Erik 124 Posted November 20, 2013 Posted November 20, 2013 Just a request for the future (as there are more important things), but can the metro start menu icon be made so that it can enlarged. Only small and medium are selectable at the moment, but as we sit back from the tv it's great to have them larger so you can see your selection easier. Thanks.
Erik 124 Posted November 20, 2013 Author Posted November 20, 2013 Windows start menu icon. there are 4 sizes and the MBT icon can only be as big as the internet explorer one in the example below. It would be great if I could increase the size to the same as the weather one.
Solution ScottIsAFool 517 Posted November 20, 2013 Solution Posted November 20, 2013 The four sizes only apply to Windows Store apps. MBT isn't a Windows Store app, it's a regular desktop app, so it can only have the one tile size. 1
gthrift 66 Posted November 20, 2013 Posted November 20, 2013 Customize your own. http://mediabrowser.tv/community/index.php?/topic/2011-customize-your-windows-8-start-screen-tiles/
swhitmore 781 Posted November 20, 2013 Posted November 20, 2013 There is a WinRT app on the way that will have live tile support. It flips to show the latest movie/tv show. 2
