Tranquil 95 Posted June 1, 2015 Posted June 1, 2015 Hello Forum. I'm using Emby for Kodi Version 0.1.94 with a customized skin of Titan. (Titan Media Browser Skin) Since I'm switched the Video Addon to the new one, I no longer can find the option to show a Info Screen instead of directly start the movie. Isn't that implemented?
Solution Angelblue05 4132 Posted June 1, 2015 Solution Posted June 1, 2015 Usually the setting can be found under Settings > Video > File lists > Default action > Show information. Do you have it set this way already? 2
Tranquil 95 Posted June 1, 2015 Author Posted June 1, 2015 Thanks Angelblue05! Found it!! You guys are doing a great job!! 1
