pmac 143 Posted November 19, 2013 Posted November 19, 2013 Something I've noticed just now with MBT, which didn't seem to happen with MBC is that when watching a television show, my MBIntros are playing before each episode. This may be fine for some users, if that's their intended purpose, but with MBC I only had intros playing before movies, and with television I could jump right into the episode without waiting for an intro to play before each one. Just a small inconvenience, which I'm sure will get sorted out with future releases. Another small issue I've noticed is that after the intro has finished playing, and the main title has started, the on-screen display still shows the title of the intro at the top, instead of the title of the movie/tv episode/etc. The proper clear logo is displayed in the corner, but the "Now Playing" text shows the title of the intro, instead of the feature title. I figured I'd post this in the MBT forum, instead of the MBIntro's area, since it seems to work fine everywhere but in MBT Thanks, Patrick
Solution ebr 16331 Posted November 19, 2013 Solution Posted November 19, 2013 Upgrade your version of the intros plug-in. 1
pmac 143 Posted November 19, 2013 Author Posted November 19, 2013 Excellent, thank you! On a side note, will there be a way of making certain intros playable for movies, and others for television? A while back I made up some slick looking television rating intros that I've been dying to use.
ebr 16331 Posted November 19, 2013 Posted November 19, 2013 The current plug-in is really designed for movies. Maybe someone will create one for TV if there is sufficient demand. 1
