im85288 1493 Posted August 18, 2015 Posted August 18, 2015 I think you might need the opposite.. Anyway I don't know anything about NFS either. @@im85288 - do SRT subs work for you? You using NFS? I do use NFS but never use subtitles, anyway looks like the problem was solved
xnappo 1611 Posted August 18, 2015 Posted August 18, 2015 @@FlyGuy94 - how are your paths specified on the server?
FlyGuy94 6 Posted August 19, 2015 Posted August 19, 2015 @xnappo /volume1/video/movies /volume1/video/tv video is a smb share
xnappo 1611 Posted August 19, 2015 Posted August 19, 2015 Okay, that is the root problem I think. We don't know from that that '/' needs to have 'nfs://' as a prefix. @@im85288 @@Angelblue05 - any insight?
FlyGuy94 6 Posted August 19, 2015 Posted August 19, 2015 Its a xpenology server btw but emby runs in a docker container on the xpenology server.
olerocker 8 Posted August 19, 2015 Posted August 19, 2015 Hi guys, I have openelec setup with the Emby plugin. When I am home everything works ok, subtitles and all. When I use the same system remotely, even though I have "playback through http" enabled I get no subtitles shown (.srt) The Emby version is 1.1.34 I think, and I do see that it comes over as a direct stream with no transcoding. I can't seem to find the option of always display subtitles in the addons configuration panel, am I doing something wrong? Thanks,
xnappo 1611 Posted August 19, 2015 Posted August 19, 2015 Correct - there is no way (that I know of) for SRT to work over HTTP streaming - Kodi need to be able to 'see' the .srt in a directory.
olerocker 8 Posted August 19, 2015 Posted August 19, 2015 There is no way then to have external subtitles when using the Emby addon remotely ?
xnappo 1611 Posted August 20, 2015 Posted August 20, 2015 Maybe if you set a default language on the server and force transcoding? @@Angelblue05?
Angelblue05 4132 Posted August 20, 2015 Posted August 20, 2015 I don't know how Emby handles external subtitles. If it's available in the subtitles list before transcode playback starts then there's a good chance it will work. Again, you'd think direct stream would work, however it's not the case so I'm unsure if transcoding will be the same. Only testing will tell. External subs are a pain, because it's not integrated in Kodi in a way we can control.
olerocker 8 Posted August 20, 2015 Posted August 20, 2015 External subtitles work when you use the web browser remotely, can't they be handled the same way through the kodi addon?
xnappo 1611 Posted August 20, 2015 Posted August 20, 2015 How do you specify which subs you want through the web interface? Is it be playback item, or just anytime audio is in a language other than X and subtitle X is available, provide them? xnappo
olerocker 8 Posted August 21, 2015 Posted August 21, 2015 When you click on an episode in the web browser a media info box shows up giving detailed information about the video. It shows codecs, audio, path of the file, and subtitles. When you press play, a small menu bar shows up and let's you choose audio track, bitrate, and subtitle track. There is also an option in the player the web browser uses to choose your subtitle.
xnappo 1611 Posted August 21, 2015 Posted August 21, 2015 I think this should be possible. I added it to our Trello board here: https://trello.com/c/RL0jjiB7/136-add-optional-listbox-of-available-external-subs-when-transcoding-append-selection-to-stream-request
Angelblue05 4132 Posted August 21, 2015 Posted August 21, 2015 (edited) @@xnappo , it is already in place. I added this like a month ago. As I said, it should be part of the list I already present before playback starts. It grabs every track reported by emby. However I don't use external subs myself so that's why I said the user needs to test and validate the srt is available for transcoding in Kodi. Sent from my iPhone using Tapatalk Edited August 21, 2015 by Angelblue05
xnappo 1611 Posted August 22, 2015 Posted August 22, 2015 So I don't understand what you mean. If you haven't tested this, how is it supposed to work? Kodi is not going to come into play at all. The only way this will work is if you detect external subs are available during a transcoding playback attempt, then present a list of available external subs, then append that sub choice to the transcode URL. Are you saying you are doing that but no one has tried it? Thanks, xnappo
Angelblue05 4132 Posted August 22, 2015 Posted August 22, 2015 (edited) @@xnappo Here's what I'm talking about - when transcoding you'll get the option to preselect the audio and subtitles track. If the srt is part of that list, then it should work... I've tested with internal subs, but I don't have external subs to validate this aspect. I simply assumed Emby reports the srt as a track and is able to burn it into the video if you select it: Yes, no one has really reported on the feature, because I'm guessing very few people actually transcode using Kodi but it is there. It's been working as far as I've tested (I just can't say for external subs since I don't have any). Edited August 22, 2015 by Angelblue05 1
xnappo 1611 Posted August 22, 2015 Posted August 22, 2015 Okay - so this is EXACTLY what I was thinking was needed - so... @@olerocker is it working or not? 1
olerocker 8 Posted August 22, 2015 Posted August 22, 2015 (edited) Hi guys, That list doesn't show up for me. I am using 1.1.34 version of the addon. When I press play it says opening stream and goes straight to play. Direct stream. I am using the http option in the playback tab. Edited August 22, 2015 by olerocker
Angelblue05 4132 Posted August 22, 2015 Posted August 22, 2015 (edited) To transcode, lower your video quality bitrate in the settings. Edited August 22, 2015 by Angelblue05
Angelblue05 4132 Posted August 22, 2015 Posted August 22, 2015 (edited) No, unfortunately. Direct play = Kodi needs to see inside your directories to load the external subtitles. Only works if you use direct paths instead of plugin paths, so you'd need to enable the option in the add-on settings and reset your library. Direct stream = Emby streams the file to Kodi without modifications. There is no way to make it append external subtitles to the file. @@Luke Is it something that would be possible? Transcoding = Emby streams the file to Kodi with modifications. Therefore if it's possible, it will burn the external subtitles in the video and you'll see it in Kodi. I suppose we could add a transcoding option without having to degrade the bitrate. Either way, you have two(three) options: use direct paths or transcode the content. Or merge your subs into your files. There is probably a software that will do this for you in bulk, but I'm no expert. @@olerocker Edit: Actually couldn't you just browse to the subtitles? Edited August 22, 2015 by Angelblue05
olerocker 8 Posted August 22, 2015 Posted August 22, 2015 (edited) I can't browse to the subtitles because i connect remotely through a dynamic DNS account. So no directory browsing. How does the web client manage this? It works fine through dynamic addresses. Edited August 22, 2015 by olerocker
xnappo 1611 Posted August 22, 2015 Posted August 22, 2015 Please try lowing the bitrate setting and see if it works. We could do something to force transcoding, but try it and make sure it works with srt when it does transcode please.
