adambot 0 Posted June 5, 2015 Posted June 5, 2015 Greetings, I just installed emby-server on my headless archlinux server and enabled the ability to delete files, however, whenever i try to delete a file through the web interface i get bounced back to the login screen. I only made 2 changes to the default setup. First was for the emby user so that it has permissions (restarting the daemon after i made the change): uid=990(emby) gid=100(users) groups=100(users),1006(emby) And i added the delete permission to the emby web user. Here is the error i get: 2015-06-04 23:49:17.1779 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5621.4 Command line: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe Operating system: Unix 4.0.4.2 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue May 19 20:07:41 UTC 2015) Application Path: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe Access to the path "/storage/media/Video/TV/Backlog/American Dad!/Season 12/American Dad! - S12E14 - American Fung - HDTV.mp4" is denied. System.UnauthorizedAccessException at System.IO.File.Delete (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile (System.String path, Boolean sendToRecycleBin) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.IO.CommonFileSystem.DeleteFile (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<DeleteItem>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-06-04 23:49:17.1779 Error - HttpServer: Error processing request for /emby/Items/0489b9c8cdbcb8f61415f003f18771af *** Error Report *** Version: 3.0.5621.4 Command line: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe Operating system: Unix 4.0.4.2 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue May 19 20:07:41 UTC 2015) Application Path: /usr/lib/emby-server/MediaBrowser.Server.Mono.exe Access to the path "/storage/media/Video/TV/Backlog/American Dad!/Season 12/American Dad! - S12E14 - American Fung - HDTV.mp4" is denied. ServiceStack.HttpError No Stack Trace Available Here is the directory permissions (from root all the way to the file) adam@turian ~ % ls -ld /storage drwxrwsr-x+ 17 adam users 4.0K Jun 4 22:59 /storage adam@turian ~ % ls -ld /storage/media drwxrwxr-x 8 adam users 95 Apr 28 17:43 /storage/media adam@turian ~ % ls -ld /storage/media/Video drwxrwxr-x 6 adam users 91 Apr 28 17:43 /storage/media/Video adam@turian ~ % ls -ld /storage/media/Video/TV drwxrwxr-x 8 adam users 119 Jun 1 20:58 /storage/media/Video/TV adam@turian ~ % ls -ld /storage/media/Video/TV/Backlog drwxrwxr-x 42 adam users 4.0K May 18 18:16 /storage/media/Video/TV/Backlog adam@turian ~ % ls -ld /storage/media/Video/TV/Backlog/American\ Dad\! drwxrwxr-x 6 adam users 110 Dec 1 2014 /storage/media/Video/TV/Backlog/American Dad! adam@turian ~ % ls -ld /storage/media/Video/TV/Backlog/American\ Dad\!/Season\ 12 drwxrwxr-x 2 adam users 137 Jun 2 19:01 /storage/media/Video/TV/Backlog/American Dad!/Season 12 adam@turian ~ % ls -ld /storage/media/Video/TV/Backlog/American\ Dad\!/Season\ 12/American\ Dad\!\ -\ S12E14\ -\ American\ Fung\ -\ HDTV.mp4 -rw-rw-r-- 1 adam users 88M May 25 21:10 /storage/media/Video/TV/Backlog/American Dad!/Season 12/American Dad! - S12E14 - American Fung - HDTV.mp4 As you can see, the users group has FULL access to the files so should be able to delete the file. I even changed the shell, su'ed over to the emby user and was able to touch a file in that directory. I also tried changing the ownership of the file to Emby but that didn't work either. Manual deletion from the command line as myself or as emby works without any issue.
Luke 42243 Posted June 5, 2015 Posted June 5, 2015 The system is incorrectly bouncing you to the login screen, and that we can fix, but we can't fix the underlying problem which is this. The server doesn't seem to be authorized to delete those files. Access to the path "/storage/media/Video/TV/Backlog/American Dad!/Season 12/American Dad! - S12E14 - American Fung - HDTV.mp4" is denied. System.UnauthorizedAccessException
adambot 0 Posted June 5, 2015 Author Posted June 5, 2015 (edited) The system is incorrectly bouncing you to the login screen, and that we can fix, but we can't fix the underlying problem which is this. The server doesn't seem to be authorized to delete those files. Access to the path "/storage/media/Video/TV/Backlog/American Dad!/Season 12/American Dad! - S12E14 - American Fung - HDTV.mp4" is denied. System.UnauthorizedAccessException Is there any way to further debug why the deletion is not allowed? [update] so it turns out that while emby doesn't need to "own" the file, it does need to "own" the directory that the file is in... very strange... Edited June 5, 2015 by adambot
spootdev 56 Posted June 5, 2015 Posted June 5, 2015 The system is incorrectly bouncing you to the login screen, and that we can fix, but we can't fix the underlying problem which is this. FYI, If you're scanning media and it can't write the nfo/image/etc file to the media directory it will kick you to login screen too with no warning.
