Xzener 729 Posted June 26, 2015 Posted June 26, 2015 (edited) Just bring out the Charms-menu -> Settings -> General -> Show text on posters. This must be broken then. Was already set to off. Toggling off/on has no effect. Labels continue to display. Edit: It's only working for Main Menu. Selecting "HD Movies" (per my example pic), labels showing regardless of setting on/off. Edited June 26, 2015 by Xzener
Xzener 729 Posted June 26, 2015 Posted June 26, 2015 Can we replace the video loading circle with the app loading circle?? The video loading circle is dated IMO. The app laoding one looks better.
Xzener 729 Posted June 26, 2015 Posted June 26, 2015 (edited) Also, regardless of which VF I'm browsing (HD Movies, TV Series) the most recent media added backdrops are being shown behind the posters/covers. Shouldn't it be related to the VF being browsed? i.e. My recent "DVD Movie" backdrop is displaying in my "TV Series" VF. Edited June 26, 2015 by Xzener
Xzener 729 Posted June 26, 2015 Posted June 26, 2015 It's just that I don't have any moviebackdrops to test with. If you have any videobackdops to share with me, I can try to add it asap. Here is one for the movie "Iron Man". One of my favorites... https://www.dropbox.com/s/9ueinnf4cckwmdr/theme.mp4?dl=0 1
Scott84Z28 39 Posted June 26, 2015 Posted June 26, 2015 @@7illusions You can basically use any video file, as long as it's in the backdrops folder and the file is called theme.something. Here's one for The Avengers. https://drive.google.com/file/d/0B1D0BH_ZuC0dWVU2b18tc3lidGs/view?usp=sharing Looks like Xzener beat me to it. One of thing I noticed while testing. I use a keyboard as my input (dinovo mini) and I run into a problem when I browser to a TV show, and in the details section of the episode, I can't arrow down to the play or the tripple dot button. I always have to switch to mouse mode and click on play. Or am I missing something? Is there a way to use the keyboard? What are people doing that use remotes? Loving this so far btw. It'll be my Emby Classic replacement when I switch to Win10. 1
Xzener 729 Posted June 26, 2015 Posted June 26, 2015 If I enter details of a movie, focus doesn't look to be set to the play button but if I click "Ok" on my remote, it starts to play. I'd imagine hitting enter should do the trick.
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 New build is up. First attempt on Video-backdrops, please try it out 1
FrostByte 5453 Posted June 27, 2015 Posted June 27, 2015 Any chance you can add shuffle for music playback?
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 (edited) New build is up. Will this be good enough for shuffle? It will be in both playlist and album view Or do you want a toggle-button to turn it on and off for the player? Edited June 27, 2015 by 7illusions 1
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 Toally OffTopic: Where do one find VideoBackdrops for download? Kind of want to add a few now when the app supports it. 1
bluemonkey07 590 Posted June 27, 2015 Posted June 27, 2015 Radeons video themes plugins download them automatically 1
FrostByte 5453 Posted June 27, 2015 Posted June 27, 2015 New build is up. Will this be good enough for shuffle? It will be in both playlist and album view That's all I would need, thank you very much 7.
FrostByte 5453 Posted June 27, 2015 Posted June 27, 2015 (edited) Will it be able to Play To Shuffled then? Would like the option to play shuffled playlist to my HTS as well as from the computer I guess. Edited June 27, 2015 by FrostByte
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 You can shuffle and play locally, then go to Now Playing view and bring up the app bar and click the "Transfer playlist" button. 1
Vicpa 612 Posted June 27, 2015 Posted June 27, 2015 Hi 7, Like the shuffle option !! Did you get a chance to hook up the ellipse button to something on the remote? still having the mkv issue and live tv isn't working for me.
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 Sorry Vicpa, Totally had forgotten about the mkv stuff. Can you try again with the latest build? (.304) Still nothing with the ContextMenu and remote, will look into soon.
Vicpa 612 Posted June 27, 2015 Posted June 27, 2015 Hi, Tried with 304 still no luck. I raised the maxstatic bitrate all the way up to 500000000. . Is that the number I need to change.? This is an example of one that won't play.
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 .305 is up, Can you give it another go? It should now respect the MaxStaticBiirate value (I hope. )
Xzener 729 Posted June 27, 2015 Posted June 27, 2015 Can't wait to get home and try these builds... Did you fix the poster/cover label issue 7??
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 Xzener, jst uploaded .06, it has your fix. Vicpa, do I have access to your server? I would REALLY like to debug against this one.
Vicpa 612 Posted June 27, 2015 Posted June 27, 2015 (edited) Yes Your account is still active same password as before. modern times or munity on the bounty are examples that won't play Edited June 27, 2015 by Vicpa
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 Vicpa, one more thing to test. There's a MaxStreamingBitrate that is set to 1000000 in the profile, can you try to increase that to 5000000?
7illusions 1249 Posted June 27, 2015 Author Posted June 27, 2015 Yet another build .307 (I'll stop spamming you guys now) Fixes an issue where sometimes a videobackdrop wouldn't play.
