raptorjr 15 Posted June 6, 2015 Posted June 6, 2015 I had the longest run so far with emby, 6 days without a crash. But now I noticed that no scheduled task is running. All of them have default settings. Should run atleast once a day. But none of them have been running for the last 5-6 days, since I started the server. Any clue on where I can start to look to find the problem? Don't say the logs, the stopped working a couple of hours after the last restart of the server =\
Luke 42243 Posted June 6, 2015 Posted June 6, 2015 I think this is happening on some Linux distros right now. Someone else reported this, or maybe it was you? Curious are you on mono 4?
raptorjr 15 Posted June 6, 2015 Author Posted June 6, 2015 Yes, I'm using Mono 4. Dont think I mentioned this problem before. Many other problems, but not this one =) 2015-06-06 15:40:08.9723 Info - Main: Emby Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /media/multimedia/emby Operating system: Unix 3.13.0.52 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /media/multimedia/emby Mono: 4.0.1 (tarball Tue May 26 04:28:10 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe2015-06-06 15:40:09.3228 Info - App: Application version: 3.0.5621.42015-06-06 15:40:09.4344 Info - App: Application configuration:
VladTepz 47 Posted June 8, 2015 Posted June 8, 2015 My friend xtropy was having the same issue, he resolved his issue by, Issue resolved after changing the URL from http://serverip:8096/emby to only http://serverip:8096/ . Adding http://serverip:8096/emby causes GUID and Scheduled Task issues, amongst other problems OP: http://emby.media/community/index.php?/topic/21765-scheduled-tasks-issue-on-ubuntu-server/ Not sure if it's the same issue you're having though, but it's worth a check. -Vlad
raptorjr 15 Posted June 8, 2015 Author Posted June 8, 2015 My friend xtropy was having the same issue, he resolved his issue by, OP: http://emby.media/community/index.php?/topic/21765-scheduled-tasks-issue-on-ubuntu-server/ Not sure if it's the same issue you're having though, but it's worth a check. -Vlad I dont think it is the same problem. I'm not trying to change or create a task. The default tasks created was not running at all. And they should be running, even when there is no webpage open. However, after a computer restart it seems that things might be working. Too soon to call yet, but something is alive inside Emby =)
draggy 0 Posted June 29, 2015 Posted June 29, 2015 My scheduled tasks also aren't running. I haven't added any triggers, but the default ones obviously aren't running. For instance the application updates should run every 24 hours (default trigger) it last ran 3 days ago. 2015-06-25 20:55:16.8526 Info - Main: Emby Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.13.0.53 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 13:22:02 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe 2015-06-25 20:55:17.2204 Info - App: Application version: 3.0.5641.5
draggy 0 Posted July 1, 2015 Posted July 1, 2015 Seems that it had something to do with the kernel version that I was using making mono unstable, mentioned here: http://emby.media/community/index.php?/topic/19955-emby-crashing-ubuntu-server/page-6 I upgraded to kernel version 3.13.0-55 and after a reboot the tasks are running. Or maybe it was the reboot, I don't know.
raptorjr 15 Posted July 2, 2015 Author Posted July 2, 2015 I'm having the same problem again, kernel 3.13.0-52. They worked for a while after a reboot. But now I have to start them manually again.
draggy 0 Posted July 6, 2015 Posted July 6, 2015 @@raptorjr I was on 3.13.0-53 when it wasn't working, so I would try newer
