jamvids 39 Posted June 8, 2015 Posted June 8, 2015 Any help anyone, If I try to play a video over 4G (which is usually 20mb) the video only plays for 10 seconds and then stops, then plays 10 seconds etc. I thought this could be due to transcoding or upload bandwidth at home but I can play the same video on a friends wifi, which will be using the same upload bandwidth it works fine. This kind of clears both of these reasons which leaves me thinking it's something to do with my mobile provider (O2) but like I say it tests at a solid 20mb minimum. Any one else experiencing the same?
chef 3811 Posted June 8, 2015 Posted June 8, 2015 Okay, I know it might not be the same thing, but I notice the play and stop when I play to my devices. 10 secs then stop, the. 10secs and then stop. It happens when I stream to my chromecast, my xbox1 and to my Galaxy Tab. I thought it was my network. I use an Arris wireless modem. But although similar, this is happening on my home network. It might not be the same... I dunno.
jamvids 39 Posted June 8, 2015 Author Posted June 8, 2015 (edited) Device is Sony Xperia Z2, Android version 5.0.2. It used to work okay. With the old app if it did a direct stream it worked okay too. Edited June 8, 2015 by jamvids
