mbc0 68 Posted June 8, 2015 Posted June 8, 2015 Hi, Don't know if it is possible but can it be made that syncing encoding can use full power but if a client wants to stream something that that will take the priority by maybe pausing the sync process until the server is idle again? Cheers
Luke 42242 Posted June 8, 2015 Posted June 8, 2015 the first part yes, the second part at some point later 1
