markle88 15 Posted June 6, 2015 Posted June 6, 2015 Every video I play freezes at about 3 minutes in. Audio playback resumes but the video remains frozen. I can't get the video to move past that freeze point no matter what I do. Anyone know how to get the log for a fire tv stick?
ebr 16336 Posted June 6, 2015 Posted June 6, 2015 I doubt a device log will help. Sounds like a transcoding issue. Do they play back properly in another app that streams (like the web client)?
tman 47 Posted June 7, 2015 Posted June 7, 2015 I've seen this before too. Depends on what you're throwing at it. 720p w/AAC is just about ok, but works better in an MP4 @ 4.1 container rather than MKV (MP4 seems to be the preferred container format for FTV). If you try 1080P w/DTS or FLAC, prepare for problems. You need a really good wifi connection for the FTV Stick as well. You'll also need a good spec CPU in your Emby server for the HD transcoding, although I'll admit, the current stable release is much, much less heavy on the CPU. I guess the full FTV doesn't have these problems.
CBers 7554 Posted June 7, 2015 Posted June 7, 2015 (edited) Anyone know how to get the log for a fire tv stick?Don't think there are any user-obtainable logs any more for the app. I hate to suggest this, but have you tried installing Kodi and the Emby addon? . Edited June 7, 2015 by CBers
markle88 15 Posted June 8, 2015 Author Posted June 8, 2015 (edited) Ok now I can't play any videos. All I get is a "Video Playback error- Failed to Load Video" error. The app worked great until recently. Not sure if some update has screwed with things.I have other clients on android, windows 8.1, and emby classic all still functioning without any problems. Server specs should be ok since I have been using this setup for a while now. And I am not trying to stream 1080p. Below are my video specs. I'll also attach the server log. Video CodecH264ProfileConstrained BaselineLevel30Resolution720x404Aspect ratio16:9AnamorphicNoInterlacedNoFramerate23.97602Bitrate1447 kbpsBit depth8 bitPixel formatyuv420pRef frames2CABACNo Audio LanguageengCodecAACProfileLCLayoutstereoChannels2 chBitrate156 kbpsSample rate48000 khzDefaultYes Audio LanguageengCodecAC3Layout5.1Channels6 chBitrate625 kbpsSample rate48000 khzDefaultNo Embedded Image CodecMJPEGLevel-99Resolution635x423Framerate90000Pixel formatyuvj444pDefaultNo Subtitle LanguageengCodecSRTDefaultNoForcedNoExternalYes Containermp4 Server Log.txt Edited June 8, 2015 by markle88
Luke 42243 Posted June 8, 2015 Posted June 8, 2015 it looks like on that file the transcoding failed. can you also post the transcoding log? thanks.
markle88 15 Posted June 8, 2015 Author Posted June 8, 2015 Transcode log as requested. Thanks for the help! Transcode Log.txt
Luke 42243 Posted June 8, 2015 Posted June 8, 2015 This is a server issue of escaping the quote within the path when constructing the ffmpeg command line. it will be resolved for the next release.
markle88 15 Posted June 8, 2015 Author Posted June 8, 2015 I have no idea what any of that meant but it sure sounds like you do . Thanks for the help Luke! 1
