stereoscopic external player not playing
raymondxcheung@gmail.com
Can anyone help!
Im trying to play Mk3d files using stereoscopic player as an external player, Im also running mpc as external player with madvr running all other movie files. The mpc works perfectly but for some odd reason the stereoscopic player will not run, only the internal player is playing that mk3d file in 2d.
what am I doing wrong?
I have setup the config on emby as external player with path & {path} -termend -nl -ol:AMD
many thanks
