scanner50 8 Posted June 25, 2015 Posted June 25, 2015 I remember with WMC you could hit the green button while playing media and it would take you to the home screen while the media continued to play. I have set up a Logitech Harmony One and would like to know if there is a corresponding Emby Theater command that does the same thing (in addition to hitting the "back" button).
