scalda 69 Posted June 11, 2015 Posted June 11, 2015 As the title says, i really miss these messages as it showed me when a connection is reestablished i.e when i reset the server. I found them to be really useful. Regards scalda 2
Angelblue05 4132 Posted June 11, 2015 Posted June 11, 2015 (edited) Ok, I'll look to make it optional again. What I did was only show in the event the server is or becomes offline. Then it will show when it comes back online. Edited June 11, 2015 by Angelblue05
CBers 7554 Posted June 11, 2015 Posted June 11, 2015 Also, in the same vein, can messages NOT be displayed when playback is happening ?? Sometimes you get an incremental sync message when you're watching something. 1
im85288 1493 Posted June 11, 2015 Posted June 11, 2015 As the title says, i really miss these messages as it showed me when a connection is reestablished i.e when i reset the server. I found them to be really useful. Regards scalda Lol, that's exactly what I said to @@Angelblue05 - when she changed the logic. 2
Angelblue05 4132 Posted June 11, 2015 Posted June 11, 2015 It is known I will reinstate it for the next version with the option to disable it for people who do not wish to see it... I just wanted to simplify things...., because I thought people didn't like my message or found it annoying!! haha >.> 1
CBers 7554 Posted June 11, 2015 Posted June 11, 2015 It is known I will reinstate it for the next version with the option to disable it for people who do not wish to see it... I just wanted to simplify things...., because I thought people didn't like my message or found it annoying!! haha >.> Is that DISABLE, or ENABLE depending if it's TRUE or FALSE :D :D 1
Angelblue05 4132 Posted June 11, 2015 Posted June 11, 2015 (edited) lolol. It will be the correct logic! Don't worry! @@scalda Are you ok with displaying Welcome "user" message instead? It is the same as "Server online", it only displays in the event we were able to connect to the server when starting Kodi. Edited June 11, 2015 by Angelblue05 1
