tornadotj 6 Posted July 21, 2015 Posted July 21, 2015 Well, you put me on the right path, pun intended. It was a rights issue. i'm not sure why, I have the directory shared with no credentials required, but I guess for some reason the OpenELEC/Kodi PC needed them. I won't post logs, it's working and I'm OK leaving the credentials in the config. 1
Cirkator01 1 Posted July 21, 2015 Posted July 21, 2015 It's now a separate addon in Kodi http://forum.kodi.tv/showthread.php?tid=228435 Thank you very much! This looks amazing :-)
Eternally 1 Posted July 24, 2015 Posted July 24, 2015 (edited) Hi I recently updated Kodi to Kodi 15.0 now emby the plugin is broken for me what is the schedule for the next emby update. In the meantime I could downgrade from the current version of Kodi that I am using. I am running Kodi on linux. Edited July 24, 2015 by Eternally
CBers 7554 Posted July 24, 2015 Posted July 24, 2015 Hi I recently updated Kodi to Kodi 15.0 now emby the plugin is broken for me what is the schedule for the next emby update. In the meantime I could downgrade from the current version of Kodi that I am using. I am running Kodi on linux. In what way is it broken? You may need to do a Kodi database reset from within the addon.
Eternally 1 Posted July 24, 2015 Posted July 24, 2015 In what way is it broken? You may need to do a Kodi database reset from within the addon. Sorry I should probably have been more specific my pass want be accepted by my server, I will try your suggestion by resetting the addon.
Eternally 1 Posted July 24, 2015 Posted July 24, 2015 I tried what you said it worked when I reset it and entered all the login information. But when I exit Kodi the server accepts the pass but the Titan logo just keeps on loading. If I reset everything again then it works with the same procedure, its defaintly better then nothing, Could it be because I am using a to long pass, When I was in my last Kodi version then there was a different problem I had to enter the pass everytime on starting Kodi. I am also using HTTPS in Kodi if I turn that off its still the same problem.
AlwinHummels 134 Posted July 28, 2015 Posted July 28, 2015 I've a strange problem on my Rpi2 Allw works fine exept music I've embi for Kosi 1.13 stable repo and when I do a manual or fulls scan music fails but I can't figure out why. See log here http://xbmclogs.com/pg2srvvec If you need more please let me know and I try to give you the information.
im85288 1493 Posted July 28, 2015 Posted July 28, 2015 I've a strange problem on my Rpi2 Allw works fine exept music I've embi for Kosi 1.13 stable repo and when I do a manual or fulls scan music fails but I can't figure out why. See log here http://xbmclogs.com/pg2srvvec If you need more please let me know and I try to give you the information. This line in your log looks worrying: Server unreachable at: http://192.168.192.20:8096/mediabrowser/Users/c05ce082774747f9b471100932691c64/Items/f406d87717be90c7212d61d6bb4dc670?format=json&Fields=Path,Genres,SortName,Studios,Writer,ProductionYear,Taglines,CommunityRating,OfficialRating,CumulativeRunTimeTicks,Metascore,AirTime,DateCreated,MediaStreams,People,Overview Are you sure the server did not crash during the sync?
AlwinHummels 134 Posted July 28, 2015 Posted July 28, 2015 (edited) This line in your log looks worrying: Server unreachable at: http://192.168.192.20:8096/mediabrowser/Users/c05ce082774747f9b471100932691c64/Items/f406d87717be90c7212d61d6bb4dc670?format=json&Fields=Path,Genres,SortName,Studios,Writer,ProductionYear,Taglines,CommunityRating,OfficialRating,CumulativeRunTimeTicks,Metascore,AirTime,DateCreated,MediaStreams,People,Overview Are you sure the server did not crash during the sync? When I click on that link i get: {"ResponseStatus":{"ErrorCode":"SecurityException","Message":"Access token is invalid or expired.","StackTrace":" at MediaBrowser.Server.Implementations.HttpServer.Security.AuthService.ValidateSecurityToken (IServiceRequest request, System.String token) [0x00000] in <filename unknown>:0 \n at MediaBrowser.Server.Implementations.HttpServer.Security.AuthService.ValidateUser (IServiceRequest request, IAuthenticationAttributes authAttribtues) [0x00000] in <filename unknown>:0 \n at MediaBrowser.Server.Implementations.HttpServer.Security.AuthService.Authenticate (IServiceRequest request, IAuthenticationAttributes authAttribtues) [0x00000] in <filename unknown>:0 \n at MediaBrowser.Controller.Net.AuthenticatedAttribute.RequestFilter (IRequest request, IResponse response, System.Object requestDto) [0x00000] in <filename unknown>:0 \n at ServiceStack.ServiceStackHost.ApplyRequestFiltersSingle (IRequest req, IResponse res, System.Object requestDto) [0x00000] in <filename unknown>:0 \n at ServiceStack.ServiceStackHost.ApplyRequestFilters (IRequest req, IResponse res, System.Object requestDto) [0x00000] in <filename unknown>:0 \n at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) [0x00000] in <filename unknown>:0 "}} But I think I found the problem now I disabled the NFS for my music share and now it's scanning all my music again. no idea why it not works when the NFS is enabled on my share (Synology DS415+) Edited July 28, 2015 by AlwinHummels
Spaceboy 2573 Posted July 28, 2015 Posted July 28, 2015 (edited) hi, i had to install the latest isengard (19/07) nightly in order to get my live tv plugin working and since doing this i get a Emby Error when opening Kodi, looking at the log it says: 17:54:10 T:3700 NOTICE: EMBY UserClient -> |---- Starting UserClient ----| 17:54:10 T:3700 NOTICE: EMBY UserClient -> Current user: Mark 17:54:10 T:3700 NOTICE: EMBY UserClient -> Current userId: a33fbab2059b4b8d9dc6444e7d255950 17:54:10 T:3700 NOTICE: EMBY UserClient -> Current accessToken: fd092260cd664e508521ce4f213c6c89 17:54:11 T:8664 NOTICE: Sync DB -> syncDatabase Exiting 17:54:11 T:8664 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.KeyError'> Error Contents: (u'Items',) Traceback (most recent call last): File "C:\Users\Mark\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py", line 259, in <module> Service().ServiceEntryPoint() File "C:\Users\Mark\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py", line 146, in ServiceEntryPoint libSync = librarySync.FullLibrarySync() File "C:\Users\Mark\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\LibrarySync.py", line 89, in FullLibrarySync self.MusicVideosFullSync(connection,cursor,pDialog) File "C:\Users\Mark\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\LibrarySync.py", line 216, in MusicVideosFullSync allEmbyMusicvideos = ReadEmbyDB().getMusicVideos() File "C:\Users\Mark\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\ReadEmbyDB.py", line 56, in getMusicVideos if (jsonData[u'Items'] != ""): KeyError: (u'Items',) -->End of Python script error report<-- things play, it just seems that the database is not syncing edit seems to have gone away Edited July 28, 2015 by Spaceboy
e123enitan 276 Posted July 29, 2015 Posted July 29, 2015 Project Team -I was trying to deduced error in Titan skin, then I spotted several other errors, any ideas why? http://xbmclogs.com/pafxqxasx http://xbmclogs.com/pvoxzk1vj
Angelblue05 4132 Posted July 29, 2015 Posted July 29, 2015 (edited) First log - the episodes skipped were due to missing season number. Check your metadata manager and assign season numbers to the episodes, then they will be scanned into Kodi properly. The second - seems your internet connection went out. Or something along these lines. Edited July 29, 2015 by Angelblue05
Spaceboy 2573 Posted July 29, 2015 Posted July 29, 2015 Hi, do only libraries containing music, TV or movies get synced by emby for kodi. if I have videos marked as home videos in a library they do not seem to be available in emby for kodi. Cheers
xnappo 1611 Posted July 29, 2015 Author Posted July 29, 2015 Correct - Home Movies are on our Trello board but are not currently supported. 1
AlwinHummels 134 Posted July 31, 2015 Posted July 31, 2015 (edited) I've just installed 1.1.8 from the beta repo and I use the latest version of OpenElec Kodi 16 build 0730 (31 Juli) on my Rpi2 but I've still problems with my music scanning. No error but Sync stops after the Artists sync so my Albums and track are never Synced. Is there something I've missed? I know I know it's still beta but I like to have the newest stuff and test things out See my Log: http://xbmclogs.com/p8qm2kotk Edited July 31, 2015 by AlwinHummels 1
StealthDefender 29 Posted July 31, 2015 Posted July 31, 2015 I've just installed 1.1.8 from the beta repo and I use the latest version of OpenElec Kodi 16 build 0730 (31 Juli) on my Rpi2 but I've still problems with my music scanning. No error but Sync stops after the Artists sync so my Albums and track are never Synced. Is there something I've missed? I know I know it's still beta but I like to have the newest stuff and test things out See my Log: http://xbmclogs.com/p8qm2kotk Thats also my problem.Stable Version do the same. I think its about codecs or something (flac, vob, etc) not sure about it. In fact the addon try every time i restart my htpc a full resync but break somewhere at albums or artists?!? Greetz Stealth
StealthDefender 29 Posted August 3, 2015 Posted August 3, 2015 (edited) Hey guys, all work nice at the moment so far. But one strange thing happened on all my machines. The music sync shows the wrong "last added" in kodi! On the server it is correct but kodi shows only the wrong albums. Greetz Stealth Edit: Is it normal that every time a full sync is done a next one starts?!? Since 2 hours the addon syncs all time long! Edited August 3, 2015 by StealthDefender
Tranquil 95 Posted August 4, 2015 Posted August 4, 2015 No, there should be no complete resync everytime. Kodi just checks the complete library for changes, but that is much faster then a complete resynch. Maybe you should try resetting your library and do a complete synch once again. Do not interrupt this process. Hopefully your problem is solved then.
Angelblue05 4132 Posted August 4, 2015 Posted August 4, 2015 (edited) @@StealthDefender Missed your post, it's always best to just start a new thread to make sure your issue gets maximum visibility The scan will restart if it's unable to complete. It will keep trying until it succeeds. I do think I managed to resolved the music situation with the latest beta version 1.1.25 but it's still very early to say. For now, I suggest you simply disable music sync in your add-on settings. The sync should then complete correctly and will not happen the next time you restart Kodi. What I did notice is the issue seems to affect people with large music libraries... The query to the server to pull every single item would timeout and the sync would fail. If this is your case, then you can always give beta a try or wait until the fix makes it to Stable Edited August 4, 2015 by Angelblue05 1
StealthDefender 29 Posted August 4, 2015 Posted August 4, 2015 Hey thx for answer! If its better for you guys to do a new thread for every question i will do it, but in my case the situation is not too bad that i can not wait a bit ;-) Yes indead, i have a huge music database, the feauture to sync it with emby is a great solution so i can wait for stable! :-D Only thing that confuses me is the last added issue that i have mentioned a few post before! Have a nice day Greetz Stealth
Angelblue05 4132 Posted August 4, 2015 Posted August 4, 2015 (edited) I think I see the same problem on my side with last added as well. I've added it to our trello board so one of us can look more into it when we have a moment: https://trello.com/c/JKaClAXL/125-last-added-seems-incorrect-for-music Edit: Actually it seems to be an easy fix, so it will be fix next beta version. Edited August 4, 2015 by Angelblue05 1
StealthDefender 29 Posted August 4, 2015 Posted August 4, 2015 @@Angelblue05 Great news, but i think i wait to stable, got a bunch of issues last time i switched from stable to beta and vice versa! Greetz Stealth
lja 51 Posted August 6, 2015 Posted August 6, 2015 Is the XBMB3 plugin still required with Emby for Kodi?
