Nick's MCE 59 Posted November 19, 2013 Posted November 19, 2013 Hi Just wondering if anyone has a psd for discs which work with ROC and Crystal. I have been using the one from the boxset PSD but it creates a disc which is 340 x 340 with a huge center hole which takes up a lot of the artwork and also has a large clear background to take up the shadowing around the disc. What is needed is something 1000 x 1000 with a small center hole and is full size to the edge, hope that makes sense. Sorry, I am psd challenged, thanks in advance if anyone can help. Thanks
Casper 29 Posted November 19, 2013 Posted November 19, 2013 http://mediabrowser.tv/community/index.php?/topic/1676-diy-fan-art-for-photoshop/ Hope this helps.....
Nick's MCE 59 Posted November 19, 2013 Author Posted November 19, 2013 Thanks for this it will save me heaps of time, however it still has the huge clear ring. Is this a layer I can remove. if you see the discs which are automatically downloaded from fan art they don't have the extra ring, I am trying to match this to keep all my discs the same. Thanks in advance if you can help.
shaefurr 1340 Posted November 19, 2013 Posted November 19, 2013 I'm a bit confused on the center part, you dont want the clear ring and just a smaller hole instead? Is it like this? http://4.bp.blogspot.com/-QwUSg47ApA4/UevH5DmlsRI/AAAAAAAAFPc/Xd2X1N9phDg/s1600/Lady+GaGa+-+The+Fame+-+CD+Disc.png
shaefurr 1340 Posted November 19, 2013 Posted November 19, 2013 (edited) Try this Download the zip here: http://www.mediafire.com/?sdjyrdmcqwsbw2l Extract it to the root of your C: ie: C:\DISC MAKER I made 2 droplets, one for using backdrops, and another for using folder images Then just drop a backdrop.jpg onto the backdrop DISC maker, or a folder.jpg onto the folder DISC maker. The disc.png will be in the same folder once its done. The disc.png is 1000x1000 Backdrop example: Folder example: Edited November 19, 2013 by shaefurr 1
Nick's MCE 59 Posted November 20, 2013 Author Posted November 20, 2013 Hi Ok this is exactly what I want but I am having trouble getting it to run, I tried dropping the images in put I am getting a message saying the command promp is not correct. I apologize in advance for being a novice!. I put it in the root folder where my other actions are, usually I run the action and it shows up in photo shop on the right hand side. I then open an image and crop it square then go insert image and save image and it shows up in the output folder, (its like magic). Is there something else I should be doing Thank you for all the help! Nick
shaefurr 1340 Posted November 20, 2013 Posted November 20, 2013 (edited) Hi Ok this is exactly what I want but I am having trouble getting it to run, I tried dropping the images in put I am getting a message saying the command promp is not correct. I apologize in advance for being a novice!. I put it in the root folder where my other actions are, usually I run the action and it shows up in photo shop on the right hand side. I then open an image and crop it square then go insert image and save image and it shows up in the output folder, (its like magic). Is there something else I should be doing Thank you for all the help! Nick This is only based off the droplet not an action, so just take the DISC MAKER folder and put it in the root of the C: (needs to be in the location C:\DISC MAKER) then you can just drop an image on either of the droplets and it should run. Here's a quick vid on how to use it: : Edited November 20, 2013 by shaefurr 2
Nick's MCE 59 Posted November 20, 2013 Author Posted November 20, 2013 Hi Thanks for this, I had the folder in the wrong place but I now got it to work, and the disc format is exactly what I need. The only last thing is, can I position the image to get it in the right spot. Thanks Nick
shaefurr 1340 Posted November 20, 2013 Posted November 20, 2013 (edited) Hi Thanks for this, I had the folder in the wrong place but I now got it to work, and the disc format is exactly what I need. The only last thing is, can I position the image to get it in the right spot. Thanks Nick Not unless you just use the template and do it manually. I have it centered and shrunk down the best I can so it will fit inside the disc constraints, but because of the dimensions of the backdrop/folder.jpg Its just going to get cut in certain areas, some discs will look fine and others won't depending on the image you use. I'm not sure how "novice" you are in Photoshop, but here's a quick vid on how to use the template and cut an image onto the disc. Once you know how it works you can make a disc in like 15 seconds. : Edited November 20, 2013 by shaefurr 1
manny 14 Posted December 17, 2013 Posted December 17, 2013 @@shaefurr, thanks for the link and vids ..... even I can make discs now!
shaefurr 1340 Posted December 17, 2013 Posted December 17, 2013 Glad it helped Sent from my XT907 using Tapatalk
Nick's MCE 59 Posted December 30, 2013 Author Posted December 30, 2013 Hi All Here is a link to TV Fanart which has the PSD for dvd/cd exactly as the automatic downloads through Media Browser Server. The PSD is fully editable for image size, placing logo etc http://fanart.tv/movie-fanart/
