7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 Can you share a file with me that won't play via dropbox or OneDrive or similar? Need the file locally to figure it out
Xzener 729 Posted June 27, 2015 Posted June 27, 2015 (edited) Vicpa, how does it fail exactly? Does it have the failure notification after it doesn't play? I have one, it has TrueHD for audio. I will test a few movies when I get home. My DTS-HD MKVs seem to play fine. Edited June 27, 2015 by Xzener
Vicpa 612 Posted June 27, 2015 Posted June 27, 2015 (edited) Hi, They give a message "The video failed to play". 7Illusions PM'd you a link to a file. I assume the DTS-HD's mkv's are being transcoded unless you know some magic I don't. (I really hope you do !). The ones that I have that don't seem to play are high bitrate rips, If you have any with ac3 audio with a bit rate over 3000kps give them a try. This is info on the file I uploaded for 7 Video Codec H264Profile HighLevel 30Resolution 720x480Aspect ratio 4:3Anamorphic NoInterlaced NoFramerate 23.97602Bitrate 3408 kbpsBit depth 8 bitPixel format yuv420pRef frames 2CABAC Yes Audio Language engCodec AC3Layout 5.1Channels 6 chBitrate 375 kbpsSample rate 48000 khzDefault Yes Xzener it will be great to hear your results. Want to make sure I not doing something wrong with my rips. Thanks! -Vicpa Edited June 27, 2015 by Vicpa
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 Well, normally, HD audio is usually packaged with ac3 (I think). All of my BD rips to MKV are either TrueHD or DTS-HD. All of them play fine in the web client. So transcoded movies that play fine in the web client SHOULD play fine in the W8.1 app. I miss Tikuf during times like this. We'll figure it out. I will be home in a couple hours, I will run some tests. Vicpa, which movie is failing for you? One of mine is American Sniper.
Luke 42240 Posted June 28, 2015 Posted June 28, 2015 The best person that you need to figure it out is already here in this thread with you. 7 knows the Win 8.1 formats better than anyone.
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 I just played the first 5 minutes of this file with no issues. It did transcode though
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 (edited) I don't believe a TrueHD track within a rip can also contain the AC3 version of audio. Though you can have a separate TrueHD and AC3 track in the same mkv. I think DTS-HD/DTS is the only codec where both can be contained in a single track and the audio equipment determines which one to play without any transcoding. With TrueHD you have to convert it if needed either during ripping process or transcode while playing if your equipment doesn't support lossless. Edited June 28, 2015 by FrostByte
Vicpa 612 Posted June 28, 2015 Posted June 28, 2015 Hi, Sorry If I am confusing the issue. Transcoding playback is just fine. 7 and I are trying to hammer out a direct stream issue I am having in Win 10. MKV support is in there h264/h265 and ac3/acc audio. Most mkv's that meet that criteria direct stream/play just fine. Some like the examples above don't. They play directly just fine in the native win 10 apps mvoies/tv or video preview. Xzener a couple a examples are Cast Away, Modern Times (1936) and Munity on the Bounty (1935).
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 Sorry, my bad. I missed the direct streaming in Win10 part.
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 I did too... No W10 here yet. July29 can't come soon enough.
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 Now that I'm awake. Can the number of songs it grabs out of a playlist for Shuffle be increased? Either an option, or set to 100 songs which is what I believe the webclient is set at now. Right now the app looks like it's only grabbing 50 songs. 100 songs would get you about 5 hours of music if you don't skip too many songs. Thanks, works great
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 (edited) Experiencing something strange. No other movie (that I have seen yet) does this... When I enter "Chappie" details page, the app closes. Anyone else seen anything like this?? Also, video backdrops (VBD) are not stopping when backing out of details pages. It continues to play behind backdrops. Edited June 28, 2015 by Xzener
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 I just ripped this one yesterday (haven't seen it yet though). Looks like the info page comes up good, tried a few others and nothing like that yet.
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 I don't believe a TrueHD track within a rip can also contain the AC3 version of audio. Though you can have a separate TrueHD and AC3 track in the same mkv. I think DTS-HD/DTS is the only codec where both can be contained in a single track and the audio equipment determines which one to play without any transcoding. With TrueHD you have to convert it if needed either during ripping process or transcode while playing if your equipment doesn't support lossless. The same MKV (TrueHD) transcodes and plays on other clients. Ok, this time the app says its transcoding but the video never started. It didn't fail like before. This looks to be the same problem Vicpa is having. Here is my transcode log... http://192.168.1.16:8096/mediabrowser/videos/50b0e23bf3bf1f6da19c769a3d96c869/hlsdynamic/main/0.ts?DeviceId=CABP4wUA3koFABCcBgABAAQAgAAEAHX6AQDqxwIAFKUJAJpq&MediaSourceId=50b0e23bf3bf1f6da19c769a3d96c869&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=9680000&AudioBitrate=320000&Level=51&ClientTime=635710602593931116&MaxVideoBitDepth=8&Profile=high&PlaySessionId=38080ee43290403baa24d9c14f3b2883&api_key=9ac38fd5780c443c935e4a976a65feff {"Protocol":"File","Id":"50b0e23bf3bf1f6da19c769a3d96c869","Path":"\\\\SERVER-PC\\H\\HD Movies\\American Sniper\\title00.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/TRUEHD","RunTimeTicks":79598680000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":28891855,"BitDepth":8,"RefFrames":2,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false,"IsCabac":true},{"Codec":"truehd","Language":"eng","IsInterlaced":false,"ChannelLayout":"7.1","Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"pgssub","Language":"eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":["mkv","webm"],"Bitrate":28891855,"RequiredHttpHeaders":{}} C:\Users\Server\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -i file:"\\SERVER-PC\H\HD Movies\American Sniper\title00.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 9680000 -bufsize 19360000 -vsync vfr -profile:v high -level 51 -force_key_frames expr:gte(t,n_forced*3) -flags +loop-global_header -sc_threshold 0 -codec:a:0 aac -strict experimental -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -y "C:\Users\Server\AppData\Roaming\MediaBrowser-Server\transcoding-temp\32d7bb1e9e06fbda25b688d3080feb0f.m3u8" ffmpeg version N-71182-g5cba529 Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 [matroska,webm @ 0000000002cd16a0] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from 'file:\\SERVER-PC\H\HD Movies\American Sniper\title00.mkv': Metadata: encoder : libmakemkv v1.9.2 (1.3.0/1.4.1) win(x64-release) creation_time : 2015-06-10 04:55:33 Duration: 02:12:39.87, start: 0.000000, bitrate: 28891 kb/s Chapter #0:0: start 0.000000, end 615.197917 Metadata: title : Chapter 01 Chapter #0:1: start 615.197917, end 1136.635500 Metadata: title : Chapter 02 Chapter #0:2: start 1136.635500, end 1707.539167 Metadata: title : Chapter 03 Chapter #0:3: start 1707.539167, end 2344.383708 Metadata: title : Chapter 04 Chapter #0:4: start 2344.383708, end 3057.387667 Metadata: title : Chapter 05 Chapter #0:5: start 3057.387667, end 3606.686417 Metadata: title : Chapter 06 Chapter #0:6: start 3606.686417, end 4076.197125 Metadata: title : Chapter 07 Chapter #0:7: start 4076.197125, end 5323.943625 Metadata: title : Chapter 08 Chapter #0:8: start 5323.943625, end 5844.713875 Metadata: title : Chapter 09 Chapter #0:9: start 5844.713875, end 6357.017333 Metadata: title : Chapter 10 Chapter #0:10: start 6357.017333, end 6883.960417 Metadata: title : Chapter 11 Chapter #0:11: start 6883.960417, end 7453.362583 Metadata: title : Chapter 12 Chapter #0:12: start 7453.362583, end 7959.868583 Metadata: title : Chapter 13 Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default) Metadata: title : Surround 7.1 Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle [libx264 @ 0000000005956400] using SAR=1/1 [libx264 @ 0000000005956400] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 SlowShuffle [libx264 @ 0000000005956400] profile High, level 5.1 [aac @ 0000000005968ce0] Unsupported number of channels: 8 Output #0, hls, to 'C:\Users\Server\AppData\Roaming\MediaBrowser-Server\transcoding-temp\32d7bb1e9e06fbda25b688d3080feb0f.m3u8': Chapter #0:0: start 0.000000, end 615.197917 Chapter #0:1: start 615.197917, end 1136.635500 Chapter #0:2: start 1136.635500, end 1707.539167 Chapter #0:3: start 1707.539167, end 2344.383708 Chapter #0:4: start 2344.383708, end 3057.387667 Chapter #0:5: start 3057.387667, end 3606.686417 Chapter #0:6: start 3606.686417, end 4076.197125 Chapter #0:7: start 4076.197125, end 5323.943625 Chapter #0:8: start 5323.943625, end 5844.713875 Chapter #0:9: start 5844.713875, end 6357.017333 Chapter #0:10: start 6357.017333, end 6883.960417 Chapter #0:11: start 6883.960417, end 7453.362583 Chapter #0:12: start 7453.362583, end 7959.868583 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, max. 9680 kb/s, 23.98 fps, 23.98 tbn, 23.98 tbc Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 0 channels, 128 kb/s (default) Metadata: encoder : Lavc56.32.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (truehd (native) -> aac (native)) Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 (edited) Strange. Thanks FrostByte. Chappie is constantly closing the app. I will try rebooting the PC and report back. This is so weird. Update: Nope, still closing the app. The first time after a reboot it tried to enter but closed before loading the page. Now it just closes right away. Nothing out of the ordinary in the folder... I'm going to try moving it to another HDD, Update: Nope. Still closing the app... Or is it crashing?? @@7illusions can we see log files with your app?? Edited June 28, 2015 by Xzener
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 (edited) 7illusions, Loving VBDs. Just need to get playback to stop when leaving the details page of a movie. Is it possible to hide the"pause/ffw/rew" (see below)?? Is it possible to add a layer in front of the VBD?? The details page adds a smoke colored layer over the backdrop allowing for the description of the movie to be read easily. Some VBDs are bright, its difficult to read the description while the VBD is playing. Edited June 28, 2015 by Xzener
7illusions 1249 Posted June 28, 2015 Author Posted June 28, 2015 Yes, logs are found by bringing out the charms bar -> Settings -> View logs. There should be a Crashlog at the end of the list of logs
7illusions 1249 Posted June 28, 2015 Author Posted June 28, 2015 New build is up, .308 Stops theme when going back out. Added videotheme to Shows. Fixed LiveTV (I think) 2
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 I noticed my wma files just recently are being transcoded again. For awhile they weren't being transcoded after the fixes in streamingprofile. Though it looks like they are being transcoded to 128-bit wma files now and not mp3 like before? Server log: 2015-06-28 09:26:51.0326 Info - App: C:\Users\Rick\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -async 1 -i file:"D:\Music\Presidents of the United States of America\The Presidents of the United States of America (1995)\06 - Peaches.wma" -threads 0 -vn -ac 2 -id3v2_version 3 -write_id3v1 1 -y "C:\Users\Rick\AppData\Roaming\MediaBrowser-Server\transcoding-temp\472cf014a8229a189108312f729be18d.wma"2015-06-28 09:26:56.5099 Info - App: FFMpeg exited with code 02015-06-28 09:28:21.6748 Info - App: Udp message sent to 192.168.1.129:492272015-06-28 09:28:40.4930 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.. Exception.Message: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Transcode log" http://pastebin.com/Z6wY4Hum Media info of transcoded file: Info for original file:
7illusions 1249 Posted June 28, 2015 Author Posted June 28, 2015 I don't have any wma files, do you think you could share that album?
7illusions 1249 Posted June 28, 2015 Author Posted June 28, 2015 Nevermind, just ripped an album to wma
FrostByte 5453 Posted June 28, 2015 Posted June 28, 2015 Oh, I was uploading one already, but it definitely would have taken longer, slow uploading to OneDrive.
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 Experiencing something strange. No other movie (that I have seen yet) does this... When I enter "Chappie" details page, the app closes. Anyone else seen anything like this?? Also, video backdrops (VBD) are not stopping when backing out of details pages. It continues to play behind backdrops. Fixed. Not sure what you did 7, but its not doing it anymore. Fixed. Well done! 1
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 Can we replace the video loading circle with the app loading circle?? The video loading circle is dated IMO. The app laoding one looks better. 7, are you able to use Microsofts loading circle for videos in the app? Looks better IMO.
Xzener 729 Posted June 28, 2015 Posted June 28, 2015 7, any plans for adding community rating, Rotten Tomatoes, Watched indicator toggle, add to favorites to details page??
