ddecaro 4 Posted June 1, 2015 Posted June 1, 2015 Hi Team, It seems each time I have set up EMBY on my Linux Mint MATE 17 AMD64, i can stream from any browser on a computer but then it fails when trying to play from an App (Rolu, android phone, Android tablet.) Server: Linux Mint 17 (Ubuntu 14.04) EMBY Version 3.0.5621.4 Roku 2: <- does not work EMBY verision 2.07 - sided loaded from this link Android phone: <- does not work Note 2 OS: CyanogenMod 12-20141220-UNOFFIXIAL-t0ltatt App: Emby for Android Works: Windows 8.1 IE 11 Chrome: version 43.0.2357.81 m Things i have tried: Fresh install of my OS each time I reinstalled EMBY Tried installed per Debian direction Tried installing per Ubuntu 14.4 direction Tried installing per docker Tried installed with my user verse using the emby user Stood up WIN7 VM, installed EMBY and confirmed both ROKU and Android phone can stream from it tried to figure out how to dongrade MONO and was unsuccessfuly tried disabling DLNA RokuTelnetLogs.txt server-63568686904.txt transcode-734416ed-7cd1-453c-8e38-1bcd0f9c8f47.txt
Luke 42243 Posted June 1, 2015 Posted June 1, 2015 You've got a really old version of ffmpeg Reading option '-hls_base_url' ...Unrecognized option 'hls_base_url'. 1
Solution ddecaro 4 Posted June 1, 2015 Author Solution Posted June 1, 2015 Thanks for the quick reply. That fixed my issue. I ran ffmpeg -version that showed I was on ffmpeg version 1.2.6-7:1.2.6-1~trusty1 A quick google search showed Ubunte removed ffmpeg from there official repository. I was able to find a way to update ffmpeg to version 2.6.3 and it fixed all my streaming apps. 1
mengine 0 Posted January 23, 2016 Posted January 23, 2016 Also had the same problem. Updating ffmpeg solved the playback issue. But I am not able too seek into the movie. Does anybody else have this issue?
