tp546 41 Posted June 1, 2015 Posted June 1, 2015 Is anyone running both Emby and Plex? I am thinking about giving Plex a try but I don't want to mess up my Emby setup. Any info is welcome. Thanks.
wbennett77 0 Posted June 1, 2015 Posted June 1, 2015 I am also thinking about running both. I am currently running Plex but curious about Emby.
Deathsquirrel 745 Posted June 1, 2015 Posted June 1, 2015 I have both installed; they get along fine. Give it a go if you're curious.
mgworek 134 Posted June 2, 2015 Posted June 2, 2015 When I was switching from one to the other i was running the Trakt plugin so both servers had the same watched status for everything. 1
mil1i 0 Posted August 31, 2015 Posted August 31, 2015 I recently installed Plex on the same server I'm running Emby on. I'm not 100% sure of what has caused this issue I am having now but I thought I would post here. Previously I was solely running Emby server, and anytime I did a search by actor name to see what movies/shows I had that a particular actress/actor was in it worked fine. It showed all movies/shows I had for them when I opened it up. After I installed Plex, is when I started noticing that it doesn't work anymore. Anytime I look up an actor/actress on the Emby client side, it will only show me one movie I have them in. Same with Plex, it also does the same thing. Any suggestions as to what may have happened?
Happy2Play 9811 Posted August 31, 2015 Posted August 31, 2015 I recently installed Plex on the same server I'm running Emby on. I'm not 100% sure of what has caused this issue I am having now but I thought I would post here. Previously I was solely running Emby server, and anytime I did a search by actor name to see what movies/shows I had that a particular actress/actor was in it worked fine. It showed all movies/shows I had for them when I opened it up. After I installed Plex, is when I started noticing that it doesn't work anymore. Anytime I look up an actor/actress on the Emby client side, it will only show me one movie I have them in. Same with Plex, it also does the same thing. Any suggestions as to what may have happened? There are several topics on this. Check this one.
