Latchmor 584 Posted January 18, 2014 Posted January 18, 2014 (edited) Aye, it's a wee bit tasty! Up and running within 2 mins! Edit: Nice, Live TV on my Nexus 4 via Web Client. Edited January 18, 2014 by Latchmor
Luke 42241 Posted January 18, 2014 Posted January 18, 2014 Any ETA on the nextpvr plugin? :runs for cover : Our developer for that has not been as available lately. I am looking for a contributor to help finish it. If I don't find one I might do it but it would be a little while. 1
ernstgot 17 Posted January 18, 2014 Posted January 18, 2014 i wonder if there would be a away to implement a overscan as i use analog for my tv tuner. in wmc i set it up to zoom 3 to get ride of the side bars. in xmbc i adjust the display ration to i think 1.38 or something like that. top image is the web client with the side black bars bottom image is wmc without side black bars just wondering if that would be possible in the webclient to get ride of the side black bars? I would be nice for a zoom function as its called in WMC
ernstgot 17 Posted January 18, 2014 Posted January 18, 2014 Any way we could get more then 100 channels in the guide
danvella 0 Posted January 18, 2014 Posted January 18, 2014 Sorry for the obvious question. I have this going in MB Server, how do I get the interface to show up a client?
Latchmor 584 Posted January 18, 2014 Posted January 18, 2014 Sorry for the obvious question. I have this going in MB Server, how do I get the interface to show up a client? Hi, it's only in the web client just now. Others will follow. See below. Cheers
Danee 57 Posted January 18, 2014 Posted January 18, 2014 I can't get it to work yet. At first everything connected correctly but I got an error when starting a TV show. I decided to configure it all again but I run into the same problem. I get this error: At that time ServerWMC shows 'Streaming DVB-T channel 4 to [MediaBrowser^0]' at active streams. After this error occurs I can play that channel (or any else) in Media Center itself. I have tried this with Internet Explorer 11 and Firefox on a windows 7 computer and on an ipad. MBS runs on a WHS 2011 and the Live TV plugin connects to the windows 7 computer. The Media Center has no physical tuners connected, on the WHS I run dvblink that serves the locally connected tuners as PBDA DVB-T tuners into Media Center. The only thing I haven't tried yet is hooking up a physical tuner to the Media Center. (btw, it would be very use full if there was a ''Run now' option for the 'Refresh Guide' task in MBS)
Latchmor 584 Posted January 18, 2014 Posted January 18, 2014 (btw, it would be very use full if there was a ''Run now' option for the 'Refresh Guide' task in MBS) Do you mean in the Client? I'm guessing you know there is one here in the Dashboard settings?
ernstgot 17 Posted January 18, 2014 Posted January 18, 2014 (edited) I can't get it to work yet. At first everything connected correctly but I got an error when starting a TV show. I decided to configure it all again but I run into the same problem. I get this error: I also get this at times, Other times when i click on a show in the guide it doesn't bring up the play button in the details screen. At that time ServerWMC shows 'Streaming DVB-T channel 4 to [MediaBrowser^0]' at active streams. After this error occurs I can play that channel (or any else) in Media Center itself. I have tried this with Internet Explorer 11 and Firefox on a windows 7 computer and on an ipad. MBS runs on a WHS 2011 and the Live TV plugin connects to the windows 7 computer. The Media Center has no physical tuners connected, on the WHS I run dvblink that serves the locally connected tuners as PBDA DVB-T tuners into Media Center. The only thing I haven't tried yet is hooking up a physical tuner to the Media Center. (btw, it would be very use full if there was a ''Run now' option for the 'Refresh Guide' task in MBS) I also get this sometimes, also when I click a show in guide I get the details screen but no play button? Edited January 18, 2014 by ernstgot
Danee 57 Posted January 18, 2014 Posted January 18, 2014 Do you mean in the Client? I'm guessing you know there is one here in the Dashboard settings? No, I mean in Media Browser server, it only shows there options: A 'Run now' option would be use full.
bloodtaker 71 Posted January 18, 2014 Posted January 18, 2014 the little forward arrow if you hit it = run now
Latchmor 584 Posted January 18, 2014 Posted January 18, 2014 (edited) Yeah Bloodtaker beat me but see the little arrow (triangle) in my pic above. Edited January 18, 2014 by Latchmor
Danee 57 Posted January 18, 2014 Posted January 18, 2014 (edited) I also get this sometimes, also when I click a show in guide I get the details screen but no play button? Yes, I've seen that too. To add to my problem, when I browse to the tempXBMC (? ) folder in Recorded TV a ts stream file and a wtv file is created for the show I try to play and both files can be played in Windows Media player while the web client displays the error. Edited January 18, 2014 by Danee 1
Danee 57 Posted January 18, 2014 Posted January 18, 2014 Thanks Latchmore, Bloodtaker, I missed that button completely
ernstgot 17 Posted January 18, 2014 Posted January 18, 2014 how about a REC button on the taskbar at the bottom for recording current playing show
JohnWhitmore 30 Posted January 18, 2014 Posted January 18, 2014 (edited) *** Ignore - solved*** Hello all, just trying to setup LiveTV on my setup. It is not a standard setup, but may be a common setup. I have a server that hosts the MediaBrowser Server. In the lounge I have a HTPC server that runs WMC and MediaBrowser Classic. This second box has the TV Tuner cards. I have installed ServerWMC onto the HTPC - note I had to change the ports as these are currently being used by Remote Potato. I am trying to setup the MB Server to access this info...I cannot find where on the MB Server I can change the IP and Port for the ServerWMC client... Can anyone give me a tip? John ***Edit - solution*** The settings are there....under Plugins then click ServerWMC.....DOH!!!! Edited January 18, 2014 by JohnWhitmore 1
bloodtaker 71 Posted January 18, 2014 Posted January 18, 2014 http://192.168.1.101:8096/mediabrowser/dashboard/ConfigurationPage?name=ServerWMC%20Addon in the server go to plugins find wmc plugin click on it ip and port go there
Latchmor 584 Posted January 18, 2014 Posted January 18, 2014 Wish the wife would bugger off to bed so i can install this!!!! Sent by my HTC8X using Tapatalk LOL
SLAYER6669 0 Posted January 18, 2014 Posted January 18, 2014 I have this working pretty good. Can't wait until Live TV hits the Android app. The only issue I appear to be having is if I watch a channel live, then stop it, it does not release the tuner. If I go into my Ceton tuner device page I still have 4 tuners playing right now when only my HTPC has a live channel tuned at the moment.
Luke 42241 Posted January 18, 2014 Posted January 18, 2014 I have this working pretty good. Can't wait until Live TV hits the Android app. The only issue I appear to be having is if I watch a channel live, then stop it, it does not release the tuner. If I go into my Ceton tuner device page I still have 4 tuners playing right now when only my HTPC has a live channel tuned at the moment. Hmm, if that's true then that will be serious enough to warrant a follow-up release.
krustyreturns 191 Posted January 18, 2014 Posted January 18, 2014 Yes, I've seen that too. To add to my problem, when I browse to the tempXBMC (? ) folder in Recorded TV a ts stream file and a wtv file is created for the show I try to play and both files can be played in Windows Media player while the web client displays the error. Yes, in hindsight tempxbmc has been become unfortunate naming on my part . Anyway, you just did what I was going to ask you to try. So now try to play one of these channels and then look at the server log (debug tab in serverwmc). Find the part of the log between OpenLiveStream and OpenLiveStream 'done' and paste it here. Or do you guys every use pastebin.com? You can post the whole log there and paste a link to it here.
