tixx 8 Posted June 2, 2015 Posted June 2, 2015 Guys, any chance emby clients could support fast playback with audio at say 1.25, 1.5, 1.75 and 2x the speed.? its such a useful feature. Kodi devs are against implementing it, and 3rd party solutions like external players dont work well. If emby clients were capable of doing it, it would be awesome. Cheers 6
Vicpa 612 Posted June 2, 2015 Posted June 2, 2015 Hi, The Windows 8 app supports it. Not quite sure of the multiple.
tixx 8 Posted June 3, 2015 Author Posted June 3, 2015 OK great thanks, will check it out. Does anyone else know if its supported on any other platform? Im wanting to replace my old hardware mediaplayer that can do the fast playback of upto 2x speed with either an android device (like an amlogic m8s) or maybe even a roku, or also possibly raspberry pi. Cheers
newblar 0 Posted July 11, 2018 Posted July 11, 2018 bump feature still wanted. Can use an addon html 5 speed playback extension on pc would like the same option on smartphone and emby theater. Server has no problem keeping up when running at 1.3x speed through internet browser.
danielwong 0 Posted August 11, 2018 Posted August 11, 2018 I agree! Would definitely want this feature, implemented consistently throughout all apps.
newblar 0 Posted August 11, 2018 Posted August 11, 2018 I only use emby through browser so I can speed up whatever I'm watching. Lot of cable channels run shows 7% faster so they can fit in more commercials.
tixx 8 Posted January 5, 2019 Author Posted January 5, 2019 Hi, Any update on this feature request? I would like the emby apps to support this natively. even if its a paid for feature. Thanks
Ray 4 Posted January 8, 2019 Posted January 8, 2019 If this could be supported natively I'd vote for Android TV support.
tixx 8 Posted January 11, 2019 Author Posted January 11, 2019 @@Luke, hopefully not too far in the distant future, its been almost 3yrs since my initial suggestion @@Ray, android and tv apps (if they get released - e.g. tizen) would be perfect. Then no need for additional boxes etc.
newblar 0 Posted January 11, 2019 Posted January 11, 2019 chrome extension video speed controller allows you to adjust html5 video playback speeds. Open source code for it is on github if that helps. https://github.com/igrigorik/videospeed
tixx 8 Posted January 12, 2019 Author Posted January 12, 2019 chrome extension video speed controller allows you to adjust html5 video playback speeds. Open source code for it is on github if that helps. https://github.com/igrigorik/videospeed Hi Newblar, is it supported in tv based browsers? i'd prefer to run directly of my smart tv. cheers
lalajee 2 Posted March 3, 2019 Posted March 3, 2019 i would like to have this too. I watch lot of guide videos and I can do with this feature. Youtube has I think best, if it can be implement into emby too. Please build this feature into emby.
Luke 42248 Posted September 14, 2020 Posted September 14, 2020 This will be in Emby Server 4.5. You'll be able to use the controls in the video player to set the playback speed.
tixx 8 Posted September 25, 2020 Author Posted September 25, 2020 Nice one Luke! Thanks for that. WIll it work on all players, or just the HTML one? Thanks
Luke 42248 Posted September 26, 2020 Posted September 26, 2020 On 9/25/2020 at 7:13 AM, tixx said: Nice one Luke! Thanks for that. WIll it work on all players, or just the HTML one? Thanks It's in the web app now in the 4.5 release, and will be added to the next updates of most of our apps. Thanks.
