FrostByte 5453 Posted June 3, 2015 Posted June 3, 2015 Or, create a random play button and I wouldn't have to do it manually every time
7illusions 1249 Posted June 4, 2015 Author Posted June 4, 2015 (edited) First post updated with new version Fixes: Remote navigation.issue. Screensaver issue. Lots of communication issues when using connect. Now Playing not showing on mainview Sync-button on sync flyout is now a little bit more "button-like" Edited June 4, 2015 by 7illusions 1
Vicpa 612 Posted June 5, 2015 Posted June 5, 2015 (edited) ]Hi, Here is some feedback on 297. Remote navigation issue. Backspace works from offline hub. Not from TV/ Series hub. Return on MCE remote doesn't work from either place. Screensaver issue.- -Kicks in on main hub, timing seems real short when you come back from another hub. Crashes app sporadically (win 10 log attached), will attempt to reproduce on win 8.1 Lots of communication issues when using connect. Now Playing not showing on mainview -Fixed Sync-button on sync flyout is now a little bit more "button-like" - I thought it was fine, now it disappears with mouse over. Thanks! -vicpa Log - 20150605.log Edited June 5, 2015 by Vicpa
FrostByte 5453 Posted June 5, 2015 Posted June 5, 2015 I have yet to get the screensaver to crash on 8.1, agree that it's a bit quick to kick off. Maybe an option to set time can be added in the future
7illusions 1249 Posted June 5, 2015 Author Posted June 5, 2015 Quick question: "Return" with MCE remote, what is the expected behavior? Same as mouse-click I guess but I want to make sure.
7illusions 1249 Posted June 5, 2015 Author Posted June 5, 2015 the quick screensaver is my fault. I changed the delay for debug purposes and forgot to change it back. 1
Vicpa 612 Posted June 5, 2015 Posted June 5, 2015 Hi, Yes return would be the same as backspace. Return to previous screen.
Lee 212 Posted June 5, 2015 Posted June 5, 2015 Return=enter doesn't it? Therefore mce remote ok button??
Vicpa 612 Posted June 5, 2015 Posted June 5, 2015 Hi, No I think it is Key press "Enter" = "OK" on the remote and Key press "backspace" = "Return" on the remote. Same as clicking on the back arrow on the screen. -Vicpa
ScottIsAFool 517 Posted June 5, 2015 Posted June 5, 2015 the quick screensaver is my fault. I changed the delay for debug purposes and forgot to change it back. #if DEBUG #else #endif
7illusions 1249 Posted June 6, 2015 Author Posted June 6, 2015 LOL!! Would have worked, except that all builds used here are Debug builds.
7illusions 1249 Posted June 6, 2015 Author Posted June 6, 2015 First post updated with new build. Screensaver timer changed Syncbutton should be a little clearer when hovering @@techywarrior can you have a look at the Hubs for newest tv/movie, I might have caught a stupid cache-bug which might have been the cause of wrong items showing .. @@Vicpa , can you test the remote stuff again? My MCE doesn't have a Return button so I had to wing it, hopefully Igot it right.
techywarrior 689 Posted June 6, 2015 Posted June 6, 2015 Newest/Latest seems fine but TV Next Up is displaying stuff that isn't in the library. How can I see what version the app is? I thought it used to be in one of the settings menu but I couldn't find it anymore (on my WIn10 machine if it makes a difference).
Vicpa 612 Posted June 6, 2015 Posted June 6, 2015 Hi, " can you test the remote stuff again? My MCE doesn't have a Return button so I had to wing it, hopefully I got it right. ;)" Yikes!! Hadn't thought about that. Yes it is working from the TV Hub. Something about the Online hub win 10 doesn't like. Remote "back" button doesn't work. But neither does the mouse click on the back arrow. (Don't know if we are troubleshooting on 10 something for the list anyway) Win 8 mouse click works from online hub. Don't have a remote on my win 8 app at the moment. I don't know how you are capturing it, on my keyboard the keypress is the "backspace/back arrow key". On one of my remotes it is the return button, on another MCE remote it is the back arrow., Button code 35 MS description-- Back Button space: Microsoft Required Icon: Label: BACK Button code: 35 First press action: Moves back one position in the user interface stack. Second press action: Repeats first press action. Auto-repeat: No If button codes are of any help I finally stumbled across a complete listing let me know if you need it. While we are on back buttons on the login screen - navigation steps skip connect/ pick server / click on user/ enter password screen, back button doesn't work there, no way to get back to pick different user. I also noticed there that the user name is truncated at the first space. I have a user "ernie & joyce" , shows on the enter password screen as ernie. password doesn't work. Can correct the user to ernie & joyce and then password = good to go. Screensaver - Timing seems fine. Did have one crash to desktop on Win 8 machine. Mouse movement from music detail screen. Not a lot of detail. 102|2015-06-06T15:58:37.0082279+00:00|FATAL|3|Application|The application crashed: Unspecified error Sequence: 102Date/time: 2015-06-06T15:58:37.0082279+00:00Level: FATALThread: 3Logger: Application------------------------The application crashed: Unspecified error ------------------------Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.4.0.298_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.4.0.298","InstallationId":"986b2c5a-50b5-4537-b167-7521141f3815"} I agree with techywarrior. version number shows up under permissions in the settings charms menu under win 8. Permissions isn't in there in Hamburger, settings under win10. -Vicpa
Vicpa 612 Posted June 6, 2015 Posted June 6, 2015 BTW If you are doing work on the remote If we could get the "play/ok" button working on the music hub screens like Movies and TV. MCE remote support would be just about complete. Only thing left would be a way to bring up the "more" or ellipsis button and some minor navigation/focus things. but I could live with that for a while, lol. It would be a nice win for those using the app as the 10 foot client of choice and/or media center replacement. Thanks!! -Vicpa
7illusions 1249 Posted June 7, 2015 Author Posted June 7, 2015 New buildis up. Added the MCEPlay-button to MusicViews. All reported bugs should be sorted. Lets go find some new ones. 1
FrostByte 5453 Posted June 7, 2015 Posted June 7, 2015 (edited) There seems to be some kind of refresh issue with music artists when scrolling left and right. Some are being refreshed, others are not. If I go to another page and come back the correct pic is displayed. I am playing music from a playlist at the time Here is a pic of the webclient. Notice some artists do not have pics. Here is a pic from the app. Notice the Group 3OH!3 looks a lot like Jerry Cantrell of Alice in Chains Edited June 7, 2015 by FrostByte
FrostByte 5453 Posted June 7, 2015 Posted June 7, 2015 (edited) I can get it to do this every time if I take the mouse and drag the scroll button at the bottom left or right quickly. It will stay the wrong image until I go to another screen and then come back Edited June 7, 2015 by FrostByte
7illusions 1249 Posted June 8, 2015 Author Posted June 8, 2015 Anyone got an idea of which MCE-button to use for the "ellipses" button? (Basically I need a "more" button.)
Vicpa 612 Posted June 8, 2015 Posted June 8, 2015 Hi, The additions for the remote are great!!. Just need one more ok/play on playlist screen (see pic for the one I mean) New to this build I did a uninstall/reinstall (on win 10 machine) so if someone could check win 8. The sync screen has some glitches Can't seem to select quality or sync to local machine. Can sync etc to different machine. See pic Live TV.. This is still not working for me. click play nothing happens (win8,10) 7 it would be awesome if we could get a remote button for the ellipse I would vote for the info button. can't discern standard keyboard equivalent, but in MS speak: More Info ButtonButton space: Microsoft RequiredIcon: Circle with an i inside one remote or just a lowercase i on anotherLabel: MORE INFO or INFOButton code: 15First press action: Provides information for the focus point (if information is available).Second press action: Hides displayed information.Auto-repeat: No Thanks!!!! Will continue to test -Vicpa
7illusions 1249 Posted June 9, 2015 Author Posted June 9, 2015 Unfortunately the info-button is being captured by the appbar and I don't even get the event for that key. Any other suggestions?
Vicpa 612 Posted June 9, 2015 Posted June 9, 2015 Well that stinks. Not sure what options we have but I would say one of these * # . (period) Or one the color keys.(Maybe you know what they are for. They are on every remote I have and I have yet to find anything they do ) -vicpa
7illusions 1249 Posted June 9, 2015 Author Posted June 9, 2015 (edited) New build is up. Please verify the context-menus. (ellipses) I hadto write my custom one to replace the old in order to support MCE navigation. This is just step one though since I haven't actually wired a button to show the menu yet. but, if you open up the menu you should be able to move up and down using he remote. (Pressing back will NOT behave correctly though) Also sorted the NextUp not respecting the TopParentId. Edited June 9, 2015 by 7illusions
