Kodi on Fire TV
chaoconnor
Good Morning!  Downloaded Emby and ran it per the video instructions.  It syncs, the progress bar showing all my movies & TV series.  I can see them and play them via the Emby Server (a docker running on unRaid).  However when I try to browse my videos in Kodi, after selection Movies or TV, the Emby selection comes up, but no shows or movies.  No matter how many times I click on All Movies or All TV Shows, nothing.  It just sits there.
Am I missing something basic?  Thanks!
im85288
Did the sync complete successfully? I also installed this on fire TV today and once the sync completed (about half an hour) it then showed all my media correctly.
Angelblue05
Do you have masterlock on?
Sent from my iPhone using Tapatalk
chaoconnor
I don't believe so, but I will check tonight when I get home.
Also, I let it sit all night, so I'll try again in case it was a "sync" issue.
Thanks for the suggestions!
  • Like 1
Angelblue05
Ok, let us know :)
PhilWhite
Where is your Emby server?  I had a similar problem -- everything played well in the Emby app but would not play in Emby for Kodi because the pathway was not recognized as legitimate by the emby for kodi addon.  Is your Emby server in a NAS by any chance?
Guest
