NANO SHELL 13 Posted June 10, 2015 Posted June 10, 2015 As of a few days ago I have not been able to reach my Emby Server outside of my own network. I have been able to previously for a while then it just stopped. When ever I try to log into my server outside my network whether it be Android app, Android chrome or chrome on windows 7 and mac, I have been getting the same message; "Connection Failure - We're unable to connect to the selected server right now. Please ensure it is running and try again." I have tried deleting the server and creating a new one to log into but the same thing happens. I have also double and triple checked my port forwarding settings and cross reference my IP address with the port forwarding. Running my Server on Windows 7 Ultimate x64 Emby Server Version 3.0.5621.4 Chrome Version 43.0.2357.124 m Mobile Chrome Version 43.0.2357.92 Emby Version 2.2.96 Any help would be great as this is doing my head in. Thanks
NANO SHELL 13 Posted June 10, 2015 Author Posted June 10, 2015 As far as I can tell it is OK looking at windows firewall but I may be looking in the wrong area. Looks like it is allowing port 8096,8920 and both "media browser.server application.exe". I also use Eset smart security but is past trial period and seems they have removed firewall setting.
Luke 42184 Posted June 10, 2015 Posted June 10, 2015 yea with two firewalls i'm sure that is the area to focus on.
NANO SHELL 13 Posted June 10, 2015 Author Posted June 10, 2015 I will uninstall Eset when I get home. Or are you talking about the double mediabrowser.serverapplication.exe? I haven't touched any of it before hand and it was all working previously.
NANO SHELL 13 Posted June 11, 2015 Author Posted June 11, 2015 So after uninstalling ESET completely EMBY still refuses to connect, giving me the same 'Connection Failure' message. So I went a bit further and turned Windows Firewall off completely and it still isn't working. The odd thing is I can still access my PC remotely (outside my network) using other apps such as Vuze Remote, Remote Mouse and Team Viewer. Could it be possible it is something to do with updating to a newer version of Emby? Not too sure when Emby updated last. First noticed this issue about the 4th June.
Nick's MCE 59 Posted June 11, 2015 Posted June 11, 2015 Hi Yep, mine was also working fine then stopped and get the same message, it also started about the 4th June. Driving me nuts any help appreciated.
NANO SHELL 13 Posted June 13, 2015 Author Posted June 13, 2015 The issue seems to have been fixed after both server and the android app updated to yesterdays update. Cheers for the help.
Nick's MCE 59 Posted June 13, 2015 Posted June 13, 2015 ok, so up-dated my server and downloaded the app today, but still cant connect unless on my home network. I know the whole system is great and I luv it but sometimes I wish they would just stop tinkering. I will screw around with it for a days and see what happens. Later
NANO SHELL 13 Posted June 13, 2015 Author Posted June 13, 2015 Probs going to be easier for you to start a new topic with specs and what is what on your PC. All the best 1
Nick's MCE 59 Posted June 13, 2015 Posted June 13, 2015 Thanks, I have fiddle around and start a new topic if I get nowhere. Nicks
