Dan64 32 Posted June 28, 2015 Posted June 28, 2015 After installing the version 1.0.15 my playlists do not works on Kodi 14.2. I have performed the reset of local Kodi DB. But the playlists that I'm using still are not working. Here an example of playlist: <?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <smartplaylist type="movies"> <name>Films-Azione</name> <match>all</match> <rule field="path" operator="contains"> <value>Movies/Films/Azione</value> </rule> </smartplaylist> the full path is the following \\192.168.0.11\Emby\Movies\Films\Avventura\ Before the upgrade all the movies inside the folder "Avventura" were selected now none is found.
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 (edited) I'm using network paths. The Kodi client is running on Windows 8.1 and the directories are fully accessible by windows apps. Before the upgrade I was using the emby for kodi version 0.33 (or 0.32 I don't remember). There is a storage where are downloaded the addons that I can use to recover the old version ? the rollback feature seems to be disabled. Edited June 28, 2015 by Dan64
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 (edited) Err yeah, you will need to reset and rescan your library in, then hopefully your smart playlist will pick up on the content. There's too much that changed in between, a clean slate for your database is required. If you want to remain on 0.32: https://github.com/MediaBrowser/Emby.Kodi/releases/tag/plugin.video.emby-0.0.32 This is why it's best to do a backup of your userdata folder, then you can easily revert back. Now there's no guarantee that even going back things will work. But I will say that the initial scan speed has greatly improved since. So it might be easier/faster to just start from scratch in your situation. Edited June 28, 2015 by Angelblue05
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 I have already performed a "Reset of local Kodi DB" and performed a rescan, but the problem still persist. For the moment I will try to revert back to 0.32. Thanks for the zip file. I discovered that the size of my package directory was above the limit allowed to have rollback enabled.
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 (edited) The reason I asked for the paths is because this is not a valid path for Kodi (with the IP). I think you'd need to set your path in Emby as nfs://IP/path/to/content You'd need to troubleshoot this more, because I have playlists working just fine in Kodi with v1.0.15. Anyway, if one day you change your mind, we are here to help as much as we can. Edited June 28, 2015 by Angelblue05
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 But I don't understand why was working on 0.0.32 and on 0.1.3 (I have discovered that I was running this version). The problem is that I'm using path substitution on server side and this path is valid for windows since I'm also using Emby for Windows. I don't think that the problem is related on paths because I have also an Android client (using the old xbmc3 addon) that is working fine.
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 (edited) If you launch Emby for Kodi - do you see your Emby user views? If so, are they populated by your Emby content (like in the web client). First we need to validate that the content was actually scanned in correctly. We will start from there to make sure everything is working. Edited June 28, 2015 by Angelblue05
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 I have decided to use path substitution in Kodi do fix the problem of path (if any). I'm using this advanced settings file: <advancedsettings> <packagefoldersize>9000</packagefoldersize> <pathsubstitution> <substitute> <from>\\192.168.0.11\</from> <to>SMB://192.168.0.11/</to> </substitute> </pathsubstitution> </advancedsettings> Actually I'm using SMB since my network server is a Linux server using samba for sharing.
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 (edited) Ok. It is indeed if any, since you didn't have any problem previously. Just have a look when you playback. However back to your actual problem, is your content not populated or it's just the smart playlist that's not working? Let us know, you can you verify following my previous post. Thanks Edited June 28, 2015 by Angelblue05
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 I seems that the problem is on Server Side. Previously the client was working because were available a working db. After the db reset the server is unable to populate the db. Here the related kodi log 12:47:45 T:2612 NOTICE: EMBY Service -> logMsg : Starting Monitor 12:47:45 T:2612 NOTICE: EMBY Service -> logMsg : ======== START EMBY ======== 12:47:45 T:2612 NOTICE: EMBY Service -> logMsg : KODI Version: 14.2 Git:20150326-7cc53a9 12:47:45 T:2612 NOTICE: EMBY Service -> logMsg : EMBY Version: 0.0.32 12:47:45 T:2612 NOTICE: EMBY ConnectionManager -> logMsg : Connection Manager Called 12:47:45 T:2612 NOTICE: EMBY ConnectionManager -> logMsg : Server already set 12:47:45 T:2612 NOTICE: emby 1 -> __init__ : emby Service -> starting playback monitor service 12:47:45 T:2612 NOTICE: emby WebSocketThread -> Log Level:2 12:47:46 T:2612 NOTICE: Not authenticated yet 12:47:46 T:7772 NOTICE: EMBY UserClient -> logMsg : |---- Starting UserClient ----| 12:47:46 T:7772 NOTICE: EMBY UserClient -> logMsg : Returning accessToken from SETTINGS for username: Test accessToken: f7cdd38008ff48ab986a564f819f616b 12:47:46 T:7772 NOTICE: EMBY UserClient -> logMsg : Returning userId from SETTINGS for username: Test userId: 8ad9331b05ce4aada4467c29a4d271f3 12:47:46 T:7772 NOTICE: EMBY UserClient -> logMsg : Returning accessToken from WINDOW for username: Test accessToken: f7cdd38008ff48ab986a564f819f616b 12:47:46 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Set username: Test 12:47:46 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Set userId: 8ad9331b05ce4aada4467c29a4d271f3 12:47:46 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Set server: http://192.168.0.11:8096 12:47:46 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Set token: f7cdd38008ff48ab986a564f819f616b 12:47:46 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Verify SSL host certificate: False 12:47:46 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : SSL client side certificate: None 12:47:47 T:7772 NOTICE: File_Lock_On C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\machine_guid.lock obtained 12:47:47 T:7772 NOTICE: EMBY ClientInformation -> logMsg : ClientId saved to WINDOW: 4A84F9CDF0C24DDB9C2F5AF4A659CC2E 12:47:47 T:7772 NOTICE: File_Lock_On C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\machine_guid.lock released 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Header: {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="8ad9331b05ce4aada4467c29a4d271f3", Client="Kodi", Device="Kodi", DeviceId="4A84F9CDF0C24DDB9C2F5AF4A659CC2E", Version="0.0.32"', 'X-MediaBrowser-Token': 'f7cdd38008ff48ab986a564f819f616b'} 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Requests session started on: http://192.168.0.11:8096 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Sessions?DeviceId=4A84F9CDF0C24DDB9C2F5AF4A659CC2E&format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Session result: [{u'UserName': u'Test', u'DeviceName': u'Kodi', u'ApplicationVersion': u'0.0.32', u'QueueableMediaTypes': [], u'LastActivityDate': u'2015-06-28T10:48:31.6610960Z', u'UserId': u'8ad9331b05ce4aada4467c29a4d271f3', u'SupportsRemoteControl': False, u'Client': u'Kodi', u'SupportedCommands': [u'Play', u'Playstate', u'SendString', u'DisplayMessage', u'PlayNext'], u'AdditionalUsers': [], u'PlayableMediaTypes': [u'Audio', u'Video'], u'PlayState': {u'CanSeek': False, u'IsMuted': False, u'IsPaused': False}, u'Id': u'36070c7f22a7c6858e5457b7936ac46f', u'DeviceId': u'4A84F9CDF0C24DDB9C2F5AF4A659CC2E'}] 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Capabilities URL: {server}/mediabrowser/Sessions/Capabilities?Id=36070c7f22a7c6858e5457b7936ac46f&PlayableMediaTypes=Audio,Video&SupportedCommands=Play,Playstate,SendString,DisplayMessage,PlayNext&SupportsMediaControl=True 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : PostData: {} 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Sessions/Capabilities?Id=36070c7f22a7c6858e5457b7936ac46f&PlayableMediaTypes=Audio,Video&SupportedCommands=Play,Playstate,SendString,DisplayMessage,PlayNext&SupportsMediaControl=True&api_key=f7cdd38008ff48ab986a564f819f616b 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : ====== 204 Success ====== 12:47:47 T:7772 NOTICE: EMBY DownloadUtils -> logMsg : Posted capabilities to sessionId: 36070c7f22a7c6858e5457b7936ac46f 12:47:47 T:7772 NOTICE: EMBY UserClient -> logMsg : Current user: Test 12:47:47 T:7772 NOTICE: EMBY UserClient -> logMsg : Current userId: 8ad9331b05ce4aada4467c29a4d271f3 12:47:47 T:7772 NOTICE: EMBY UserClient -> logMsg : Current accessToken: f7cdd38008ff48ab986a564f819f616b 12:47:47 T:2612 NOTICE: Doing_Db_Sync: syncDatabase (Started) 12:47:47 T:6208 NOTICE: emby WebSocketThread -> WebSocket URL : ws://192.168.0.11:8096/mediabrowser 12:47:47 T:6208 NOTICE: emby WebSocketThread -> Client Starting 12:47:47 T:6208 ERROR: --- request header --- 12:47:47 T:6208 NOTICE: . 12:47:47 T:6208 ERROR: GET /mediabrowser HTTP/1.1 Upgrade: websocket Connection: Upgrade Host: 192.168.0.11:8096 Origin: http://192.168.0.11:8096 Sec-WebSocket-Key: DA5QOZ+GStaDkgt0CgfqgQ== Sec-WebSocket-Version: 13 12:47:47 T:6208 NOTICE: . 12:47:47 T:6208 ERROR: ----------------------- 12:47:47 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: --- response header --- 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: HTTP/1.1 101 Switching Protocols 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: Server: websocket-sharp/1.0 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: Upgrade: websocket 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: Connection: Upgrade 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: Sec-WebSocket-Accept: ujQiZtmskfGmL55hA3fzuES6BgU= 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 ERROR: ----------------------- 12:47:48 T:6208 NOTICE: . 12:47:48 T:6208 NOTICE: emby WebSocketThread -> Opened : {"Data": "Kodi|4A84F9CDF0C24DDB9C2F5AF4A659CC2E|0.0.32|Kodi", "MessageType": "Identity"} 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:48 T:6208 ERROR: send: '\x81\xd8?!j7D\x03.VK@H\r\x1f\x03!X[H\x16\x03~\x19^q\x06b.q\x0fbX\x03{e(\x0e|\x13,\x02~g^v\t\x14St|\x13/K\x0f\x0fZ\x19\x0c\x13\x16|PE\x03\x15\x13\x01HzZR\x19VXD>NODH\r\x1f\x03#SZO\x1e^KXHJ' 12:47:48 T:6208 NOTICE: . 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/Items/Root?format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/items?ParentId=e9d5075a555c1cbc394eec4cef295274&Sortby=SortName&format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 12:47:48 T:2612 NOTICE: Sync Episodes -> TvShowsSync : Finished 0:0 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/Items/Root?format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:48 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/items?ParentId=e9d5075a555c1cbc394eec4cef295274&Sortby=SortName&format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:47:49 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 12:47:49 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:47:49 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/items?ParentId=c8ca023cdbb96c78e4de5fcb477df512&SortBy=SortName&Fields=Path,Genres,SortName,Studios,Writer,ProductionYear,Taglines,CommunityRating,OfficialRating,CumulativeRunTimeTicks,Metascore,AirTime,DateCreated,MediaStreams,People,Overview&Recursive=true&SortOrder=Descending&IncludeItemTypes=Movie&CollapseBoxSetItems=false&format=json&ImageTypeLimit=1&api_key=f7cdd38008ff48ab986a564f819f616b 12:48:02 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 12:48:03 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 12:48:03 T:2612 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.0.11:8096/mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/Items/8fd112373478a90f87f3431e26f53c17/LocalTrailers?format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:48:33 T:2612 ERROR: Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPConnectionPool(host='192.168.0.11', port=8096): Read timed out. (read timeout=30)",)': /mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/Items/8fd112373478a90f87f3431e26f53c17/LocalTrailers?format=json&api_key=f7cdd38008ff48ab986a564f819f616b 12:48:33 T:2612 NOTICE: . 12:48:44 T:1564 NOTICE: Thread JobWorker start, auto delete: true 12:49:03 T:2612 NOTICE: Sync DB -> syncDatabase : syncDatabase Exiting 12:49:03 T:2612 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'requests.exceptions.ConnectionError'> Error Contents: HTTPConnectionPool(host='192.168.0.11', port=8096): Max retries exceeded with url: /mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/Items/8fd112373478a90f87f3431e26f53c17/LocalTrailers?format=json&api_key=f7cdd38008ff48ab986a564f819f616b (Caused by ReadTimeoutError("HTTPConnectionPool(host='192.168.0.11', port=8096): Read timed out. (read timeout=30)",)) Traceback (most recent call last): File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py", line 151, in <module> Service().ServiceEntryPoint() File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py", line 117, in ServiceEntryPoint libSync = librarySync.syncDatabase() File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\LibrarySync.py", line 53, in syncDatabase completed = completed and self.MoviesSync(connection, cursor,True, True) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\LibrarySync.py", line 137, in MoviesSync WriteKodiDB().addMovieToKodiLibrary(item,connection, cursor) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\WriteKodiDB.py", line 675, in addMovieToKodiLibrary jsonData = downloadUtils.downloadUrl(itemTrailerUrl) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\DownloadUtils.py", line 167, in downloadUrl r = s.get(url, params=postBody, timeout=timeout) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 476, in get return self.request('GET', url, **kwargs) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 464, in request resp = self.send(prep, **send_kwargs) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 576, in send r = adapter.send(request, **kwargs) File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\adapters.py", line 424, in send raise ConnectionError(e, request=request) ConnectionError: HTTPConnectionPool(host='192.168.0.11', port=8096): Max retries exceeded with url: /mediabrowser/Users/8ad9331b05ce4aada4467c29a4d271f3/Items/8fd112373478a90f87f3431e26f53c17/LocalTrailers?format=json&api_key=f7cdd38008ff48ab986a564f819f616b (Caused by ReadTimeoutError("HTTPConnectionPool(host='192.168.0.11', port=8096): Read timed out. (read timeout=30)",)) -->End of Python script error report<-- 12:49:16 T:5492 NOTICE: Thread JobWorker start, auto delete: true The problem is on server side but I don't know how to fix it.
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 (edited) Yeah I think you must have been on a later version (0.0.33), after we removed the api key from the query url. This is what's causing the server to fail to answer... However, there were no version drafted for 0.0.33 so I can't give it to you.... I think at this point, you have no choice but to use the latest beta version (1.0.15) and we'll start from there. Steps to follow: Update to the latest Emby for Kodi version, then do a reset database like you did previously. This time however, if you are able to go into %appdata/Roaming/Kodi/userdata/database and delete myvideosxx.db. Start Kodi and let the content sync up. Then your Emby content should show up in Kodi. Edit: I'm sorry you are having this difficulties I will try to help as much as possible...but I have to go soon. Edited June 28, 2015 by Angelblue05
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 I will try to use the last version 1.0.15. I will inform you about the results of my tests as soon as will be completed.
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 Thanks null_pointer Yes that must be it! I wasn't sure if it was just playlist not working or content also not showing.
Dan64 32 Posted June 28, 2015 Author Posted June 28, 2015 Probably I have found the issue, the problem is that now the path stored is something like: plugin://plugin.video.emby/movies/e73b874b2a727ab07cbe4e....0cf I'm able to play the file, but the information on the true path is completely hidden ! 1
Angelblue05 4132 Posted June 28, 2015 Posted June 28, 2015 (edited) Ok so in that case, you have the option to use direct path instead (add-on settings > sync options) - but it will require another sync (just perform local database reset, no need to delete the database file). However using direct paths doesn't give enough control to the add-on to control playback so you will lose out on some emby features like cinema experience, parental control, fall back methods for playback, etc. Another option is to change the rules on your smart playlist to use other filters such as Genres or rating. You could also separate those folders individually in Emby and Kodi will follow suit and divide them for you, in different views. You have many options, so you can get the best out of this experience. It is up to you Glad at least, we have an answer, I'm sorry it took a bit to reach it. Edited June 28, 2015 by Angelblue05
Bernie V 7 Posted December 18, 2015 Posted December 18, 2015 Probably I have found the issue, the problem is that now the path stored is something like: plugin://plugin.video.emby/movies/e73b874b2a727ab07cbe4e....0cf I'm able to play the file, but the information on the true path is completely hidden ! Is there a way to find out what the exactly path is for a music file within Kodi using the Emby addon?
Angelblue05 4132 Posted December 18, 2015 Posted December 18, 2015 Music uses direct path. Either local (smb) or checking the add-on settings > sync option, if Music direct stream is enabled, then it's http.
Bernie V 7 Posted December 18, 2015 Posted December 18, 2015 Music uses direct path. Either local (smb) or checking the add-on settings > sync option, if Music direct stream is enabled, then it's http. Yes, I know but like the TS said it is not possible to create a smart music playlist based on the path in Kodi when using the Emby plugin. Kodi log: 13:03:46 T:2676 NOTICE: EMBY Player -> ONPLAYBACK_STARTED: musicdb://songs/116.mp3 ITEMID: 04a1e5b6e86293380ec5a832a8ab1dba The plugin uses musicdb://songs/ as path for the track and nothing from the original path where the music is stored on disk.
Angelblue05 4132 Posted December 18, 2015 Posted December 18, 2015 Music doesn't work the same way as the video library. The path are either smb or http. If you are not using direct stream for music then it is using direct paths to music. The path you are seeing in log is an internal Kodi path. It's basically just used to find the right info in the database for the song to play. Sent from my iPhone using Tapatalk
