johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 @@Angelblue05 - Log attached... kodi.log 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) @@johnodon It's not able to direct play because it's not able to locate the file from Kodi using the path from your Emby library. In your Emby server, what are your paths like under library (media location) for where your Avatar is located? Edit: At least I know my fallback works I added this failsafe to get the best possible outcome if the user has any issues. It will try to direct play first, then direct stream and then transcoding. Because the bitrate is already modified, and Avatar requires a higher bitrate to direct stream, it ended up transcoding. Edited June 2, 2015 by Angelblue05 1
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 @@Angelblue05 - I am using path substitutions. Without them, my media will not play in Kodi. Here my movie library path: Here is the path sub for my movies library:
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) @@johnodon Ok, in the Emby for Kodi addon settings, can you set the log level to Debug instead of Info. Repeat the steps once more. It will show why it can't locate the file. Thanks Edit: Oh and post your log, hehe. Edited June 2, 2015 by Angelblue05 1
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 I think you are close to nailing this. I'm not sure if it is a configuration issue on my server or something else, but I set Emby back to 100Mbit so it did not transcode and I still see the same message in the kodi log: 17:30:28 T:6260 NOTICE: PLAY Called 17:30:28 T:6260 NOTICE: EMBY PlayUtils -> Can't direct play: Unable to locate the content. So, I guess all it was doing was streaming at unlimited bitrate.
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 @@johnodon Ok, in the Emby for Kodi addon settings, can you set the log level to Debug instead of Info. Repeat the steps once more. It will show why it can't locate the file. Thanks I'll do that now..Hold one...
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 I think you are close to nailing this. I'm not sure if it is a configuration issue on my server or something else, but I set Emby back to 100Mbit so it did not transcode and I still see the same message in the kodi log: 17:30:28 T:6260 NOTICE: PLAY Called 17:30:28 T:6260 NOTICE: EMBY PlayUtils -> Can't direct play: Unable to locate the content. So, I guess all it was doing was streaming at unlimited bitrate. Exactly my thoughts
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 @@Angelblue05 - Debug log attached... kodi.log 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) I'm pretty sure your nfs path is incorrect because of the :\\, but I need someone to validate as I don't use it myself.... @@johnodon Can you try reversing the slashes? like nfs://mnt/users/Movies See if that works instead, that's the only thing I can think of.... Edited June 2, 2015 by Angelblue05
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 (edited) @@Angelblue05 - Hmmm...I think I may have solved but I'm not sure. I changed my movies sub path to: /mnt/user/Movies --> \\unraid\Movies Unless I'm going googly eyed, I don't see the direct play error in this log. Can you take a look also? EDIT: Answered my own question. Looky looky... 17:52:59 T:3744 NOTICE: EMBY PlayUtils -> logMsg : Path exists. 17:52:59 T:3744 NOTICE: EMBY PlayUtils -> logMsg : File is direct playing. 17:52:59 T:4092 NOTICE: DVDPlayer: Opening: smb://unraid/Movies/Avatar (2009)/Avatar (2009).mkv kodi.log Edited June 2, 2015 by johnodon 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) I just don't know how nfs should be set in the server so if @@Luke or @@ebr can confirm the proper path format, I think you can get it to work with nfs paths. I couldn't find any information about it in the wiki or tutorial... Edited June 2, 2015 by Angelblue05
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 OK...let me try the format you suggested. SMB works fine but NFS is a little faster for me. I'll post back after I test. 1
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 Well, that path looked better in some aspects but still failed to play... 18:07:20 T:4384 NOTICE: EMBY PlayUtils -> logMsg : Can't verify path. Still try direct play. 18:07:20 T:4384 NOTICE: EMBY PlayUtils -> logMsg : File is direct playing. 18:07:20 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:20 T:776 NOTICE: DVDPlayer: Opening: nfs://mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv 18:07:20 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:21 T:776 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=61279d7d5e0dc0f58172231bd21c2748&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:21 T:4016 NOTICE: Thread DVDPlayer start, auto delete: false 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:21 T:4016 NOTICE: Creating InputStream 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=4a51d77eefb0c7de21d65bd760df5b35&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=153246ef3958dce25376114e1bebb074&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=7c29ae9cf36ff4ef78182812f5037570&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=672d13b74bf029d9ee1705768ded2124&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=0490358d8b20c023b58f09088264454d&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:21 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=5ebaf8e582f6ea6c876c072ada27791f&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=12ac4e88d0f22fc30ca0c33b40a40b8b&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=ca3e052417827337adb17a653c723ca8&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=feea27f662bf6b3bb48e39eda95a29e7&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=6cedd9b6b975b7ff9beffe8fd178d7be&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:22 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=04c22d9905b5689a8e4c7d8bc9a5b96c&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=485dd4c180df9049739467b2b0eacaec&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 18:07:23 T:5936 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=c984fd154ce610242586f3f6fda36b79&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 18:07:23 T:4016 ERROR: Unable to lookup host: 'mnt' 18:07:23 T:4016 ERROR: CDVDPlayer::OpenInputStream - error opening [nfs://mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv] 18:07:23 T:4016 NOTICE: CDVDPlayer::OnExit() I'll stick with the SMB path for now since I know it works. If Luke/EBR chime in maybe we can figure it out. Glad to know that it was not a plugin issue in the end. Thanks for your help! John
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) @@johnodon Ok, please revert back to your original path (nfs:\\). I will fix this. I think I know why! Give me a few minutes. Edited June 2, 2015 by Angelblue05
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 (edited) OK...ready to go... /mnt/user/Movies/ --> nfs:\\mnt\user\Movies\ Edited June 2, 2015 by johnodon
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) @@johnodon Alright, same deal as before. Install the zip, no need to uninstall first, just restart Kodi after installing the zip. If it doesn't work and still direct streams, I'll have to rethink this, so for the moment you can switch to smb if it doesn't work. plugin.video.emby-1.0.0.zip Edited June 2, 2015 by Angelblue05
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 @@Angelblue05 - I'll do that now. Something to think about...was just doing some reading and the correct format may be nfs:// as you had suggested. But I will try nfs:\\ now.
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 @@johnodon - Yeah, if it doesn't work, then we know your nfs are incorrect for sure. I'm basically letting Kodi decide if it works or not in the build I'm making you test....
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 OK...I think I am an idiot. Don't I need an actual server name (IP) in my nfs path? :S like... nfs:\\192.168.1.10\user\mnt\Movies\ 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 Haha, I don't know - I don't use nfs, but try it out and let me know.
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 I modded my paths subs to include server IP: This one played but failed directl play and defaulted to HTTP (nfs://): 18:38:53 T:4604 NOTICE: EMBY PlayUtils -> logMsg : Path is detected as a Url: nfs://192.168.1.10/mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv. Try direct streaming. 18:38:53 T:4604 NOTICE: EMBY PlayUtils -> logMsg : Can't direct play: Unable to locate the content. 18:38:53 T:4604 NOTICE: EMBY PlayUtils -> logMsg : Playurl: http://192.168.1.10:8096/mediabrowser/Videos/94b2dfb740b42a6401ab88b3f02e045f/stream?static=true&AudioStreamIndex=1 18:38:53 T:4604 NOTICE: EMBY PlayUtils -> logMsg : File is direct streaming. This one failed to play at all but the issue is obvious (nfs:\\): 18:42:24 T:5572 NOTICE: EMBY PlayUtils -> logMsg : Can't verify path. Still try direct play. 18:42:25 T:5572 NOTICE: EMBY PlayUtils -> logMsg : File is direct playing. 18:42:25 T:5640 NOTICE: DVDPlayer: Opening: nfs:smb://192.168.1.10/mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) Ok, that's great! so what I had originally worked fine. So I guess what you can do now is to go uninstall the addon and reinstall the version from the Emby repo under add-ons > Get add-ons. This should work correctly now that you fixed your path. Restart Kodi and you should get nfs direct playing. (fingers crossed) Edited June 2, 2015 by Angelblue05
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 (edited) @@Angelblue05 Sigh... I ended up just removing Kodi and deleting any leftover bits. Reinstalled Kodi Helix, the Emby Repo and the Emby Plugin (from the repo) with no defaults changed other than to turn debug logging. Sub path is set to nfs:\\192.168.1.10\mnt\user\Movies\ This is what I see in the Kodi log... 19:10:03 T:5308 NOTICE: PLAY Called 19:10:03 T:5308 NOTICE: EMBY PlayUtils -> logMsg : Path is detected as a Url. Try direct streaming. 19:10:03 T:6684 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 19:10:03 T:5308 NOTICE: EMBY PlayUtils -> logMsg : Playurl: http://192.168.1.10:8096/mediabrowser/Videos/94b2dfb740b42a6401ab88b3f02e045f/stream?static=true&AudioStreamIndex=1 19:10:03 T:5308 NOTICE: EMBY PlayUtils -> logMsg : File is direct streaming. 19:10:03 T:6684 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 19:10:03 T:6388 NOTICE: DVDPlayer: Opening: http://192.168.1.10:8096/mediabrowser/Videos/94b2dfb740b42a6401ab88b3f02e045f/stream?static=true&AudioStreamIndex=1 19:10:03 T:6684 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=31ed0dbcfd456fe95ec1b8967f30a276&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 19:10:03 T:6388 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 19:10:03 T:4868 NOTICE: Thread DVDPlayer start, auto delete: false Still wants to stream. Edited June 2, 2015 by johnodon 1
Angelblue05 4132 Posted June 2, 2015 Posted June 2, 2015 (edited) Ok, thanks for reporting back. Do not worry, I'll get it to work, but for now you can switch your path substitution to \\unraid\. I'll test a few things on my side. Edited June 2, 2015 by Angelblue05
johnodon 18 Posted June 2, 2015 Author Posted June 2, 2015 Will do. BTW...I did my own test. I added an new Source in Kodi under File Manager and point to the NFS share on my unraid server. I then played Avatar from that source and this is how Kodi saw the NFS path: 19:20:43 T:5956 NOTICE: DVDPlayer: Opening: nfs://192.168.1.10/mnt/user/Movies/Avatar (2009)/Avatar (2009).mkv 19:20:43 T:776 NOTICE: EMBY DownloadUtils -> logMsg : === ENTER downloadUrl === 19:20:43 T:5956 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 19:20:43 T:776 NOTICE: EMBY DownloadUtils -> logMsg : URL: http://192.168.1.10:8096/mediabrowser/Users/6f80196bcfab48cb92fb25ac4d94bf0f/Items?ParentId=5ebaf8e582f6ea6c876c072ada27791f&IsVirtualUnaired=false&IsMissing=False&SortBy=SortName&Fields=Name,SortName,CumulativeRunTimeTicks,Etag&Recursive=true&SortOrder=Ascending&IncludeItemTypes=Episode&format=json&ImageTypeLimit=1 19:20:43 T:436 NOTICE: Thread DVDPlayer start, auto delete: false 19:20:43 T:436 NOTICE: Creating InputStream 19:20:43 T:776 NOTICE: EMBY DownloadUtils -> logMsg : ====== 200 Success ====== 19:20:43 T:436 NOTICE: Creating Demuxer 1
