Angelblue05 4132 Posted March 22, 2019 Posted March 22, 2019 (edited) betaVersion 4.0.14aSmall follow up to 4.0.13a Fixes: Series pooling. Repair your libraries that contains series pooling to confirm the fix works correctly. Please report back with your Kodi log if otherwise. Edited March 22, 2019 by Angelblue05 4
Angelblue05 4132 Posted April 28, 2019 Posted April 28, 2019 (edited) betaVersion 4.0.15a Please repair your tv show libraries. Report back your issues as possible, I'm hoping to release a new stable soon, thank you! To repair, open emby for kodi > Manage libraries > Repair libraries and select the appropriate libraries. Changes: Update translations Playback improvements Patching improvements Fixes: Server and user name encoding Series pooling - repair your tv show libraries to apply the fix. Sorting episodes was wrongly applied to all episodes instead of only for special episodes - repair your tv show libraries. Special episodes within seasons will now respect the server setting repair your tv show libraries to apply this. Transcode via context menu Live tv not playing Edited April 29, 2019 by Angelblue05 2
Angelblue05 4132 Posted April 29, 2019 Posted April 29, 2019 betaVersion 4.0.16a Fixes: strm playback regression Small fixes 2
Angelblue05 4132 Posted May 6, 2019 Posted May 6, 2019 (edited) betaVersion 4.0.20a Hopefully the last beta before releasing a new stable version. Please report back your issues as soon as possible, thank you! Changes: Backport Playback speed improvements to Krypton. In addition, if you are using direct play with add-on playback, you will be able to see chapter images and subtitles downloader will be able to see your directory during playback Patching has been improved a little more Fixes: Theme Media should now sync all of your themes Transcode option Progress tracking Edited May 7, 2019 by Angelblue05 3
Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 (edited) betaVersion 4.0.22a If you are somehow on 4.0.21, please update to this version to avoid any errors. Hopefully the last beta before releasing a new stable version. Please report back your issues as soon as possible, thank you! Changes: Backport audio and subtitles prefs setup in database for playback in KryptonFixes: Theme Media with special characters in their path Playlist playback for Krypton Permanent users HTTP playback for strm Transcode profile main 10 with the option Hi10p (to be renamed) Minor fixes Edited May 12, 2019 by Angelblue05 4
Angelblue05 4132 Posted May 15, 2019 Posted May 15, 2019 (edited) betaVersion 4.0.23a Please report back your issues as soon as possible, stable version is very near, thank you! Changes: Re-labeled the notification for the fast sync settings and set the default value to 9999 Re-labeled Transcode Hi10p to Transcode 10-bit Fixes: Episode and movie stacking. Repair your libraries. If odd content still exists in the wrong shows, you can do a local database reset or manually delete those bad entries from Kodi. Episodes appearing under the wrong series. Repair your tv show libraries. Up next for native playback Edited May 15, 2019 by Angelblue05 3
Angelblue05 4132 Posted May 16, 2019 Posted May 16, 2019 betaVersion 4.0.24a Fixes: Playback for Leia Patch reload to fix corner case 4
Angelblue05 4132 Posted May 23, 2019 Posted May 23, 2019 (edited) betaVersion 4.0.25a Now we are really getting there. Thanks to all beta testers, life savers, pioneers for helping test this bigger than expected beta. If I could get a few users to try to update from 4.0.5 to the latest beta to confirm if you face any issues, I would greatly appreciate it. Of course, if you have issues, please post your Kodi log, don't even restart Kodi so I can see the update logging. Changes: New settings under Playback: Play remote urls using Emby. Enable this if your server returns urls to play, but can't be played directly in Kodi. Break Transcode 10 bit into two settings, H264 and H265/hevc New settings under Interface: Display hidden users in selection. Enable or disable to control displaying hidden users in the list of available users to add to session. New settings under Advanced: Reset patch update. Use this only if you have errors after a new patch has been applied. If you are unsure, post your Kodi log and I'll confirm. Fixes: Playback via info dialogs with certain skins Restore sync Scenario where server has no LAN address Hidden users missing from add users to session Edited May 23, 2019 by Angelblue05 4
Angelblue05 4132 Posted June 1, 2019 Posted June 1, 2019 (edited) betaVersion 4.0.26a Fixes: Database writing during playback Simple play for external players Permanent users (hidden users) Token clearing with wrong exceptions Device name, ensure there is one Improve patching Episodes added when new show is added as live update Edit: Noticed there is a bug in writing to database if your server restarts. You can revert back to 4.0.25 via sideloading while I write a fix. Edited June 4, 2019 by Angelblue05 5
Angelblue05 4132 Posted June 5, 2019 Posted June 5, 2019 (edited) betaVersion 4.0.27a re: 4.0.26a Fixes: Database writing bug (when playback ends) introduced 4.0.26 Edited June 5, 2019 by Angelblue05 5
Angelblue05 4132 Posted June 19, 2019 Posted June 19, 2019 (edited) betaVersion 4.0.28a Final beta, On Friday, I'd like to release the new stable. For this build, you may need to restart Kodi to see all the changes. Please report any issues before then. Changelog: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.0.28a Edited June 19, 2019 by Angelblue05 3
Angelblue05 4132 Posted June 29, 2019 Posted June 29, 2019 stable/betaVersion 4.1.0 Keep me posted if there's any issue moving from 4.0.5 (stable) to this new version. Changelog: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.0 3
Angelblue05 4132 Posted June 30, 2019 Posted June 30, 2019 stable/betaVersion 4.1.1 Keep me posted if there's any issue moving from 4.0.5 (stable) to this new version. Changelog: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.1 3
Angelblue05 4132 Posted July 3, 2019 Posted July 3, 2019 stable/betaVersion 4.1.2 Changelog: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.2 3
Angelblue05 4132 Posted July 8, 2019 Posted July 8, 2019 stable/betaVersion 4.1.3 Changelog: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.3 3
Angelblue05 4132 Posted July 19, 2019 Posted July 19, 2019 stable/betaVersion 4.1.4 Changelog: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.4 2
Angelblue05 4132 Posted July 23, 2019 Posted July 23, 2019 stable/betaVersion 4.1.5 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.5 2
Angelblue05 4132 Posted July 24, 2019 Posted July 24, 2019 (edited) stable/betaVersion 4.1.8 Reminder, if a build stops working correctly, you can always rollback using this method here: https://github.com/MediaBrowser/plugin.video.emby/wiki/tips#sideload Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.8 Edited July 27, 2019 by Angelblue05 3
Angelblue05 4132 Posted July 28, 2019 Posted July 28, 2019 stable/betaVersion 4.1.9 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.9 4
Angelblue05 4132 Posted July 29, 2019 Posted July 29, 2019 stable/betaVersion 4.1.10 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.10 3
Angelblue05 4132 Posted August 2, 2019 Posted August 2, 2019 (edited) stable/betaVersion 4.1.12 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.12 Edited August 2, 2019 by Angelblue05 3
Angelblue05 4132 Posted August 13, 2019 Posted August 13, 2019 stable/betaVersion 4.1.13 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.13 3
Angelblue05 4132 Posted August 18, 2019 Posted August 18, 2019 stable/betaVersion 4.1.14 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.14 3
Angelblue05 4132 Posted November 14, 2019 Posted November 14, 2019 stable/betaVersion 4.1.15 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.15 5
Angelblue05 4132 Posted November 21, 2019 Posted November 21, 2019 stable/betaVersion 4.1.16 Small follow up to 4.1.15 Changelog https://github.com/MediaBrowser/plugin.video.emby/releases/tag/4.1.16 4
