geaves 13 Posted June 2, 2015 Posted June 2, 2015 This seems to have stopped working with the latest ubuntu install, install plugin, leave default as 2 click save and an error message pops up; Guid should contain 32 digits with 4 dashes. Is there something that requires editing? Thx.
geaves 13 Posted June 2, 2015 Author Posted June 2, 2015 (edited) Sorry forgot that part... 2015-06-02 14:06:39.9725 Error - HttpServer: Error processing request for /emby/Plugins/899c12c7-5b40-4c4e-9afd-afd74a685eb1/Configuration *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.16.0.30 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 04:05:12 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). ServiceStack.HttpError No Stack Trace Available 2015-06-02 14:06:44.6861 Info - Auto Box Sets: Executing Automatic BoxSet creation. Found 0 potential box sets.2015-06-02 14:06:44.6861 Info - Auto Box Sets: Automatic BoxSet creation completed. If I uninstall then re install.... 2015-06-02 14:11:57.5085 Error - HttpServer: Error processing request for /emby/Plugins/899c12c7-5b40-4c4e-9afd-afd74a685eb1/Configuration *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.16.0.30 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 04:05:12 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). ServiceStack.HttpError No Stack Trace Available 2015-06-02 14:11:58.9335 Info - App: Scan media library Completed after 0 minute(s) and 8 seconds2015-06-02 14:11:58.9412 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-06-02 14:11:59.1059 Info - App: Executing Check for plugin updates2015-06-02 14:11:59.1089 Info - LibraryMonitor: Watching directory /var/lib/emby-server/data/playlists2015-06-02 14:11:59.1089 Info - LibraryMonitor: Watching directory /var/lib/emby-server/data/collections2015-06-02 14:11:59.1089 Info - LibraryMonitor: Watching directory /var/lib/emby-server/data/camerauploads2015-06-02 14:11:59.1097 Info - LibraryMonitor: Watching directory /var/lib/emby-server/root2015-06-02 14:11:59.1196 Info - App: Check for plugin updates Completed after 0 minute(s) and 0 seconds2015-06-02 14:11:59.1204 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-06-02 14:11:59.2695 Info - App: Executing Refresh Channels2015-06-02 14:11:59.2729 Info - App: Refresh Channels Completed after 0 minute(s) and 0 seconds2015-06-02 14:11:59.2738 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-06-02 14:11:59.4230 Info - App: Executing Check for application updates2015-06-02 14:11:59.4321 Info - App: Check for application updates Completed after 0 minute(s) and 0 seconds2015-06-02 14:11:59.4331 Info - ServerManager: Sending web socket message ScheduledTaskEnded2015-06-02 14:12:02.2166 Info - Auto Box Sets: Executing Automatic BoxSet creation. Found 0 potential box sets.2015-06-02 14:12:02.2166 Info - Auto Box Sets: Automatic BoxSet creation completed.2015-06-02 14:12:02.5410 Info - Auto Box Sets: Executing Automatic BoxSet creation. Found 0 potential box sets.2015-06-02 14:12:02.5410 Info - Auto Box Sets: Automatic BoxSet creation completed.2015-06-02 14:12:04.8301 Info - LibraryMonitor: Watching directory /media/Movies Edited June 2, 2015 by geaves
ebr 16342 Posted June 2, 2015 Posted June 2, 2015 However, it sounds like your issue is this one: http://emby.media/community/index.php?/topic/21877-emby-server-error-guid-should-contain-32-digits-with-4-dashes/?p=214903
geaves 13 Posted June 2, 2015 Author Posted June 2, 2015 Ok, this a complete new log... 2015-06-02 14:34:48.9033 Info - Main: Emby Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.16.0.30 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 04:05:12 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe2015-06-02 14:34:49.5751 Info - App: Application version: 3.0.5621.42015-06-02 14:34:49.7183 Info - App: Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableUserSpecificUserViews":true,"EnableInternetProviders":true,"IsPortAuthorized":true,"SeasonZeroDisplayName":"Specials","SaveLocalMeta":false,"EnableLocalizedGuids":true,"EnableLibraryMetadataSubFolder":true,"PreferredMetadataLanguage":"en","MetadataCountryCode":"GB","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeLibraryMonitorDelay":40,"EnableDashboardResponseCaching":true,"EnableDashboardResourceMinification":true,"MergeMetadataAndImagesByName":true,"EnableStandaloneMetadata":true,"ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Logo","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"EnableRealtimeMonitor":true,"PathSubstitutions":[],"UICulture":"en-GB","PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false,"DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps9":["Chromecast","iOS","Unknown app","iPad","iPhone","Windows Phone"],"SaveMetadataHidden":false,"ContentTypes":[],"EnableAudioArchiveFiles":false,"EnableVideoArchiveFiles":false,"RemoteClientBitrateLimit":0,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true,"EnableCustomPathSubFolders":true}2015-06-02 14:34:49.7728 Info - App: Loading AutoBoxSets, Version=1.0.0.7, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Api, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.WebDashboard, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Model, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Common, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Controller, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Providers, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Server.Implementations, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.MediaEncoding, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Dlna, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.LocalMetadata, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.XbmcMetadata, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Server.Mono, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:49.7728 Info - App: Loading MediaBrowser.Server.Startup.Common, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null2015-06-02 14:34:50.3368 Info - SqliteUserRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/users.db2015-06-02 14:34:50.5185 Info - SqliteItemRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/chapters.db2015-06-02 14:34:50.5329 Info - SqliteItemRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/mediainfo.db2015-06-02 14:34:50.5805 Info - SqliteFileOrganizationRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/fileorganization.db2015-06-02 14:34:50.6069 Info - AuthenticationRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/authentication.db2015-06-02 14:34:50.6423 Info - SyncRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/sync14.db2015-06-02 14:34:51.0320 Info - ImageMagick: ImageMagick version: ImageMagick 6.9.1-2 Q8 x86_64 2015-06-02 http://www.imagemagick.org2015-06-02 14:34:51.1641 Info - ImageProcessor: ImageProcessor started with 4 max concurrent image processes2015-06-02 14:34:51.2714 Info - App: FFMpeg: /var/lib/emby-server/ffmpeg/20150331/ffmpeg2015-06-02 14:34:51.2714 Info - App: FFProbe: /var/lib/emby-server/ffmpeg/20150331/ffprobe2015-06-02 14:34:51.3114 Info - ActivityRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/activitylog.db2015-06-02 14:34:51.3436 Info - SqliteDisplayPreferencesRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/displaypreferences.db2015-06-02 14:34:51.3554 Info - SqliteItemRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/library.db2015-06-02 14:34:51.3745 Info - SqliteProviderInfoRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/refreshinfo.db2015-06-02 14:34:51.3998 Info - SqliteUserDataRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/userdata_v2.db2015-06-02 14:34:51.4180 Info - SqliteNotificationsRepository: Sqlite 3.8.2 opening /var/lib/emby-server/data/notifications.db2015-06-02 14:34:51.9507 Info - HttpServer: Calling ServiceStack AppHost.Init2015-06-02 14:34:57.9931 Info - ServiceStackHost: Initializing Application took 7240.908ms2015-06-02 14:34:58.0342 Info - ServerManager: Loading Http Server2015-06-02 14:34:58.0389 Info - HttpServer: Adding HttpListener prefix http://+:8096/2015-06-02 14:34:58.0398 Info - HttpServer: Adding HttpListener prefix https://+:8920/2015-06-02 14:34:58.0591 Error - ServerManager: The http server is unable to start due to a Socket error. This can occasionally happen when the operating system takes longer than usual to release the IP bindings from the previous session. This can take up to five minutes. Please try waiting or rebooting the system. *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.16.0.30 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 04:05:12 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe Address already in use System.Net.Sockets.SocketException at System.Net.Sockets.Socket.Bind (System.Net.EndPoint local_end) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener.CreateSocket () [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener..ctor (ILogger logger, System.Net.IPAddress addr, Int32 port, Boolean secure, System.String certificateLocation) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.GetEPListener (ILogger logger, System.String host, Int32 port, SocketHttpListener.Net.HttpListener listener, Boolean secure) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.AddPrefixInternal (ILogger logger, System.String p, SocketHttpListener.Net.HttpListener listener) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.AddListener (ILogger logger, SocketHttpListener.Net.HttpListener listener) [0x00000] in <filename unknown>:0 2015-06-02 14:34:58.0591 Error - App: Error starting http server *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.16.0.30 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 04:05:12 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe Address already in use System.Net.Sockets.SocketException at System.Net.Sockets.Socket.Bind (System.Net.EndPoint local_end) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener.CreateSocket () [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener..ctor (ILogger logger, System.Net.IPAddress addr, Int32 port, Boolean secure, System.String certificateLocation) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.GetEPListener (ILogger logger, System.String host, Int32 port, SocketHttpListener.Net.HttpListener listener, Boolean secure) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.AddPrefixInternal (ILogger logger, System.String p, SocketHttpListener.Net.HttpListener listener) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.AddListener (ILogger logger, SocketHttpListener.Net.HttpListener listener) [0x00000] in <filename unknown>:0 2015-06-02 14:34:58.0644 Error - Main: UnhandledException *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server Operating system: Unix 3.16.0.30 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.1 (tarball Tue Jun 2 04:05:12 UTC 2015) Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe One or more errors occurred. System.AggregateException at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, Int32 millisecondsTimeout) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (MediaBrowser.Server.Implementations.ServerApplicationPaths appPaths, ILogManager logManager, MediaBrowser.Server.Startup.Common.StartupOptions options) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00000] in <filename unknown>:0 InnerException: System.Net.Sockets.SocketException Address already in use at System.Net.Sockets.Socket.Bind (System.Net.EndPoint local_end) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener.CreateSocket () [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener..ctor (ILogger logger, System.Net.IPAddress addr, Int32 port, Boolean secure, System.String certificateLocation) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.GetEPListener (ILogger logger, System.String host, Int32 port, SocketHttpListener.Net.HttpListener listener, Boolean secure) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.AddPrefixInternal (ILogger logger, System.String p, SocketHttpListener.Net.HttpListener listener) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointManager.AddListener (ILogger logger, SocketHttpListener.Net.HttpListener listener) [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost+<Init>c__async1.MoveNext () [0x00000] in <filename unknown>:0
Luke 42253 Posted June 2, 2015 Posted June 2, 2015 See here http://emby.media/community/index.php?/topic/21877-emby-server-error-guid-should-contain-32-digits-with-4-dashes/
geaves 13 Posted June 2, 2015 Author Posted June 2, 2015 See here http://emby.media/community/index.php?/topic/21877-emby-server-error-guid-should-contain-32-digits-with-4-dashes/ Thanks updating kernel now, apologies should have searched the forums first.
geaves 13 Posted June 3, 2015 Author Posted June 3, 2015 (edited) I have posted in the other thread regarding the error, the has now gone following those instructions, however the box set plugin still fails, if I manually search the movie db and locate a film set id and insert that using the metadata manager it has at least populated the one box set I have edited. EDIT: Scratch that.....1) Search the forums!! 2) Use the tools these guys have created. and say THANK YOU.... Now all I have to do is to create a 'Her Indoors' collection.... Edited June 3, 2015 by geaves
