Jeremy Frasier 0 Posted June 21, 2015 Posted June 21, 2015 Hi, as the topic states I have no audio with my live TV stream. The video playback is fine. I have verified I do have audio by opening the same channel in WMC and using the Android app and there is sound on both but still no sound using the Fire TV app. https://docs.google.com/document/d/1hNxEUl6YzIQrOkWzeuFJOZ_EYPET7oSdgDMMLFlsZkk/edit?usp=sharing
ebr 16336 Posted June 21, 2015 Posted June 21, 2015 Sounds like this problem. I believe it is a server or common lib problem and that Luke is aware of it.
Jeremy Frasier 0 Posted June 21, 2015 Author Posted June 21, 2015 (edited) Thanks for the quick response. i saw that thread and didn't know if my problem fit that category. The weird part is I get no transcode log no matter what Bitrate I use. I went back and looked at the transcode log I posted and the time it's from is when I was using my Android phone to watch TV since it has audio. Edited June 21, 2015 by Jeremy Frasier
Jeremy Frasier 0 Posted June 21, 2015 Author Posted June 21, 2015 (edited) Ok... So after some tinkering with the ServerWMC settings, for some reason under the HTTP Service tab the check boxes were checked so I unchecked them, and lowering the Bitrate to 2Mbits I now get this transcode log. https://docs.google.com/document/d/1iiTqkqOWRUov-4AzaWVeA5lL_mE9pmD4ujYTT9n6-oo/edit?usp=sharing does it still sound like I'm in that same catergory? Just trying to make sure so I know what thread to follow for a resolution instead of keeping this one up if there is already one open. Edited June 21, 2015 by Jeremy Frasier
Luke 42243 Posted June 21, 2015 Posted June 21, 2015 i would suggest keeping that setting on as playback will be more reliable. do you get sound on regular videos?
Jeremy Frasier 0 Posted June 21, 2015 Author Posted June 21, 2015 (edited) Yes, I get sound on regular videos. After some more testing, with the HTTP Service off I can only get video and sound at 720Kbits on WIFI and 1.5Mbits Wired. I get no video or sound on any other Bitrate. With the HTTP Service on I get Video on all Bitrates but no sound at all. Also, I only get a Transcode log with the HTTP Service off. Edited June 21, 2015 by Jeremy Frasier
ebr 16336 Posted June 22, 2015 Posted June 22, 2015 It sounds to me like we are direct streaming those streams with an incompatible audio track. So, it only works when you change something else (bitrate) that forces a transcode.
Jeremy Frasier 0 Posted June 22, 2015 Author Posted June 22, 2015 You guys can close this thread then and I'll follow the one in the comment that ebr posted.
Spaceboy 2573 Posted June 23, 2015 Posted June 23, 2015 I think I'm seeing the same symptoms. Recently emby has stopped respecting the default audio track, I'm getting the audio described track all the time
ebr 16336 Posted June 24, 2015 Posted June 24, 2015 I think I'm seeing the same symptoms. Recently emby has stopped respecting the default audio track, I'm getting the audio described track all the time That doesn't sound like the same thing at all...
