Chuck 17 Posted June 27, 2015 Posted June 27, 2015 After setting channel primary images, local channels and some replacements the defaults, with the metadata manager, the guide refresh seems to be overwriting the metadata and resetting the images to the defaults.
Luke 42245 Posted June 27, 2015 Posted June 27, 2015 well for now at least it's kind of by design. we don't have any way of knowing if the data from the tv providers has changed, so we always just replace. Since EmbyTV is our own, we will have to change that though.
Chuck 17 Posted June 28, 2015 Author Posted June 28, 2015 Thanks! Obviously, not a must have, just a nicety. And, the challenge is definitely understood.
csunflower999 0 Posted May 21, 2019 Posted May 21, 2019 I've just spent 9 HOURS updating all the channels and logos so they are all the same size and the same color (white). Next thing I know, the guide refreshes and wiped out all the work I did. So not ok.
Luke 42245 Posted May 22, 2019 Posted May 22, 2019 I apologize for the issue. This is something we can take a look at and review. Thanks.
