Luke 42239 Posted August 5, 2015 Posted August 5, 2015 that typically means the device doesn't like the format being delivered. so from here it's just trial and error referring to the device's supported formats list, and playing with the direct play and transcoding profiles. This ps4 profile was contributed by a community member, and to my knowledge of a month or so ago it was working nicely, but now i see it needs adjustment.
ilikerolls 0 Posted August 5, 2015 Posted August 5, 2015 that typically means the device doesn't like the format being delivered. so from here it's just trial and error referring to the device's supported formats list, and playing with the direct play and transcoding profiles. This ps4 profile was contributed by a community member, and to my knowledge of a month or so ago it was working nicely, but now i see it needs adjustment. Luke, just to be clear this was only after I created a modified profile. It transcodes and plays fine with no modifications. I was only trying to get Fast forward and Rewind to work and from my understanding in reading this post that was because it couldn't find the profile to do "Direct Play". Did I misunderstand this post?
Luke 42239 Posted August 5, 2015 Posted August 5, 2015 You might be right, I just don't have a PS4 to test and verify with.
ilikerolls 0 Posted August 5, 2015 Posted August 5, 2015 ah OK I guess this is beyond me at this point. There is a good chance it is just PS4's crappy Media Player too. I wouldn't be surprised if that was the issue either. Sounds like Plex has the same issue. Let me know if there is anything I can test. I am not an expert at all in video or Emby, but know where the profiles are and have developer and sys admin experience.
Luke 42239 Posted August 5, 2015 Posted August 5, 2015 In the profile you can try upping the bitrate limits to the maximum supported by your device and your network. Doing that will increase the likelihood of direct streaming which will at least help make it more tolerable.
ilikerolls 0 Posted August 6, 2015 Posted August 6, 2015 FYI you need to change your PS4 profile to search for http headers User-Agent -> (PlayStation 4) -> substring or it can't find the profile and goes to the default. Still even when it finds the profile I can't get it to direct stream.
Luke 42239 Posted August 6, 2015 Posted August 6, 2015 am i missing something because it looks like it already has that. <Identification> <FriendlyName>PLAYSTATION 4</FriendlyName> <Headers> <HttpHeaderInfo name="User-Agent" value="PLAYSTATION 4" match="Substring" /> <HttpHeaderInfo name="X-AV-Client-Info" value="PLAYSTATION 4" match="Substring" /> </Headers> </Identification>
ilikerolls 0 Posted August 7, 2015 Posted August 7, 2015 Luke, I know I saw that too, but I have tested this over and over. The only thing I could think of is it maybe case sensitive? Ahh you know what I didn't think about this before, but I bet it has to do with the fact that I am running it on Linux and not Windows. Maybe in Windows it is not case sensitive. None the less you should change it to "PlayStation 4" for the Linux users. Here is a sample line from my logs. Ip: 192.168.1.111:50268. Headers: Host=192.168.1.70:8096,User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/2.57 (PlayStation 4),Connection=Keep-Alive2015-08-05 13:14:56.4665 Debug - HttpServer: HTTP Response 200 to 192.168.1.111. Response time: 0.881 ms. Even when it picks up the profile it still gets that error though. It still plays just not directplay and without FF/RW.
Luke 42239 Posted August 7, 2015 Posted August 7, 2015 except the comparison is case insensitive so that really shouldn't matter, unless the comparison isn't working but then i imagine a lot would break.
ilikerolls 0 Posted August 8, 2015 Posted August 8, 2015 except the comparison is case insensitive so that really shouldn't matter, unless the comparison isn't working but then i imagine a lot would break. That I cannot answer. I can tell you it definitely made a difference on my Linux box for the PS4 profile. As I spent a couple hours trying to get that profile to work. And it would say in the logs that it would find the profile with it as "PlayStation 4" and default to the "default profile" as "PLAYSTATION 4". Maybe it is something strange when Emby is run with Mono in Linux that the substring comparision becomes case sensitive? I don't have Emby setup on my Windows machine unfortunately, so couldn't test that theory. Shooting in the dark on that one without seeing the code.
kaspar_k 0 Posted December 14, 2015 Posted December 14, 2015 Installed emby to my iMac and tried to stream to my PS4. It playes everything really nicely, except it doesn't play audio for MKV files. Does anyone know a solution to this?
Jonz 11 Posted December 29, 2015 Posted December 29, 2015 PS4 DLNA doesn't work for me. Would not even play any files. Anybody has a DLNA profile that is working? DLNA working on my LG TV though.
Sp3kt3r 13 Posted January 14, 2016 Posted January 14, 2016 I have the same issue. most of my file doesn't work on the PS4... it's not even working enough to be able to use it The PS4 is really weak in term of codec so I don't except direct stream but would be happy with transcoding.
Luke 42239 Posted January 14, 2016 Posted January 14, 2016 Installed emby to my iMac and tried to stream to my PS4. It playes everything really nicely, except it doesn't play audio for MKV files. Does anyone know a solution to this? It's probably direct streaming them when it shouldn't. Can you give an example?
Sp3kt3r 13 Posted January 15, 2016 Posted January 15, 2016 Does any body have a DLNA profile tweaked for PS4 ? I read on the Universal Media Server that transcoding work fine with PS4 but I don't really want to install another media server. Emby is best !!! I'm going to try to play with some setting but i'm not a pro at transcoding setting. Most of my movie keep saying AUDIO not supported (DTS) and I know the PS4 doesn't decode DTS from file (only from bluray disc)
Luke 42239 Posted January 16, 2016 Posted January 16, 2016 Did you customize the profile? because looking at the default ps4 profile that we're providing, there's no way it would just pass DTS straight through without re-encoding. Or maybe it doesn't like the transcoded audio?
Sp3kt3r 13 Posted January 17, 2016 Posted January 17, 2016 Hi Luke No I haven't modify the profile. I was going to but everything seems right. I think Emby doesn't initiate the transcoding or the PS4 doesn't like it. Here's the step I"m doing Turn on PS4 Open the Media Player Apps Wait until Emby is detected (about 15 second) Browse my library Start a movie (loading circle show up) Movie start with audio (movie with ac3 audio) While moving playing, look at my server dashboard for server activities and don't see anything Start another movie but this time with DTS audio (not supported) and I still don't see any server activities I also noticed that some of my movie are playing as a playlist, I can't go forward or backward, I can only click next for next file.. (there's no running time, I only see 4/50) why I'm saying like a playlist.
Luke 42239 Posted January 17, 2016 Posted January 17, 2016 it is transcoding then. if you can post a transcoding log then we can at least see what format is being delivered to the player. thanks.
Sp3kt3r 13 Posted January 17, 2016 Posted January 17, 2016 will do ! but if it's transcoding, how come I don't see my PS4 connected to Emby under the dashboard (beside ACTIVE DEVICE) ? I usually see the image of the movie playing with the logo DLNA at least it does that on my other DLNA device.
Luke 42239 Posted January 17, 2016 Posted January 17, 2016 at the moment devices only display there if they support both play to and the dlna server.
Sp3kt3r 13 Posted January 17, 2016 Posted January 17, 2016 Ah i didn't know that I'm going to clear my log and do a fresh test. I found a movie that doesn't even play with ac3 and the ps4 is compatible with ac I have no issue with universal media server but don't want to use it lol I'm a emby fan. They also use ffmpeg for transcoding so it must be just something small.. I'll be back in a few minute
Sp3kt3r 13 Posted January 17, 2016 Posted January 17, 2016 (edited) Here's my transcoding log. This movie start but with no audio and it has AC3 which is supposed to be compatible As per the log it tried to use mp3 which is fine so don't really understand why the ps4 doesn't read it ? Actually it shouldn't even transcode everything is compatible with the PS4. With Universal Media Server it direct play. transcode-974ee757-7ac8-46c7-bc6d-122a2a895532.txt Edited January 17, 2016 by Sp3kt3r
Happy2Play 9811 Posted January 17, 2016 Posted January 17, 2016 Have you tried a custom PS4 profile and changing the bitrate limit, since it is set to 10mb? "BitRate":10609161 -b:v 9680000
