pelfed 5 Posted June 12, 2015 Posted June 12, 2015 Hi All I have just moved over to a new PC (windows 7 64 bit), so am having some issues. My older PC (windows 7 32 bit), Was working great (albeit a bit slow) and had no issues regarding the below. Basically, I have a TV series that is in FLV format and it plays great on the Main PC Server within Emby Classic. However, on the ROKU, playing the FLV doesn't work. When I click play it looks as if it is loading, but then just kicks me back to the 'play' screen. The strange thing is this was working and does work and plays great within ROKU using my OLD PC Emby server? Attached log file. Log.txt
pelfed 5 Posted June 12, 2015 Author Posted June 12, 2015 (edited) there is no log file (transcoding debug is on) created. thus i think there is an issue within emby server. here is the debug from the actual ROKU: Button command: playNot sure what to do with breadcrumbs on screen type: InvalidPushing screen 4 onto view controller stack - Video PlayerMediaPlayer::playVideo: Displaying video: Episode 46Getting metadata for Id 89189524f5b6c391c6063d8638b9d7ccMedia item container: flvMedia item video codec: h264Media item audio codec: aacMedia item subtitles: invalidMedia item stereo codec: aacMedia item surround codec: invalidSecondary audio stream selected: falseSetting PlayStart to 0Starting to play transcoded videoVideo status: 0 0Video status: 0 0MediaPlayer::playVideo::VideoScreenEvent::isRequestFailed - message =MediaPlayer::playVideo::VideoScreenEvent::isRequestFailed - data = 1MediaPlayer::playVideo::VideoScreenEvent::isRequestFailed - index = -5MediaPlayer::playVideo::VideoScreenEvent::isScreenClosed: position -> 0Sending message to server to stop transcodingPopping screen 4 and cleaning up 0 breadcrumbsTop of stack is once again: VideoSpringboardScreen89189524f5b6c391c6063d8638b9d7 Edited June 12, 2015 by pelfed
pelfed 5 Posted June 12, 2015 Author Posted June 12, 2015 is there any reason why transcoding doesn't start?
Solution Luke 42184 Posted June 12, 2015 Solution Posted June 12, 2015 i'll make sure this is handled when the current beta goes stable. in the meantime, just ensure the following directory is created and i think it will go away C:\Users\User\AppData\Roaming\Emby-Server\transcoding-temp 1
