CBers 7557 Posted June 3, 2015 Posted June 3, 2015 Is there one? Searched through this forum, but it seems to be more questions than answers. Also, is the plugin still supported? Thanks in advance
hiro24 0 Posted June 3, 2015 Posted June 3, 2015 I came here looking for that as well. I can't get anything to work for it. Not sure if it's bad sources or if the plugin is defunct.
CBers 7557 Posted June 3, 2015 Author Posted June 3, 2015 No, the plugin still works. I've just added a bunch of sport channels to it.
AgileHumor 123 Posted June 3, 2015 Posted June 3, 2015 Curious about documentation myself. I personally can't figure how to get IPTV Plugin to work with H.264 IP Cameras. Someone said it's supported...but the protocol droptdowns don't match up. Personally don't use any media with RTMP. Allegedly YouTube works too (fixed video).
Luke 42252 Posted June 4, 2015 Posted June 4, 2015 How much of a guide is really needed? You find direct links to videos on the web and you add them to the plugin. that's really all there is too it. they have to be direct links to the actual media and not links to web pages that play videos
CBers 7557 Posted June 4, 2015 Author Posted June 4, 2015 I had a play with the plugin last night and managed to get 6 IPTV streams working.
AgileHumor 123 Posted June 7, 2015 Posted June 7, 2015 Basic IP stuff: How about some guidelines like supported Codecs? You support MJPEG/H264? Bitstreams? Protocols (why not RTSP, the most popular)? Audio?
techywarrior 689 Posted June 7, 2015 Posted June 7, 2015 Since the server will handle transcoding if required anything supported by the Emby server is supported. I had added support for the IPTV plugin in the Chrome Companion app so if you need some help you can try that. The Chrome Companion will try and detect streams/links that can be added. Then you just give it a name and click add. 3
gillmacca 17 Posted June 7, 2015 Posted June 7, 2015 I've never found any IPTV stream that works yet. Maybe a new thread needs to be started that will list IPTV streams that work
CBers 7557 Posted June 7, 2015 Author Posted June 7, 2015 Since the server will handle transcoding if required anything supported by the Emby server is supported. I had added support for the IPTV plugin in the Chrome Companion app so if you need some help you can try that. The Chrome Companion will try and detect streams/links that can be added. Then you just give it a name and click add. I could never figure out what I had to do with that part of the extension Which sort of websites does it detect streams/links on? YouTube for example?
CBers 7557 Posted June 7, 2015 Author Posted June 7, 2015 I've never found any IPTV stream that works yet. Maybe a new thread needs to be started that will list IPTV streams that work A great idea. My son and I have been scouring various IPTV related sites trying to get streams to work. We found a few, but the PQ is appealing.
techywarrior 689 Posted June 7, 2015 Posted June 7, 2015 I could never figure out what I had to do with that part of the extension Which sort of websites does it detect streams/links on? YouTube for example? Simply go to a webpage that has a video on it, open the extension and go to the video bookmark tab, it should list any video streams that it finds. The problem is that many websites are actively trying to prevent this exact sort of behavior. In order for the IPTV stream to work in Emby we need to get the actual video stream URL and often times the website will use tricks in order to hide it behind redirects that use cookies to validate a link, access tokens, and other special things. 1
techywarrior 689 Posted June 7, 2015 Posted June 7, 2015 A great idea. My son and I have been scouring various IPTV related sites trying to get streams to work. We found a few, but the PQ is appealing. Yea, it's probably a good idea to have a thread that lists some working URLs and/or instructions on how to get to the real stream URLs for websites that make it hard. 1
ebr 16342 Posted June 8, 2015 Posted June 8, 2015 Yea, it's probably a good idea to have a thread that lists some working URLs and/or instructions on how to get to the real stream URLs for websites that make it hard. Be careful. I don't want to start hosting a "how to" on pirating content. 2
Rainey 2 Posted July 14, 2015 Posted July 14, 2015 At least tell use where the links file is keep so we can edit it direct as putting one link at a time into the GUI is a PITA. Maybe it should be drag and drop?
Blueeyiz702 223 Posted August 11, 2015 Posted August 11, 2015 http://www.freeiptvlinks.com/2015/08/10/usa-iptv-channelsnew-4/
Blueeyiz702 223 Posted August 11, 2015 Posted August 11, 2015 (edited) TNT on IPTV,my screenshot is weird picture is perfect Edited August 11, 2015 by blueeyiz7021
Blueeyiz702 223 Posted August 11, 2015 Posted August 11, 2015 Are these permanent links? According to the site,they are all good working links.
ebr 16342 Posted August 11, 2015 Posted August 11, 2015 Be careful. I don't want to start hosting a "how to" on pirating content.
Blueeyiz702 223 Posted August 11, 2015 Posted August 11, 2015 Be careful. I don't want to start hosting a "how to" on pirating content. oops,sorrry ebr didnt see that! wont do that again
romana 1 Posted August 11, 2015 Posted August 11, 2015 there are two ways of setting up iptv one is to install the iptv plugin and live with it or the other way is to install tvheadend or dvblink and configure them to access iptv and guide which will make everything look awesome as well as it will be functional. ask me if any questions.
Blueeyiz702 223 Posted August 12, 2015 Posted August 12, 2015 (edited) removed post,ebr if thats ok.thought it would be better if i did. Edited August 12, 2015 by blueeyiz7021
Blueeyiz702 223 Posted August 12, 2015 Posted August 12, 2015 (edited) i removed my post,as to not cause problems and get me in hot water. Edited August 12, 2015 by blueeyiz7021
Blueeyiz702 223 Posted August 12, 2015 Posted August 12, 2015 (edited) Edited August 12, 2015 by blueeyiz7021
