2014 by jcain
Danee 57 Posted January 19, 2014 Posted January 19, 2014 (edited) Yes, in hindsight tempxbmc has been become unfortunate naming on my part . Anyway, you just did what I was going to ask you to try. So now try to play one of these channels and then look at the server log (debug tab in serverwmc). Find the part of the log between OpenLiveStream and OpenLiveStream 'done' and paste it here. Or do you guys every use pastebin.com? You can post the whole log there and paste a link to it here. Hi Krusty, I've got my Media Center running again, fresh install of everything , and I tested again. With IE I got exactly the same error but with Chrome it is working now. I still have the logs from the IE and Chrome try, just let me know if you're interested in them. I did however run into a different (reproducible) problem, I will create a new topic for that: http://mediabrowser.tv/community/index.php?/topic/4030-live-tv-problem-with-non-english-audio-shows/ Edited January 19, 2014 by Danee
Luke 42241 Posted January 19, 2014 Posted January 19, 2014 Hi Krusty, I've got my Media Center running again, fresh install of everything , and I tested again. With IE I got exactly the same error but with Chrome it is working now. I still have the logs from the IE and Chrome try, just let me know if you're interested in them. I did however run into a different (reproducible) problem, I will create a new topic for that. The IE video issues are a core issue and has nothing to do with live tv. We're working on it. 1
Danee 57 Posted January 19, 2014 Posted January 19, 2014 The IE video issues are a core issue and has nothing to do with live tv. We're working on it. Ok, thanks. Is there also a known issue with the live tv webclient on an ipad? For me the guide won't load and when I try to play a show via the channels tab it won't play but an active stream is created in ServerWMC (MediaBrowser^5). When I quit the player and safari that stream stays active and when I start safari again and navigate to the same show and press play another host (MediaBrowser^4) taps into the stream and it plays.
Deihmos 170 Posted January 19, 2014 Posted January 19, 2014 jasonmcroy, on 19 Jan 2014 - 03:08 AM, said: Hello. Ok, so I have been testing the new plugin and serverwmc tonight. I had it working when I first installed it. It showed me all of my epg data, recordings, scheduled, etc. It all looked awesome. Then I tried to play a channel. The first one I played worked fine. Then I stopped that channel (with the stop button) and tried to play another one. It would not play so I hit the stop button. It went away and I tried another- same deal. I then uninstalled everything to give it another try. Now I am not getting the epg data to show up but my recordings show up when I view via the web browser. I have restarted my computer a couple of times but nothing is changing now. I am running Windows 7, MBS version 3.0.5131.18923, Server WMC version #1.0.0.21 Build 1114. I have pasted my log file here: http://paste2.org/K6a65sYt This is the log file from serverwmc. Let me know if there is anything else you need from me. By the way, when it was working it looked completely awesome btw! Thanks for all the work you guys have put into this! edit: I am using the Chrome browser if you need that data. I have the same exact problem. I uninstalled it then just reinstalled and now nothing works.
ernstgot 17 Posted January 19, 2014 Posted January 19, 2014 If I am trying to run from the internet (not home network) and I have enabled the media browser ports (and confirmed they work -8096 and the other one)... Do I need to enable any other ports for live TV? No just make sure that your router has those ports forwarded and your firewall as well. Then you should be good.
Deihmos 170 Posted January 19, 2014 Posted January 19, 2014 (edited) I got it working. It does not really work with IE so use chrome. This is really good for beta and I notice that the server cpu use was really low even for hd content. I cannot get it to play anything on my cell phone using the chrome browser. Edited January 19, 2014 by Deihmos
Deuce911 10 Posted January 19, 2014 Posted January 19, 2014 I tried using Chrome but have the same issue, no video on the Web Client. I am selecting an OTA channel to play. Here is my ServerWMC log. 2014/01/19 12:17:06.130 ServerWMC started at 1/19/2014 12:17:06 PM 2014/01/19 12:17:06.131 Assembly version: 1.0.0.21, build: 1114 2014/01/19 12:17:06.131 Config file version: 40 2014/01/19 12:17:06.131 Click-once deployment: False 2014/01/19 12:17:06.132 OS: Windows 7 Service Pack 1 64-bit 2014/01/19 12:17:06.132 OS Version: 6.1.7601.65536 2014/01/19 12:17:07.229 Processor: Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz 2014/01/19 12:17:07.246 Graphics: Intel(R) HD Graphics 4000 2014/01/19 12:17:07.246 Server MachineName: MEDIACENTER-4 2014/01/19 12:17:07.270 RecService> Starting recording service... 2014/01/19 12:17:07.274 EPG> loading... 2014/01/19 12:17:07.276 EPG> 1. opening store2 2014/01/19 12:17:07.694 EPG> 1b. TV store opened 2014/01/19 12:17:07.699 EnumerateRecorders> Tuner Devices and TuningSpaces found: 2014/01/19 12:17:07.702 EnumerateRecorders> 0 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.702 EnumerateRecorders> HardwareId: 1a3d8baa-761e-43f7-942b-b147cd4d630c 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-2, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 1 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 143feb96-6c6c-4450-9f3f-e06ed98d6eab 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-2, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 2 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 2417b67e-c2e8-4ea8-8f92-fde314da2d4b 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-1, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 3 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 3065c1a1-64ea-40d5-8200-40420d34278d 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-0, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 4 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: fedd5b58-e257-4751-9db7-e86ded3672e9 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-0, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 5 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: cdb2e4d7-b66e-440d-acf6-f962ac692610 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-1, TuningSpace: Digital Cable 2014/01/19 12:17:07.760 EnumerateRecorders> 6 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 9666a51c-b670-437d-b49d-b99c47283da9 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10388AE6-0, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 7 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 48ecc5de-e53a-43a5-8cf8-e03ef9963c25 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10388AE6-1, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 8 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: c2c6c30c-12f0-4ed1-a53b-2f0fe0580838 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10390731-0, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 9 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 9f9c6d81-6bd3-4dcb-8bdb-9deaa09cdcbd 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10390731-1, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> done 2014/01/19 12:17:07.770 GetLineUpsAndChannels> started 2014/01/19 12:17:09.688 GetLineUpsAndChannels> DRM found: FS1, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.691 GetLineUpsAndChannels> DRM found: FS1HD, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.696 GetLineUpsAndChannels> DRM found: FS1, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.698 GetLineUpsAndChannels> DRM found: TMC, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.701 GetLineUpsAndChannels> DRM found: SHO2, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.705 GetLineUpsAndChannels> more than 5 channels found with DRM 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Total LineUps: 1, Total Channels to be exported: 445 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Channels found in database: 668 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Ignored channels> Blocked in WMC: 216, UserHidden: 7, No Service: 0, No Space: 0, OutOfRange: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Protected Channels> Encrypted: 0, DRM: 39 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Renamed CallSigns: 0, Renumbered Channels: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> ChannelGroups found in database: 1 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Ignored ChannelGroups> Blocked in WMC: 0, No Valid Channels: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> done 2014/01/19 12:17:09.827 EPG> loading done 2014/01/19 12:17:10.390 StartRecordingLibraryWatcher> recording library watcher started 2014/01/19 12:17:12.109 RecService> EventScheduler started 2014/01/19 12:17:12.109 RecService> tuner priming turned off 2014/01/19 12:17:12.110 LoadGenreDict> 'GenreDict.xml' loaded OK 2014/01/19 12:17:12.131 CheckChannelIcons> Channel icons processed: 359 2014/01/19 12:17:12.131 RecService> starting recording service - done 2014/01/19 12:17:12.136 Local 'Recorded tv' path: D:\Recorded TV\ 2014/01/19 12:17:12.137 Format: NTFS 2014/01/19 12:17:12.137 Network 'Recorded tv' path: smb://MEDIACENTER-4/Recorded TV 2014/01/19 12:17:12.138 Additional watched 'Recorded TV' folders: 2014/01/19 12:17:12.138 > \\WHS-2\Recorded TV 2014/01/19 12:17:12.423 SocketServer> starting up SocketServer 2014/01/19 12:17:12.423 SocketServer> permission to access sockets granted 2014/01/19 12:17:12.427 SocketServer> socket object created 2014/01/19 12:17:12.429 SocketServer> started on port: 9080 2014/01/19 12:17:12.431 MaintenanceTimer> callback at 12:17 PM 2014/01/19 12:17:12.463 MaintenanceTimer> callback - complete 2014/01/19 12:17:42.938 Client: 'MediaBrowser^' addon Version: 1.0.0.14, Client OS: windows 6.1.7601.65536 2014/01/19 12:17:42.941 Client: 'MediaBrowser^' running remotely: True 2014/01/19 12:17:42.944 Client: 'MediaBrowser^' path to Rec Folder: '\\MEDIACENTER-4\Recorded TV' 2014/01/19 12:18:06.158 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:09.146 Finished request GetTimers in 2.99s 2014/01/19 12:18:09.154 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:11.986 Finished request GetTimers in 2.83s 2014/01/19 12:18:15.009 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:17.860 Finished request GetTimers in 2.85s 2014/01/19 12:18:20.601 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:23.461 Finished request GetTimers in 2.86s 2014/01/19 12:18:29.671 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:32.422 Finished request GetTimers in 2.75s 2014/01/19 12:18:37.804 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:40.657 Finished request GetTimers in 2.85s 2014/01/19 12:18:48.688 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:51.545 Finished request GetTimers in 2.86s 2014/01/19 12:18:51.555 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:54.366 Finished request GetTimers in 2.81s 2014/01/19 12:18:54.499 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:57.380 Finished request GetTimers in 2.88s 2014/01/19 12:18:59.702 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:19:02.536 Finished request GetTimers in 2.83s 2014/01/19 12:19:06.222 Received client request: MediaBrowser^@WHS-2@10|OpenLiveStream|6808167 2014/01/19 12:19:06.226 OpenLiveStream> -----------------start------------------------ 2014/01/19 12:19:06.226 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 12:19:06.235 StreamProc> live-tv started 2014/01/19 12:19:06.250 SetChannel> Tuner: Silicondust HDHomeRun Tuner 10388AE6-0 / 9666a51c-b670-437d-b49d-b99c47283da9 2014/01/19 12:19:06.250 SetChannel> > Digital: True 2014/01/19 12:19:06.250 SetChannel> > Encrypted: False 2014/01/19 12:19:06.251 SetChannel> > RecorderInfo found: True 2014/01/19 12:19:06.260 SetChannel > busy: False, client: 2014/01/19 12:19:06.261 SetChannel> > tuner is available (taking tuner from ) => stopping search 2014/01/19 12:19:06.261 SetChannel> Recorder Content Protection: PROT_COPY_FREE 2014/01/19 12:19:06.265 SetChannel> Recorder acquired: True 2014/01/19 12:19:06.268 SetChannel> TuneRequest set 2014/01/19 12:19:06.288 StreamProc> wtv recording started in 0.05 sec 2014/01/19 12:19:06.288 StreamProc> stream output file: LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:06.290 StreamProc> started remux thread: 'KCTVDT-1003: 6808167' 2014/01/19 12:19:06.317 Remux::FindDescriptors> Scanning wtv for streams... 2014/01/19 12:19:07.823 Parse> Guid: 0 took 1.45 sec, it was attempted 692 times 2014/01/19 12:19:08.481 Parse> Descriptor pass done, using 500 guids in 0.66 sec 2014/01/19 12:19:08.481 Parse> Total Descriptor parse time: 2.11 sec 2014/01/19 12:19:08.481 Pass 'Descriptor': 2014/01/19 12:19:08.481 > WtvToPesDemuxer::Parse> total guid headers processed: 500 2014/01/19 12:19:08.481 > WtvToPesDemuxer::Parse> total data packets processed: 102 2014/01/19 12:19:08.486 Remux::FindDescriptors> wtv scanned (2.18 sec), Streams found: 2014/01/19 12:19:08.490 > Audio: ID:20 (eng) AC3 5.1 48000 Hz 448 kb/s 2014/01/19 12:19:08.492 > Video: ID:21 MPEG-2 MP-HL 1920x1080i fps: 30000/1001 AR: 16:9 2014/01/19 12:19:08.492 > Other: ID:22 MS TV Caption 2014/01/19 12:19:08.495 Remux::FindDescriptors> languages other than 'eng' removed: 0 2014/01/19 12:19:08.495 Remux::FindDescriptors> Output streams: 2014/01/19 12:19:08.495 > Audio: ID:20 (eng) AC3 5.1 48000 Hz 448 kb/s 2014/01/19 12:19:08.495 > Video: ID:21 MPEG-2 MP-HL 1920x1080i fps: 30000/1001 AR: 16:9 2014/01/19 12:19:08.571 StreamProc> 'ts' file created, size: 229,376 in 2.28 sec 2014/01/19 12:19:08.571 StreamProc> total time: 2.34 sec 2014/01/19 12:19:08.572 OpenLiveStream> stream path returned to client: \\MEDIACENTER-4\Recorded TV\TempXBMC\LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:08.572 OpenLiveStream> -----------------done------------------------- 2014/01/19 12:19:08.574 Finished request OpenLiveStream in 2.35s 2014/01/19 12:19:08.836 Received client request: MediaBrowser^@WHS-2@11|OpenLiveStream|6808167 2014/01/19 12:19:08.836 OpenLiveStream> -----------------start------------------------ 2014/01/19 12:19:08.836 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 12:19:08.844 OpenLiveStream> stream path returned to client: \\MEDIACENTER-4\Recorded TV\TempXBMC\LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:08.844 OpenLiveStream> -----------------done------------------------- 2014/01/19 12:19:08.845 Finished request OpenLiveStream in 0.01s 2014/01/19 12:19:35.891 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:19:38.873 Finished request GetTimers in 2.98s 2014/01/19 12:20:07.170 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:20:10.116 Finished request GetTimers in 2.95s 2014/01/19 12:20:10.121 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:20:13.132 Finished request GetTimers in 3.01s
ernstgot 17 Posted January 19, 2014 Posted January 19, 2014 So I am trying to use it on other Android devices cant seem to get it to play video on a samsung tab 10.1 (first edition), Sony Xperia Z, or the latest Sony Xperia tablet. Any idea? I have tried Chrome, firefox, and other browsers no luck. But on my Samsung S3 it works just fine.
Luke 42241 Posted January 19, 2014 Posted January 19, 2014 all playback issues need to be accompanied by three logs - mb server log, ffmpeg log + server wmc log 1
ernstgot 17 Posted January 19, 2014 Posted January 19, 2014 I tried using Chrome but have the same issue, no video on the Web Client. I am selecting an OTA channel to play. Here is my ServerWMC log. 2014/01/19 12:17:06.130 ServerWMC started at 1/19/2014 12:17:06 PM 2014/01/19 12:17:06.131 Assembly version: 1.0.0.21, build: 1114 2014/01/19 12:17:06.131 Config file version: 40 2014/01/19 12:17:06.131 Click-once deployment: False 2014/01/19 12:17:06.132 OS: Windows 7 Service Pack 1 64-bit 2014/01/19 12:17:06.132 OS Version: 6.1.7601.65536 2014/01/19 12:17:07.229 Processor: Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz 2014/01/19 12:17:07.246 Graphics: Intel(R) HD Graphics 4000 2014/01/19 12:17:07.246 Server MachineName: MEDIACENTER-4 2014/01/19 12:17:07.270 RecService> Starting recording service... 2014/01/19 12:17:07.274 EPG> loading... 2014/01/19 12:17:07.276 EPG> 1. opening store2 2014/01/19 12:17:07.694 EPG> 1b. TV store opened 2014/01/19 12:17:07.699 EnumerateRecorders> Tuner Devices and TuningSpaces found: 2014/01/19 12:17:07.702 EnumerateRecorders> 0 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.702 EnumerateRecorders> HardwareId: 1a3d8baa-761e-43f7-942b-b147cd4d630c 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-2, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 1 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 143feb96-6c6c-4450-9f3f-e06ed98d6eab 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-2, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 2 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 2417b67e-c2e8-4ea8-8f92-fde314da2d4b 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-1, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 3 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 3065c1a1-64ea-40d5-8200-40420d34278d 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-0, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 4 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: fedd5b58-e257-4751-9db7-e86ded3672e9 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-0, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 5 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: cdb2e4d7-b66e-440d-acf6-f962ac692610 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-1, TuningSpace: Digital Cable 2014/01/19 12:17:07.760 EnumerateRecorders> 6 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 9666a51c-b670-437d-b49d-b99c47283da9 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10388AE6-0, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 7 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 48ecc5de-e53a-43a5-8cf8-e03ef9963c25 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10388AE6-1, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 8 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: c2c6c30c-12f0-4ed1-a53b-2f0fe0580838 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10390731-0, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 9 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 9f9c6d81-6bd3-4dcb-8bdb-9deaa09cdcbd 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10390731-1, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> done 2014/01/19 12:17:07.770 GetLineUpsAndChannels> started 2014/01/19 12:17:09.688 GetLineUpsAndChannels> DRM found: FS1, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.691 GetLineUpsAndChannels> DRM found: FS1HD, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.696 GetLineUpsAndChannels> DRM found: FS1, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.698 GetLineUpsAndChannels> DRM found: TMC, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.701 GetLineUpsAndChannels> DRM found: SHO2, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.705 GetLineUpsAndChannels> more than 5 channels found with DRM 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Total LineUps: 1, Total Channels to be exported: 445 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Channels found in database: 668 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Ignored channels> Blocked in WMC: 216, UserHidden: 7, No Service: 0, No Space: 0, OutOfRange: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Protected Channels> Encrypted: 0, DRM: 39 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Renamed CallSigns: 0, Renumbered Channels: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> ChannelGroups found in database: 1 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Ignored ChannelGroups> Blocked in WMC: 0, No Valid Channels: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> done 2014/01/19 12:17:09.827 EPG> loading done 2014/01/19 12:17:10.390 StartRecordingLibraryWatcher> recording library watcher started 2014/01/19 12:17:12.109 RecService> EventScheduler started 2014/01/19 12:17:12.109 RecService> tuner priming turned off 2014/01/19 12:17:12.110 LoadGenreDict> 'GenreDict.xml' loaded OK 2014/01/19 12:17:12.131 CheckChannelIcons> Channel icons processed: 359 2014/01/19 12:17:12.131 RecService> starting recording service - done 2014/01/19 12:17:12.136 Local 'Recorded tv' path: D:\Recorded TV\ 2014/01/19 12:17:12.137 Format: NTFS 2014/01/19 12:17:12.137 Network 'Recorded tv' path: smb://MEDIACENTER-4/Recorded TV 2014/01/19 12:17:12.138 Additional watched 'Recorded TV' folders: 2014/01/19 12:17:12.138 > \\WHS-2\Recorded TV 2014/01/19 12:17:12.423 SocketServer> starting up SocketServer 2014/01/19 12:17:12.423 SocketServer> permission to access sockets granted 2014/01/19 12:17:12.427 SocketServer> socket object created 2014/01/19 12:17:12.429 SocketServer> started on port: 9080 2014/01/19 12:17:12.431 MaintenanceTimer> callback at 12:17 PM 2014/01/19 12:17:12.463 MaintenanceTimer> callback - complete 2014/01/19 12:17:42.938 Client: 'MediaBrowser^' addon Version: 1.0.0.14, Client OS: windows 6.1.7601.65536 2014/01/19 12:17:42.941 Client: 'MediaBrowser^' running remotely: True 2014/01/19 12:17:42.944 Client: 'MediaBrowser^' path to Rec Folder: '\\MEDIACENTER-4\Recorded TV' 2014/01/19 12:18:06.158 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:09.146 Finished request GetTimers in 2.99s 2014/01/19 12:18:09.154 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:11.986 Finished request GetTimers in 2.83s 2014/01/19 12:18:15.009 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:17.860 Finished request GetTimers in 2.85s 2014/01/19 12:18:20.601 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:23.461 Finished request GetTimers in 2.86s 2014/01/19 12:18:29.671 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:32.422 Finished request GetTimers in 2.75s 2014/01/19 12:18:37.804 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:40.657 Finished request GetTimers in 2.85s 2014/01/19 12:18:48.688 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:51.545 Finished request GetTimers in 2.86s 2014/01/19 12:18:51.555 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:54.366 Finished request GetTimers in 2.81s 2014/01/19 12:18:54.499 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:57.380 Finished request GetTimers in 2.88s 2014/01/19 12:18:59.702 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:19:02.536 Finished request GetTimers in 2.83s 2014/01/19 12:19:06.222 Received client request: MediaBrowser^@WHS-2@10|OpenLiveStream|6808167 2014/01/19 12:19:06.226 OpenLiveStream> -----------------start------------------------ 2014/01/19 12:19:06.226 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 12:19:06.235 StreamProc> live-tv started 2014/01/19 12:19:06.250 SetChannel> Tuner: Silicondust HDHomeRun Tuner 10388AE6-0 / 9666a51c-b670-437d-b49d-b99c47283da9 2014/01/19 12:19:06.250 SetChannel> > Digital: True 2014/01/19 12:19:06.250 SetChannel> > Encrypted: False 2014/01/19 12:19:06.251 SetChannel> > RecorderInfo found: True 2014/01/19 12:19:06.260 SetChannel > busy: False, client: 2014/01/19 12:19:06.261 SetChannel> > tuner is available (taking tuner from ) => stopping search 2014/01/19 12:19:06.261 SetChannel> Recorder Content Protection: PROT_COPY_FREE 2014/01/19 12:19:06.265 SetChannel> Recorder acquired: True 2014/01/19 12:19:06.268 SetChannel> TuneRequest set 2014/01/19 12:19:06.288 StreamProc> wtv recording started in 0.05 sec 2014/01/19 12:19:06.288 StreamProc> stream output file: LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:06.290 StreamProc> started remux thread: 'KCTVDT-1003: 6808167' 2014/01/19 12:19:06.317 Remux::FindDescriptors> Scanning wtv for streams... 2014/01/19 12:19:07.823 Parse> Guid: 0 took 1.45 sec, it was attempted 692 times 2014/01/19 12:19:08.481 Parse> Descriptor pass done, using 500 guids in 0.66 sec 2014/01/19 12:19:08.481 Parse> Total Descriptor parse time: 2.11 sec 2014/01/19 12:19:08.481 Pass 'Descriptor': 2014/01/19 12:19:08.481 > WtvToPesDemuxer::Parse> total guid headers processed: 500 2014/01/19 12:19:08.481 > WtvToPesDemuxer::Parse> total data packets processed: 102 2014/01/19 12:19:08.486 Remux::FindDescriptors> wtv scanned (2.18 sec), Streams found: 2014/01/19 12:19:08.490 > Audio: ID:20 (eng) AC3 5.1 48000 Hz 448 kb/s 2014/01/19 12:19:08.492 > Video: ID:21 MPEG-2 MP-HL 1920x1080i fps: 30000/1001 AR: 16:9 2014/01/19 12:19:08.492 > Other: ID:22 MS TV Caption 2014/01/19 12:19:08.495 Remux::FindDescriptors> languages other than 'eng' removed: 0 2014/01/19 12:19:08.495 Remux::FindDescriptors> Output streams: 2014/01/19 12:19:08.495 > Audio: ID:20 (eng) AC3 5.1 48000 Hz 448 kb/s 2014/01/19 12:19:08.495 > Video: ID:21 MPEG-2 MP-HL 1920x1080i fps: 30000/1001 AR: 16:9 2014/01/19 12:19:08.571 StreamProc> 'ts' file created, size: 229,376 in 2.28 sec 2014/01/19 12:19:08.571 StreamProc> total time: 2.34 sec 2014/01/19 12:19:08.572 OpenLiveStream> stream path returned to client: \\MEDIACENTER-4\Recorded TV\TempXBMC\LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:08.572 OpenLiveStream> -----------------done------------------------- 2014/01/19 12:19:08.574 Finished request OpenLiveStream in 2.35s 2014/01/19 12:19:08.836 Received client request: MediaBrowser^@WHS-2@11|OpenLiveStream|6808167 2014/01/19 12:19:08.836 OpenLiveStream> -----------------start------------------------ 2014/01/19 12:19:08.836 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 12:19:08.844 OpenLiveStream> stream path returned to client: \\MEDIACENTER-4\Recorded TV\TempXBMC\LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:08.844 OpenLiveStream> -----------------done------------------------- 2014/01/19 12:19:08.845 Finished request OpenLiveStream in 0.01s 2014/01/19 12:19:35.891 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:19:38.873 Finished request GetTimers in 2.98s 2014/01/19 12:20:07.170 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:20:10.116 Finished request GetTimers in 2.95s 2014/01/19 12:20:10.121 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:20:13.132 Finished request GetTimers in 3.01s I had this issue and one thing that seemed to fix it was going into the dashboard and telling it to install the the ServerWMC plugin again. Not install ServerWMC backend just the plugin within the dashboard. And restart the server.
krustyreturns 191 Posted January 19, 2014 Posted January 19, 2014 I tried using Chrome but have the same issue, no video on the Web Client. I am selecting an OTA channel to play. Here is my ServerWMC log. 2014/01/19 12:17:06.130 ServerWMC started at 1/19/2014 12:17:06 PM 2014/01/19 12:17:06.131 Assembly version: 1.0.0.21, build: 1114 2014/01/19 12:17:06.131 Config file version: 40 2014/01/19 12:17:06.131 Click-once deployment: False 2014/01/19 12:17:06.132 OS: Windows 7 Service Pack 1 64-bit 2014/01/19 12:17:06.132 OS Version: 6.1.7601.65536 2014/01/19 12:17:07.229 Processor: Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz 2014/01/19 12:17:07.246 Graphics: Intel(R) HD Graphics 4000 2014/01/19 12:17:07.246 Server MachineName: MEDIACENTER-4 2014/01/19 12:17:07.270 RecService> Starting recording service... 2014/01/19 12:17:07.274 EPG> loading... 2014/01/19 12:17:07.276 EPG> 1. opening store2 2014/01/19 12:17:07.694 EPG> 1b. TV store opened 2014/01/19 12:17:07.699 EnumerateRecorders> Tuner Devices and TuningSpaces found: 2014/01/19 12:17:07.702 EnumerateRecorders> 0 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.702 EnumerateRecorders> HardwareId: 1a3d8baa-761e-43f7-942b-b147cd4d630c 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-2, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 1 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 143feb96-6c6c-4450-9f3f-e06ed98d6eab 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-2, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 2 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 2417b67e-c2e8-4ea8-8f92-fde314da2d4b 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-1, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 3 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: 3065c1a1-64ea-40d5-8200-40420d34278d 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-0, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 4 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: fedd5b58-e257-4751-9db7-e86ded3672e9 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 1315F58A-0, TuningSpace: Digital Cable 2014/01/19 12:17:07.759 EnumerateRecorders> 5 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.759 EnumerateRecorders> HardwareId: cdb2e4d7-b66e-440d-acf6-f962ac692610 2014/01/19 12:17:07.759 EnumerateRecorders> count: 0 Device name: HDHomeRun Prime Tuner 131757E1-1, TuningSpace: Digital Cable 2014/01/19 12:17:07.760 EnumerateRecorders> 6 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 9666a51c-b670-437d-b49d-b99c47283da9 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10388AE6-0, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 7 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 48ecc5de-e53a-43a5-8cf8-e03ef9963c25 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10388AE6-1, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 8 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: c2c6c30c-12f0-4ed1-a53b-2f0fe0580838 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10390731-0, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> 9 Content Recorder HardwareBaseId: 2014/01/19 12:17:07.760 EnumerateRecorders> HardwareId: 9f9c6d81-6bd3-4dcb-8bdb-9deaa09cdcbd 2014/01/19 12:17:07.760 EnumerateRecorders> count: 0 Device name: Silicondust HDHomeRun Tuner 10390731-1, TuningSpace: ATSC 2014/01/19 12:17:07.760 EnumerateRecorders> done 2014/01/19 12:17:07.770 GetLineUpsAndChannels> started 2014/01/19 12:17:09.688 GetLineUpsAndChannels> DRM found: FS1, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.691 GetLineUpsAndChannels> DRM found: FS1HD, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.696 GetLineUpsAndChannels> DRM found: FS1, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.698 GetLineUpsAndChannels> DRM found: TMC, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.701 GetLineUpsAndChannels> DRM found: SHO2, drm: PROT_COPY_ONCE 2014/01/19 12:17:09.705 GetLineUpsAndChannels> more than 5 channels found with DRM 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Total LineUps: 1, Total Channels to be exported: 445 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Channels found in database: 668 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Ignored channels> Blocked in WMC: 216, UserHidden: 7, No Service: 0, No Space: 0, OutOfRange: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Protected Channels> Encrypted: 0, DRM: 39 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Renamed CallSigns: 0, Renumbered Channels: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> ChannelGroups found in database: 1 2014/01/19 12:17:09.827 GetLineUpsAndChannels> Ignored ChannelGroups> Blocked in WMC: 0, No Valid Channels: 0 2014/01/19 12:17:09.827 GetLineUpsAndChannels> done 2014/01/19 12:17:09.827 EPG> loading done 2014/01/19 12:17:10.390 StartRecordingLibraryWatcher> recording library watcher started 2014/01/19 12:17:12.109 RecService> EventScheduler started 2014/01/19 12:17:12.109 RecService> tuner priming turned off 2014/01/19 12:17:12.110 LoadGenreDict> 'GenreDict.xml' loaded OK 2014/01/19 12:17:12.131 CheckChannelIcons> Channel icons processed: 359 2014/01/19 12:17:12.131 RecService> starting recording service - done 2014/01/19 12:17:12.136 Local 'Recorded tv' path: D:\Recorded TV\ 2014/01/19 12:17:12.137 Format: NTFS 2014/01/19 12:17:12.137 Network 'Recorded tv' path: smb://MEDIACENTER-4/Recorded TV 2014/01/19 12:17:12.138 Additional watched 'Recorded TV' folders: 2014/01/19 12:17:12.138 > \\WHS-2\Recorded TV 2014/01/19 12:17:12.423 SocketServer> starting up SocketServer 2014/01/19 12:17:12.423 SocketServer> permission to access sockets granted 2014/01/19 12:17:12.427 SocketServer> socket object created 2014/01/19 12:17:12.429 SocketServer> started on port: 9080 2014/01/19 12:17:12.431 MaintenanceTimer> callback at 12:17 PM 2014/01/19 12:17:12.463 MaintenanceTimer> callback - complete 2014/01/19 12:17:42.938 Client: 'MediaBrowser^' addon Version: 1.0.0.14, Client OS: windows 6.1.7601.65536 2014/01/19 12:17:42.941 Client: 'MediaBrowser^' running remotely: True 2014/01/19 12:17:42.944 Client: 'MediaBrowser^' path to Rec Folder: '\\MEDIACENTER-4\Recorded TV' 2014/01/19 12:18:06.158 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:09.146 Finished request GetTimers in 2.99s 2014/01/19 12:18:09.154 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:11.986 Finished request GetTimers in 2.83s 2014/01/19 12:18:15.009 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:17.860 Finished request GetTimers in 2.85s 2014/01/19 12:18:20.601 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:23.461 Finished request GetTimers in 2.86s 2014/01/19 12:18:29.671 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:32.422 Finished request GetTimers in 2.75s 2014/01/19 12:18:37.804 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:40.657 Finished request GetTimers in 2.85s 2014/01/19 12:18:48.688 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:51.545 Finished request GetTimers in 2.86s 2014/01/19 12:18:51.555 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:54.366 Finished request GetTimers in 2.81s 2014/01/19 12:18:54.499 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:18:57.380 Finished request GetTimers in 2.88s 2014/01/19 12:18:59.702 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:19:02.536 Finished request GetTimers in 2.83s 2014/01/19 12:19:06.222 Received client request: MediaBrowser^@WHS-2@10|OpenLiveStream|6808167 2014/01/19 12:19:06.226 OpenLiveStream> -----------------start------------------------ 2014/01/19 12:19:06.226 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 12:19:06.235 StreamProc> live-tv started 2014/01/19 12:19:06.250 SetChannel> Tuner: Silicondust HDHomeRun Tuner 10388AE6-0 / 9666a51c-b670-437d-b49d-b99c47283da9 2014/01/19 12:19:06.250 SetChannel> > Digital: True 2014/01/19 12:19:06.250 SetChannel> > Encrypted: False 2014/01/19 12:19:06.251 SetChannel> > RecorderInfo found: True 2014/01/19 12:19:06.260 SetChannel > busy: False, client: 2014/01/19 12:19:06.261 SetChannel> > tuner is available (taking tuner from ) => stopping search 2014/01/19 12:19:06.261 SetChannel> Recorder Content Protection: PROT_COPY_FREE 2014/01/19 12:19:06.265 SetChannel> Recorder acquired: True 2014/01/19 12:19:06.268 SetChannel> TuneRequest set 2014/01/19 12:19:06.288 StreamProc> wtv recording started in 0.05 sec 2014/01/19 12:19:06.288 StreamProc> stream output file: LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:06.290 StreamProc> started remux thread: 'KCTVDT-1003: 6808167' 2014/01/19 12:19:06.317 Remux::FindDescriptors> Scanning wtv for streams... 2014/01/19 12:19:07.823 Parse> Guid: 0 took 1.45 sec, it was attempted 692 times 2014/01/19 12:19:08.481 Parse> Descriptor pass done, using 500 guids in 0.66 sec 2014/01/19 12:19:08.481 Parse> Total Descriptor parse time: 2.11 sec 2014/01/19 12:19:08.481 Pass 'Descriptor': 2014/01/19 12:19:08.481 > WtvToPesDemuxer::Parse> total guid headers processed: 500 2014/01/19 12:19:08.481 > WtvToPesDemuxer::Parse> total data packets processed: 102 2014/01/19 12:19:08.486 Remux::FindDescriptors> wtv scanned (2.18 sec), Streams found: 2014/01/19 12:19:08.490 > Audio: ID:20 (eng) AC3 5.1 48000 Hz 448 kb/s 2014/01/19 12:19:08.492 > Video: ID:21 MPEG-2 MP-HL 1920x1080i fps: 30000/1001 AR: 16:9 2014/01/19 12:19:08.492 > Other: ID:22 MS TV Caption 2014/01/19 12:19:08.495 Remux::FindDescriptors> languages other than 'eng' removed: 0 2014/01/19 12:19:08.495 Remux::FindDescriptors> Output streams: 2014/01/19 12:19:08.495 > Audio: ID:20 (eng) AC3 5.1 48000 Hz 448 kb/s 2014/01/19 12:19:08.495 > Video: ID:21 MPEG-2 MP-HL 1920x1080i fps: 30000/1001 AR: 16:9 2014/01/19 12:19:08.571 StreamProc> 'ts' file created, size: 229,376 in 2.28 sec 2014/01/19 12:19:08.571 StreamProc> total time: 2.34 sec 2014/01/19 12:19:08.572 OpenLiveStream> stream path returned to client: \\MEDIACENTER-4\Recorded TV\TempXBMC\LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:08.572 OpenLiveStream> -----------------done------------------------- 2014/01/19 12:19:08.574 Finished request OpenLiveStream in 2.35s 2014/01/19 12:19:08.836 Received client request: MediaBrowser^@WHS-2@11|OpenLiveStream|6808167 2014/01/19 12:19:08.836 OpenLiveStream> -----------------start------------------------ 2014/01/19 12:19:08.836 OpenLiveStream> client: MediaBrowser^ requesting live stream 2014/01/19 12:19:08.844 OpenLiveStream> stream path returned to client: \\MEDIACENTER-4\Recorded TV\TempXBMC\LiveTV_MediaBrowser^10_ATSC_1003_2014_01_19_12_19_06.ts 2014/01/19 12:19:08.844 OpenLiveStream> -----------------done------------------------- 2014/01/19 12:19:08.845 Finished request OpenLiveStream in 0.01s 2014/01/19 12:19:35.891 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:19:38.873 Finished request GetTimers in 2.98s 2014/01/19 12:20:07.170 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:20:10.116 Finished request GetTimers in 2.95s 2014/01/19 12:20:10.121 Received client request: MediaBrowser^@WHS-2@|GetTimers 2014/01/19 12:20:13.132 Finished request GetTimers in 3.01s It looks like you are running mbs on different machine then swmc. In this case, the 'recorded tv' folder that wmc uses to save wtv recordings needs to be a shared folder, accessible by the mb3 machine, have you set this up?
jcain 7 Posted January 19, 2014 Posted January 19, 2014 How do I provide an ffmpeg log when it never even launches
jcain 7 Posted January 19, 2014 Posted January 19, 2014 (edited) Double Edited January 19, 2014 by jcain
Latchmor 584 Posted January 19, 2014 Posted January 19, 2014 (edited) @@jcain Hi, in your Task Manager screen print above I see you have RDP'd to the server. You need to click 'Show Processes from all users' to see if ffmpeg.exe is there. Either way, have you checked the C:\Users\[username]\AppData\Roaming\MediaBrowser-Server\logs folder anyway for ffmpeg files? Cheers Edited January 19, 2014 by Latchmor
Luke 42241 Posted January 19, 2014 Posted January 19, 2014 How do I provide an ffmpeg log when it never even launches that's fine then. when that happens server log and server wmc log are fine.
