johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 LOL...so I changed my sub path to be nfs://192.168.1.10/mnt/user/Movies/ 19:26:14 T:3968 NOTICE: PLAY Called 19:26:14 T:3968 NOTICE: EMBY PlayUtils -> logMsg : Can't verify path. Still try direct play. 19:26:14 T:3968 NOTICE: EMBY PlayUtils -> logMsg : File is direct playing. 19:26:14 T:2916 NOTICE: DVDPlayer: Opening: nfs://192.168.1.10/mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv 19:26:14 T:5376 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 19:26:14 T:2916 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 19:26:14 T:5376 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 19:26:14 T:6892 NOTICE: Thread DVDPlayer start, auto delete: false 19:26:14 T:5376 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=2b4edaa6885c2c0e4a0f177dcbfc1b8d&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 19:26:14 T:6892 NOTICE: Creating InputStream 19:26:14 T:6892 NOTICE: Creating Demuxer 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) This is great @@johnodon! Thanks for sticking through this. So for future reference this is the format that should be used for path subs in Emby, to get direct play: nfs://{ipaddress}/pathtocontent Edited June 2, 2015 by Angelblue05 1
Solution johnodon 18 Posted June 2, 2015 Author Solution Posted June 2, 2015 @@Angelblue05 And for the coup d'etat... I set the bitrate to 12.2mbit and then set the plugin back to Direct Play. 19:35:04 T:5768 NOTICE: PLAY Called 19:35:04 T:5768 NOTICE: EMBY PlayUtils -> logMsg : Can't verify path. Still try direct play. 19:35:04 T:5768 NOTICE: EMBY PlayUtils -> logMsg : File is direct playing. 19:35:04 T:4900 NOTICE: DVDPlayer: Opening: nfs://192.168.1.10/mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv 19:35:04 T:4780 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 19:35:04 T:4900 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 19:35:04 T:4780 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items/Root?format=json 19:35:04 T:6428 NOTICE: Thread DVDPlayer start, auto delete: false 19:35:04 T:4780 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 19:35:04 T:6428 NOTICE: Creating InputStream I'd say we can consider this closed. Sorry to waste so much of your time but I really appreciate your help! John 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 Not at all, I've learnt a great deal. Not many people use nfs so it was not tested very much. I might have to set it up for myself using path subs. It's quite easy!
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 We can't verify nfs paths, but we still allow to try direct play. Not being able to verify NFS paths cannot cause other issues, right?
