I would like to have the current episode I'm watching showing up on the main screen at the moment I am going into TV Shows scrolling to the Shows then playing next unwatched episode from there
Scott84Z28
I think that would depend on the theme you use.  You basically want something with a "next up" or "resume" section.
What theme are you using now?
MB Classic theme
