JeremyFr79 228 Posted June 11, 2015 Posted June 11, 2015 I found tonight that Emby for Android is not adhering to the bitrate set in the app. For instance tonight I tested some LiveTV content, the app showed that it was set for 720p 1.5mbps, However the server showed it was transcoding it at 8mbps. I was able to verify this was the case by watching the throughput on my router. Anyone else seeing this ( or even realizing it's happening for that matter) This is a huge issue if you're on 3g/4g connection without unlimited data.
Luke 42242 Posted June 11, 2015 Posted June 11, 2015 i've tested and couldn't repro but i will keep an eye out for it.
JeremyFr79 228 Posted June 12, 2015 Author Posted June 12, 2015 i've tested and couldn't repro but i will keep an eye out for it. hmmm weird, I will try with other content, I'm wondering if it's just LiveTV that has the issue, For now I'm no longer watching content unless on WiFi until I can get this figured out. I thought server maybe was just reporting incorrectly, but like I said was able to verify on my PFSense box that was in fact the bandwidth it was sending out.
JeremyFr79 228 Posted June 12, 2015 Author Posted June 12, 2015 ok, now it's working, I dunno............nevermind I guess, if I see it pop up again I'll pull logs and let ya know.
