dme 2 Posted June 16, 2015 Posted June 16, 2015 Is there currently a way to change the default max bitrate settings for each user? Some of my friends use my server and I'd rather not have to explain how to change their bitrate settings so they can access all of the direct stream options (my little machine doesn't do well with live encoding). Thanks for your help.
dme 2 Posted June 16, 2015 Author Posted June 16, 2015 (edited) Where might the user configurations be stored? I'd like to run through and change them. Edited June 16, 2015 by dme
