MALLINDER 10 Posted June 13, 2015 Posted June 13, 2015 Sure its a quick fix, using emby inside windows media center 7. New to this but got most of it working, woundering once I have watched one of my recorded tv episodes how do I delete it ? Searched round, found something about the xml file, so edited that but still cant find a delete option within emby / windows media center. Any ideas ?
MALLINDER 10 Posted June 13, 2015 Author Posted June 13, 2015 Got the actions window to open whcih has a delete option in it, but now it has dissapeared, if I right click or press the "info" button on the remote I get the internet security or settings options and no the action box with the delete option.
ebr 16334 Posted June 13, 2015 Posted June 13, 2015 You have to enable delete capability for the user on the server. Then you should get delete options inside EMC (on the detail page, in the context menu or just by hitting the 'clear' button on your remote).
