fastcar 0 Posted June 3, 2015 Posted June 3, 2015 Hi There, I am just trying this out, I am currently using TVmobili. In TVMobili when I go through the folder list on my TV the list comes up exactly as it is in the folder structure on my hard drive. After installing emby and adding a couple of folders, for example X,Y,W for my movies and then going to my Samsung TV to see how it looks I find that the folder structure has changed, each film in no longer in their folder name but has moved to the referring letter, for example Yogi Bear Movie, shows up when I go in to the letter Y where I would like it to show as it is stored, Films,Y,Yogi Bear Movie,Yogie Bear Movie.MPG. What I am trying to say very badly.....lol............is I do not want emby to change file names, or move things about when I add folder to the library, I have things just the way I like them and would like them displayed on my TV like that. I hope I have made myself clear Thanks
Happy2Play 9802 Posted June 3, 2015 Posted June 3, 2015 You need to look at your view options in "My Preferences".
fastcar 0 Posted June 3, 2015 Author Posted June 3, 2015 If have been through that and could not see anything that helped. Thanks
fastcar 0 Posted June 3, 2015 Author Posted June 3, 2015 Just to give you a better idea this is my folder structure I have on my drives and the way I would like to see it on my TV
Happy2Play 9802 Posted June 3, 2015 Posted June 3, 2015 (edited) What server version are you on? Unless you didn't capture it in your screenshots there is a "View Style" section or "Display a folder view to show plain media folders" right above the Styles options. Edited June 3, 2015 by Happy2Play 1
Deathsquirrel 745 Posted June 3, 2015 Posted June 3, 2015 I'm not certain how well the server will parse your existing structure. It is definitely not the recommended structure.If you want to play with Emby to get a feel for it without messing with your current structure you may want to make a copy of a few movies, set them up as suggested in the WIKI at https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming, and point your library at that. Of course it could work perfectly. The product is pretty flexible in it's support for less common file structures.
Cerothen 98 Posted June 4, 2015 Posted June 4, 2015 I have a similar folder structure however you can get it to pick things up well if you add the folder like in the image.
fastcar 0 Posted June 10, 2015 Author Posted June 10, 2015 (edited) What server version are you on? Unless you didn't capture it in your screenshots there is a "View Style" section or "Display a folder view to show plain media folders" right above the Styles options. I don't seem to have that option as per my image posted, I am using Version 3.0.5621.4 on a Windows 8.1 PC. I might not have that option because I have changed some settings in the dashboard to try and get it to display as I want. Thanks for the help guys Edit...Just a thought, I have also added the files as "Home Videos" not movies so I don't know if that has any effect on the display, I tried "Movies" also but still wont display as I would like it to. Edited June 10, 2015 by fastcar
cab2344 0 Posted March 1, 2017 Posted March 1, 2017 i know this topic is old, but it has been bothering me for a while and i found out my problem. My movies would show the same folder structure/box sets, but on my phone or through kodi addon it would separate my movies and episodes into separate files. By CHANGING content type from movies to unset (mixed content) it fixed it. You cannot change the folder, but have to add a new folder and then delete the old one. Hope it helps for anyone in the future.
