ramrod215 6 Posted October 16, 2015 Posted October 16, 2015 I have the Chromecast 2.0 connected via 5gz band AC and i also get the not disconnecting bug. I am chalking it up to an old android verison will test with 5.0 in a week when the nexus shows up. Feature request (prob wrong section): A notification widget like logitech harmory/google music one. Without having to pop back in the app to pause or resume playback. Amazing work with the app so far and thank you for spending your free time making it great!
Luke 42244 Posted October 16, 2015 Posted October 16, 2015 I have the Chromecast 2.0 connected via 5gz band AC and i also get the not disconnecting bug. I am chalking it up to an old android verison will test with 5.0 in a week when the nexus shows up. Feature request (prob wrong section): A notification widget like logitech harmory/google music one. Without having to pop back in the app to pause or resume playback. Amazing work with the app so far and thank you for spending your free time making it great! There is already notification bar control for Chromecast and any remote control client, but currently only if you're running android 5.0+. 1
ramrod215 6 Posted October 17, 2015 Posted October 17, 2015 Awesome can't wait till I get my nexus 5x to use it. Currently running with a iPhone 6s so I keep my old phone (droid maxx) on the couch for playing with chromecast/Android app. Normally I stick with the roku 3 for being the best non-pc viewing of emby (due to being hardlined and direct streaming). Awaiting the drop of the new emby theater!
AxelAxel3 23 Posted November 4, 2015 Posted November 4, 2015 My phone still absolutely doesn't do anything to Chromecast other than play it. I can't pause it from the app, the notification drawer, can't use any volume controls, and I can't even stop it without casting over it or rebooting Chromecast. When I hit home and go back to the app, emby acts like nothing is playing, not connected to Chromecast, and the notification goes away. App: 2.4.30 Server: 3.0.5724.6 Any update one this? Still having all the issues listed...
techbullies 1 Posted November 11, 2015 Posted November 11, 2015 downloaded the Android App on my S6 Last night and was able to cast from my Server to Chromecast fine today. i hit play and it just sits there on chromecast (emby casting screen) factory reset chromecast restarted my server (emby software and physical server) restarted my router/network Verified Chromecast DOES work from every other source, just not Emby no use it keeps just sitting there.
techbullies 1 Posted November 11, 2015 Posted November 11, 2015 Nevermind, I figured it out. Physical Servers IP was reset on one of my Twin Bonded NIC ports. 1
Guest Econaut Posted April 21, 2019 Posted April 21, 2019 This still very much a bug. I've been able to Chromecast 1 in 30 times at best. Is there any reliable solution to this? I've already rebooted and updated everything.
Luke 42244 Posted April 21, 2019 Posted April 21, 2019 This still very much a bug. I've been able to Chromecast 1 in 30 times at best. Is there any reliable solution to this? I've already rebooted and updated everything. Hi there, can you please describe what happens? Thanks.
Guest Econaut Posted May 14, 2019 Posted May 14, 2019 (edited) Hi there, can you please describe what happens? Thanks. In short, not much. I go to cast and it looks like it's going to but then instead of playing, it removes the media playback/chromecast bar and I'm just where I started. After some more reading, it seems like this might be the chromecast not accepting my self signed cert (and HTTPS is forced in emby). Last time I tried to use Let's Encrypt which everyone says is easy, it was an abysmal failure and didn't work. Is there a good/updated guide that makes it easy and doesn't require having some web server? Edited May 14, 2019 by Xen0sys
Luke 42244 Posted May 14, 2019 Posted May 14, 2019 In short, not much. I go to cast and it looks like it's going to but then instead of playing, it removes the media playback/chromecast bar and I'm just where I started. After some more reading, it seems like this might be the chromecast not accepting my self signed cert (and HTTPS is forced in emby). Last time I tried to use Let's Encrypt which everyone says is easy, it was an abysmal failure and didn't work. Is there a good/updated guide that makes it easy and doesn't require having some web server? Yes most likely Chromecast does not trust the certificate. If you want to use https, you'll need to use one that your Chromecast receiver will trust.
Guest Econaut Posted April 2, 2020 Posted April 2, 2020 (edited) Frankly, I gave up because it's way too difficult to set up a certificate that could be trusted. Plex just works Edited April 2, 2020 by Xen0sys
Luke 42244 Posted April 4, 2020 Posted April 4, 2020 Frankly, I gave up because it's way too difficult to set up a certificate that could be trusted. Plex just works Well they create a domain name of their own that resolves to your personal ip address, so I guess you can go that route if that's OK with you. Alternatively you could still use Emby and do one of the following: Use the web app on localhost Use the emby android app Use the emby iOS app
