ars92 4 Posted June 29, 2015 Posted June 29, 2015 Thank you, I will create the version for stable. When im85288 or xnappo have a moment they will include it into the repo. A new release is going to come for stable soon to remove the beta feature that was accidentally included, and also to fix a bug that might affect certain ppl. Is this with the latest stable release version 1.1.0? Awesome!! Just so you know, I just watched two episode of different shows using Emby for Kodi few hundred kilometers away from my server, and everything worked flawlessly!! Fast loading, subtitles, just great!! Thanks for the hard work you guys have done to completely revamp the way emby works with kodi. Its so fast to sync that I dont care even if I had to reset the database everytime an update was released lol. Might try the video and theme music addon soon, and also the cinema mode to see how well it all works. Thanks again!! 4
Angelblue05 4132 Posted June 29, 2015 Posted June 29, 2015 Awesome! We'll feel free to switch to Beta version to keep trying the alternate server address feature as it is removed from Stable v 1.1.1. It is an untested feature, so thanks for reporting!
jjdavola 0 Posted June 29, 2015 Posted June 29, 2015 Is my issue that difficult to solve? I thought I was just missing an easy, n00b step to get images recognized in Kodi.
ars92 4 Posted June 29, 2015 Posted June 29, 2015 Awesome! We'll feel free to switch to Beta version to keep trying the alternate server address feature as it is removed from Stable v 1.1.1. It is an untested feature, so thanks for reporting! Will do! [emoji2] Sent from my SM-N910C using Tapatalk
Jibest 27 Posted June 30, 2015 Posted June 30, 2015 1. On the to do list. 2. You can easily create playlists in Kodi for now. 3. Not sure what you mean? 4. It should work as long as the server address you put in is your external one. Since Emby connect is not integrated, on the to do list but documentation is lacking when not using the prebuilt api client, this one will take longer. So right now, you can add a secondary account that you'd use while being away. Then you can direct stream or transcode depending on your internet connection. Check out our trello board for easy reference: https://trello.com/b/qBJ49ka4/emby-for-kodi Hi, how do add in a feature request on the Trello boards for people to vote on? I would like to request that Emby playlists appear within Kodi
Jibest 27 Posted June 30, 2015 Posted June 30, 2015 Quick question regarding adding the server in Kodi. If I enter in my dynamic dns name (also remote details in Emby Server). The server connects and I can view my media. But will this still be playing just over the lan when i'm at home? Or will it be sending data over the internet as if i'm in a remote location?
adamnmcc 1 Posted June 30, 2015 Posted June 30, 2015 (edited) edit: never mind, was running beta. Edited June 30, 2015 by adamnmcc
Angelblue05 4132 Posted June 30, 2015 Posted June 30, 2015 Quick question regarding adding the server in Kodi. If I enter in my dynamic dns name (also remote details in Emby Server). The server connects and I can view my media. But will this still be playing just over the lan when i'm at home? Or will it be sending data over the internet as if i'm in a remote location? It will keep using your dynamic dns even while at home. So t will connect as if from a remote location. I've actually just implement an option for secondary address where you could put the internal address to your server and switch between the two. However this is only availabe in the beta version. It's a brand new feature still need some work like make it automatic if possible, etc... Still looking for feedback on it. If you try it out, let me know how it went. http://emby.media/community/index.php?/topic/19739-emby-for-kodi-beta/?p=223840
bluemonkey07 590 Posted June 30, 2015 Posted June 30, 2015 Quick question regarding adding the server in Kodi. If I enter in my dynamic dns name (also remote details in Emby Server). The server connects and I can view my media. But will this still be playing just over the lan when i'm at home? Or will it be sending data over the internet as if i'm in a remote location?there is a proviso that your router must support hairpinning for this to work within the same lan
Jibest 27 Posted June 30, 2015 Posted June 30, 2015 there is a proviso that your router must support hairpinning for this to work within the same lan Thanks Vidman, I just did a tracert from my home network and one from a remote location pointing to the dynamic dns name and the one from home was far shorter & quicker whereas the remote tracert took far longer with many more entries. I assume this means the router supports hairpinning?
Ryangodammit 0 Posted July 4, 2015 Posted July 4, 2015 Hi guys. Just a few questions, excuse the noobness. I'm new to emby, been using kodi/xbmc for a while now. What machine are you guys running the server on? The same one as kodi? I'm running openelec on a chromebox and I want to install my emby server on the same machine so its on 24/7. How do I do this? Straight from kodi? Or do I use putty or something to ssh the regular linux install into the background? Where is the best place to learn about emby from the very basics up? Still kind of struggling to get my head around it, even more so combined with kodi. Sounds awesome though
im85288 1493 Posted July 5, 2015 Posted July 5, 2015 If you go to the downloads section of the Emby web page you will find the packages for the various versions of the server. I'm not too sure if you can run the server on a chrome box.
bluemonkey07 590 Posted July 5, 2015 Posted July 5, 2015 (edited) It might be easier to use a more complete linux/kodi solution like kodibuntu distro to run emby server and kodi on the same device rather than openelec Edited July 5, 2015 by Vidman
jordy 284 Posted July 9, 2015 Posted July 9, 2015 Hi, installed Kodi/Emby4Kodi last night on my surface Pro 3 - i5 and it's good, very quick. It seems though, that it will only show Libraries designated as Movie or TV. I have a couple of libraries designated "Home Videos" can/will Emby4Kodi show them?
bluemonkey07 590 Posted July 9, 2015 Posted July 9, 2015 You can vote for that feature request on the trello board
jordy 284 Posted July 9, 2015 Posted July 9, 2015 @@Vidman, so it's already a FR on the Kodi forums? I'm not a convert to Kodi yet, I tried it a couple of years ago - before MB2-Emby and didn't get much out of it. I have noticed the good reports from others on the Emby forums and thought I would give it another try.
itsrumsey 4 Posted July 12, 2015 Posted July 12, 2015 I've been using this addon primarily for all my xbmc installations recently and it has been working great. 2
psmc 8 Posted July 13, 2015 Posted July 13, 2015 Swapped from WMC/MBC last week pretty happy so far with the exception of themes that are pretty meh This is a great player .THe use of milkdrop as a visualizer over the bland media center ones is a bonus as does the ability to set the screen size for all 4:3 TV / Movies is a neat feature
Deihmos 170 Posted July 13, 2015 Posted July 13, 2015 Have you tried the Artic theme? That is the most visually appeasing theme I have ever used.
xnappo 1611 Posted July 13, 2015 Author Posted July 13, 2015 Swapped from WMC/MBC last week pretty happy so far with the exception of themes that are pretty meh This is a great player .THe use of milkdrop as a visualizer over the bland media center ones is a bonus as does the ability to set the screen size for all 4:3 TV / Movies is a neat feature Yes - curious what skins you have tried. Some of the better ones are not hosted via the Kodi repo..
bartolomesoriano 26 Posted July 13, 2015 Posted July 13, 2015 Good evening, Does the addon support Isengaard RC2 (MyVideos94 database)? Please let me know. Thanks. Regards, Bart
Angelblue05 4132 Posted July 14, 2015 Posted July 14, 2015 (edited) Good evening, Does the addon support Isengaard RC2 (MyVideos94 database)? Please let me know. Thanks. Regards, Bart No** Edited July 14, 2015 by Angelblue05
bartolomesoriano 26 Posted July 14, 2015 Posted July 14, 2015 No** Thanks for the quick reply Angelblue05! Any ETA of when this would be supported? Regards, Bart
Angelblue05 4132 Posted July 14, 2015 Posted July 14, 2015 (edited) Soon, I'm sure Depends if any changed occurred to the database structure. Edited July 14, 2015 by Angelblue05
