millsii 8 Posted June 13, 2015 Posted June 13, 2015 Hi, I am having an issue with the correct profile be set for our Samsung TVs. From looking at the log t appears to recognise and set the correct profile, then straight after not recognise the device and set the Generic profile. 2015-06-13 14:27:06.8339 Debug - Dlna: Found matching device profile: Samsung Smart TV2015-06-13 14:27:06.8495 Info - Dlna: DLNA Session created for Samsung D6600 - UA46D66002015-06-13 14:27:08.4745 Debug - HttpServer: HTTP GET http://192.168.1.102:8096/dlna/08b635a538630b25018535845cfd24a9/description.xml Ip: 192.168.1.103:52295. Headers: HOST=192.168.1.102:8096,USER-AGENT=SEC_HHP_Samsung D6600/1.0,ACCEPT-LANGUAGE=en-us2015-06-13 14:27:08.4901 Debug - Dlna: No matching device profile found. The default will be used.2015-06-13 14:27:08.4901 Debug - HttpServer: HTTP Response 200 to 192.168.1.103. Response time: 15.6252 ms. After the above, there is recurring error reports. Log attached from when TV is turned on. Any thoughts? Server Log.txt
CBers 7554 Posted June 13, 2015 Posted June 13, 2015 Have you tried the Samsung Smart TV app? http://emby.media/community/index.php?/topic/9869-samsung-smart-tv-app-install-instructions/ Might be worth a try.
millsii 8 Posted June 15, 2015 Author Posted June 15, 2015 Yep, have already used the Samsung app and it works well. Was just hoping to keep it simple by accessing directly through sources.
