denethor 90 Posted June 16, 2015 Posted June 16, 2015 (edited) I think I found a bug with 1.0.8 Theme music support. It only happen movies with special characters in their original name. Here is the sample from movie nfo file in movie folder. Notice the ":" moviename.nfo <title>The Hunger Games: Catching Fire</title> <originaltitle>The Hunger Games: Catching Fire</originaltitle> movie.xml <LocalTitle>The Hunger Games: Catching Fire</LocalTitle>This results below log in Kodi during initial "Sync Themes" action.I think Add-on tries to create folder with invalid chars. 21:10:25 T:3312 ERROR: XFILE::CDirectory::Create - Error creating C:\Users\username\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.emby\library\The Hunger Games: Catching Fire\ 21:10:25 T:3312 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.IOError'> Error Contents: (22, "invalid mode ('w') or filename", 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\The Hunger Games: Catching Fire\\tvtunes.nfo') Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 45, in <module> entrypoint.getThemeMedia() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\Entrypoint.py", line 184, in getThemeMedia nfo_file = open(nfo_path, 'w') IOError: (22, "invalid mode ('w') or filename", 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\The Hunger Games: Catching Fire\\tvtunes.nfo') -->End of Python script error report<-- 21:10:25 T:14144 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?mode=thememedia 21:10:25 T:14144 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby/?mode=thememedia) failed 21:10:25 T:14808 NOTICE: Thread LanguageInvoker start, auto delete: false Edit: Functionality looks fine for the synced titles. Playback starts rapidly (theme musics synced with direct play option) and music fades out nicely after scrolling through the other titles in poster view. Edited June 16, 2015 by denethor 1
Angelblue05 4132 Posted June 17, 2015 Posted June 17, 2015 This will be fixed in next version 1.0.09. Thank you for testing! 1
denethor 90 Posted June 18, 2015 Author Posted June 18, 2015 This will be fixed in next version 1.0.09. Thank you for testing! 1.0.9 fixed the issue with ":" but this time It got stuck on movies with "." in their names. This time it was able to create folder in userdata folder. But somehow I cannot delete or modify the contents of folder that created by add-on. I' ve noticed another problem with this movies the original movie file name. It was Monsters Inc..mkv (double .) Now I've renamed the file to "Monsters Inc.mkv". But Add-on sync still fails since the corrupted folder created in the first run. 21:39:48 T:20436 NOTICE: Utils -> Path to Video database: C:\Users\username\AppData\Roaming\Kodi\userdata\Database\MyVideos93.db 21:39:51 T:20644 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.IOError'> Error Contents: (2, 'No such file or directory', 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\Monsters Inc.\\tvtunes.nfo') Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 45, in <module> entrypoint.getThemeMedia() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\Entrypoint.py", line 193, in getThemeMedia nfo_file = open(nfo_path, 'w') IOError: (2, 'No such file or directory', 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\Monsters Inc.\\tvtunes.nfo') -->End of Python script error report<-- 21:39:51 T:19992 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?mode=thememedia 21:39:51 T:19992 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby/?mode=thememedia) failed 21:39:51 T:20732 NOTICE: Thread LanguageInvoker start, auto delete: false
denethor 90 Posted June 18, 2015 Author Posted June 18, 2015 No matter what I did I cannot delete the below folder created by add-on I tried chkdsk, several eraser utilities etc. Non of them worked C:\Users\username\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.emby\library\Monsters Inc.\ 1
Angelblue05 4132 Posted June 18, 2015 Posted June 18, 2015 Oh my, ok. Thanks for reporting again, I will fix this asap. Sent from my iPhone using Tapatalk
denethor 90 Posted June 18, 2015 Author Posted June 18, 2015 (edited) OK found the way to delete it. Oldschool worked once again c:\dir /X get the long file name in a shot name format (MONSTE~2 in this case) c:\rmdir MONSTE~2 Viola! Folder got deleted. Edited June 18, 2015 by denethor
Angelblue05 4132 Posted June 19, 2015 Posted June 19, 2015 Whew ty for this. I will review and push another fix for trailing period as they will break things Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted June 19, 2015 Posted June 19, 2015 @@denethor Ok - Can you give this build a try? All you do is install from zip > restart Kodi and try again. Thank you for helping out on this.
denethor 90 Posted June 19, 2015 Author Posted June 19, 2015 (edited) Ok; this time we have a Mortal Combat style combo hit "." and ":" at time same title I'm warning you @@Angelblue05 I have 2100 titles in my library Add-on couldn' t create a folder in userdata\addon_data 09:01:06 T:6672 ERROR: XFILE::CDirectory::Create - Error creating C:\Users\username\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.emby\library\Dr. Strangelove or: How I Learned to Stop Worrying and Love the Bomb\ 09:01:06 T:6672 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.IOError'> Error Contents: (22, "invalid mode ('w') or filename", 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\Dr. Strangelove or: How I Learned to Stop Worrying and Love the Bomb\\tvtunes.nfo') Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 45, in <module> entrypoint.getThemeMedia() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\Entrypoint.py", line 193, in getThemeMedia nfo_file = open(nfo_path, 'w') IOError: (22, "invalid mode ('w') or filename", 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\Dr. Strangelove or: How I Learned to Stop Worrying and Love the Bomb\\tvtunes.nfo') -->End of Python script error report<-- 09:01:06 T:7304 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?mode=thememedia 09:01:06 T:7304 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby/?mode=thememedia) failed Movie file on file system: "\\hostname\movies\Dr.Strangelove\Dr. Strangelove.mkv" Localtitle tag in movie.xml: <LocalTitle>Dr. Strangelove or: How I Learned to Stop Worrying and Love the Bomb</LocalTitle> Edited June 19, 2015 by denethor 1
Angelblue05 4132 Posted June 19, 2015 Posted June 19, 2015 @@denethor Thank you very much for your patience. Can you try this build? I've tried with the title you've encountered and it was fine. So hopefully it's good this time!
denethor 90 Posted June 19, 2015 Author Posted June 19, 2015 (edited) Now it's time for something even more weird Folder created by add-on. Notice the strange "dot" "c:\Users\username\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.emby\library\WALL·E" 12:00:42 T:9088 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.IOError'> Error Contents: (2, 'No such file or directory', 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\WALL\xc2\xb7E\\tvtunes.nfo') Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 45, in <module> entrypoint.getThemeMedia() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\Entrypoint.py", line 193, in getThemeMedia nfo_file = open(nfo_path, 'w') IOError: (2, 'No such file or directory', 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\WALL\xc2\xb7E\\tvtunes.nfo') -->End of Python script error report<-- 12:00:42 T:9052 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?mode=thememedia 12:00:42 T:9052 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby/?mode=thememedia) failed 12:00:42 T:2288 NOTICE: Thread LanguageInvoker start, auto delete: false File name \\hostname\movies\Wall-E\Wall-E.mkv movie.xml <LocalTitle>WALL·E</LocalTitle> Edited June 19, 2015 by denethor 1
Angelblue05 4132 Posted June 19, 2015 Posted June 19, 2015 (edited) Ok. Back to the drawing board! @@denethor I am very confident that it's good now. Please try with the next version 1.0.10 which should be out soon. Thanks!!! Edited June 19, 2015 by Angelblue05 1
denethor 90 Posted June 19, 2015 Author Posted June 19, 2015 (edited) I am very confident that it's good now. Sorry man, I warned you I have 2100 items to deal with. It won't be finished until I say so Now it's "," and "?"s turn. Add-on couldn' t create a folder in userdata\addon_data File Path "\\hostname\movies\O Brother Where Art Thou" movie.xml <LocalTitle>O Brother, Where Art Thou?</LocalTitle> Error T:9428 ERROR: XFILE::CDirectory::Create - Error creating C:\Users\username\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.emby\library\O Brother, Where Art Thou?\ 19:55:27 T:9428 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.IOError'> Error Contents: (22, "invalid mode ('w') or filename", 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\O Brother, Where Art Thou?\\tvtunes.nfo') Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 45, in <module> entrypoint.getThemeMedia() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\Entrypoint.py", line 193, in getThemeMedia nfo_file = open(nfo_path, 'w') IOError: (22, "invalid mode ('w') or filename", 'C:\\Users\\username\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.emby\\library\\O Brother, Where Art Thou?\\tvtunes.nfo') -->End of Python script error report<-- 19:55:27 T:5268 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?mode=thememedia 19:55:27 T:5268 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby/?mode=thememedia) failed Edited June 19, 2015 by denethor 1
Angelblue05 4132 Posted June 19, 2015 Posted June 19, 2015 (edited) It's ok. We'll get it right. never give up, never surrender! HahAt least, we are doing a little better each time?Edit: Well turns out it would have failed in TV Tunes because we use the exact same filter as TV Tunes and they don't remove "?". I believe the comma is fine but I will have to check out with Rob over at TV Tunes. Edited June 20, 2015 by Angelblue05 1
im85288 1493 Posted June 20, 2015 Posted June 20, 2015 This may be fixed with version 1.0.13 of the emby addon and the latest beta of tv tunes (5.0.1.a) located here: http://forum.kodi.tv/showthread.php?tid=214287&page=14 Please try and report back for Angelblue05 2
denethor 90 Posted June 20, 2015 Author Posted June 20, 2015 I can't get the 1.0.13 update. I also tried to force to Kodi to search for updates. But 1.0.10 is the latest in the report. I also checked the repo xml file,could find the 1.0.13 in there http://cdn.mediabrowser.tv/downloads/addons/xbmb3c/kodi-beta-repo/addons.xml
im85288 1493 Posted June 20, 2015 Posted June 20, 2015 Yes there's something up with the beta repo as no updates have been pushed there since version 1.0.10 Unfortunately it is out of my hands. You could try install from GitHub for now.
denethor 90 Posted June 20, 2015 Author Posted June 20, 2015 (edited) Yes there's something up with the beta repo as no updates have been pushed there since version 1.0.10 Unfortunately it is out of my hands. You could try install from GitHub for now. Yep already the did that. Your were faster than me, I couldn't edit my previous post And @@Angelblue05 you got your good news 1.0.13 and 5.0.1.a solved the problem. And even the video themes working fine. Only annoyance is theme video doesn't stop while you are moving across the library items. Edited June 20, 2015 by denethor 1
im85288 1493 Posted June 20, 2015 Posted June 20, 2015 Yeah I've experienced that occasionally too, be sure to report it in the TV tunes thread as video theme support has only just been added and I think emby users are the only ones testing that feature so he will not get big reports from other users or check this thread 1
