Haraldy09 1 Posted June 17, 2015 Posted June 17, 2015 Hello, Is it possible to access my embyserver while traveling (with emby connect), or can i only use it at my homenetwork?
Angelblue05 4132 Posted June 17, 2015 Posted June 17, 2015 (edited) You can use while away. However emby connect is not supported. What you can do right now is create a Kodi profile for remote access and as server address you can have your external IP or dynamic dns, for example. Change add-on settings > playback > Play from HTTP instead of SMB and you can adjust the video quality (if you leave as is, it will direct stream. The lower you go, the more chance there is of transcoding instead of direct streaming) Edited June 17, 2015 by Angelblue05
Haraldy09 1 Posted June 17, 2015 Author Posted June 17, 2015 Thanks for the answer,is it planned to support Emby connect sometime?
Angelblue05 4132 Posted June 17, 2015 Posted June 17, 2015 https://trello.com/c/NGIBVUi4/73-support-emby-connect 2
