Very Slow loading channel (NEXTPVR)
Can  somebody provide me maybe some information?
Browse to  http://[nextpvr server ip]:8866/api
Then open the following
http://i.imgur.com/YjghokX.png
Put this in the parameter field and send me the response back please.I want to check some stuff.
My provider doesn't provide that much information so i can't test everything.
I hope also to find somebody with hd shows....
{"resultLimit": -1,"datetimeSortSeq":
0,"channelSortSeq":
0,"titleSortSeq":
0,"statusSortSeq":
0,"datetimeDecending":
false,"channelDecending": false,"titleDecending":
false,"statusDecending": false,"All":
true,"None": false,"Pending":
false,"InProgress": false,"Completed":
false,"Failed": false,"Conflict":
false,"Recurring": false,"Deleted":
false,"FilterByName": false,"NameFilter":
null,"NameFilterCaseSensitive": false}
  • 2 weeks later...
I have this problem too. I tried:
0,"channelSortSeq":
0,"titleSortSeq":
0,"statusSortSeq":
but I'm not sure what to do now sorry. I just got a load of json with info on the program I was watching.
Something of a newb to Emby. If only it didn't take 20 seconds to load the channel this would be my ideal solution!
Many thanks, Duncan
55e6169a832c7_Output.pngHi Sven, I have done what you requested. I'd be happy to help with anything else. I too have the slow load of channels 40+ seconds, npvr is 1 to 2 seconds max. I have a mix of sd and hd channels tuned.
Edited by damian
This was for the HD channels (view in the grid), but some people told me it's ok now.. And you don't have any guide information? You should see all your programs in that response...
40+ seconds that's long. I am debugging some stuff to see what happens.
  • Like 1
I have 309 stations all with guide data. I can see the guide data in both NPVR and Emby. Thats strange if I was supposed to get a big list of guide data. I use epg centre to pull the freesat (UK sat service) data from my dvb-s2 card into an xml and then use npvr to pull the epg data from that xml. I'd be glad to help test anything or provide more info. I've pulled down the emby source code and npvr plugin source. I'm going to start playing around with it in a week or so after my holidays.
  • 1 year later...
Any update on this issue? 20+ seconds to change a channel is unusable - last update on this subject was over a year ago
Didn't check it anymore.
But what device are you using? HDhomerun,....
