Angelblue05 4132 Posted March 12, 2018 Posted March 12, 2018 betaVersion 3.0.15aQuick follow up build to 3.0.14a. I would like to move this build to stable very soon. Keep reporting bugs! Fixes: Dialogs (broken by a change I made for Leia) 3
Angelblue05 4132 Posted March 23, 2018 Posted March 23, 2018 stableVersion 2.3.63 Changes: Small update for the Kodi companion server plugin (previously known as the Fast sync plugin) betaVersion 3.0.16a Changes: Small update for the Kodi companion server plugin (previously known as the Fast sync plugin)Fixes: Modify how items are downloaded to put less strain on your devices (to help prevent Kodi from crashing during the initial process) Strm playback Albums with no MusicBrainzId assigned (if you have multiple of the same albums, you'll need to reset your database to fix this issue) Other minor fixes 7
Angelblue05 4132 Posted March 27, 2018 Posted March 27, 2018 (edited) stableVersion 3.0.16 Moving forward, the minimum version supported is Kodi Krypton. Changes: Dialogs have been revamped Artwork urls (ensure original images are used by removing maxheight/maxwidth parameters) Source selection for playback Add Force Transcode to the context menu Playback has been fully revamped A few settings for playback have changed, you can view them in the add-on settings > video playback tab. Fixes: Modify how items are downloaded to put less strain on your devices (to help prevent Kodi from crashing during the initial process) Playback report Fix for empty shows. Refresh the tv show entry (Kodi context menu > Emby options > Refresh Item) and it will be dropped from the library as it should. Fix the context menu on the home screen Strm playback Albums with no MusicBrainzId assigned (if you have multiple of the same albums, you'll need to reset your database to fix this issue) Edited March 27, 2018 by Angelblue05 8
Angelblue05 4132 Posted March 30, 2018 Posted March 30, 2018 (edited) stable/betaVersion 3.0.18 The minimum version supported is Kodi Krypton. Quick follow-up build to 3.0.16. Fixes: Transcode Subtitles downloader compatibility Edited March 31, 2018 by Angelblue05 3
Angelblue05 4132 Posted March 31, 2018 Posted March 31, 2018 (edited) stable/betaVersion 3.0.19 The minimum version supported is Kodi Krypton. Quick follow-up build to 3.0.16. Fixes: Transcode to respect add-on settings for audio/subtitles selection Other minor fixes that slipped in the few previous versions.. Edited March 31, 2018 by Angelblue05 3
Angelblue05 4132 Posted April 4, 2018 Posted April 4, 2018 stable/betaVersion 3.0.20 Reminder, the minimum version supported is Kodi Krypton. Changes: Increase the Emby context menu dialog sizeFixes: Content being marked as watched when it shouldn't be 3
Angelblue05 4132 Posted April 15, 2018 Posted April 15, 2018 stable/betaVersion 3.0.21 Reminder, the minimum version supported is Kodi Krypton. Fixes: Double resume 4
Angelblue05 4132 Posted April 20, 2018 Posted April 20, 2018 stable/betaVersion 3.0.22 Reminder, the minimum version supported is Kodi Krypton. Changes: Support line return for plot (i.e.: This is the first line of the plot.<br>This is the second line.)Fixes: Play to playback order Music repair 5
Angelblue05 4132 Posted May 11, 2018 Posted May 11, 2018 (edited) stable/betaVersion 3.0.23 Changes: Device Id is now handled automatically. When copying your setup, you no longer have to generate a new device Id. It will generate a new device Id the next time you start Kodi. But this Id is now permanent.Fixes: Rework the websocket connection Resume not working Support Resume as default play action Edited May 11, 2018 by Angelblue05 4
Angelblue05 4132 Posted May 13, 2018 Posted May 13, 2018 (edited) stable/betaVersion 3.0.24 Changes: Remove Google AnalyticsFixes: Modified the DeviceId again to ensure uniqueness. Apologies. To remove duplicate device entries, delete them in your emby dashboard > devices. Shut down your running Kodi instances. Restart your server and you should be good to go. Edited May 13, 2018 by Angelblue05 3
Angelblue05 4132 Posted May 15, 2018 Posted May 15, 2018 stable/betaVersion 3.0.25 Fixes: Progress report for Native playback mode 3
Angelblue05 4132 Posted May 17, 2018 Posted May 17, 2018 stable/betaVersion 3.0.26 Changes: Revert recent device Id changes. Your devices will revert back to their old Ids. I am just not happy with how things worked out. To remove duplicates under active devices (which is only a cosmetic issue), I shut down Kodi after updating the add-on, then restarted my server. We should be back to normal and will never change the device id process again (unless Kodi gives us a permanent id that is unique to the installation, which will likely never happen) 2
Angelblue05 4132 Posted June 9, 2018 Posted June 9, 2018 (edited) stable/betaVersion 3.0.27a Changes: Remove unnecessary ssl settingsFixes: Library sync exited error. Season name External subtitles Edited June 9, 2018 by Angelblue05 4
Angelblue05 4132 Posted June 11, 2018 Posted June 11, 2018 (edited) stable/betaVersion 3.0.29a The changes should start slowing down now. I'm pretty set on leaving Krypton frozen now and focusing on Leia mostly. I have a few changes in mind. Please report back if you still experience issues with Emby for Kodi. Thanks guys. Changes: Re-added verify ssl setting. Default is now set to True. Disable it in the add-on settings if you have a self signed certificate. There is no other reason to touch that setting. Progress report is now fully dependent on your server. The add-on will only report updates when you pause/resume/seek or every 4min30 instead of every 10 seconds (less traffic). Update Leia database to 110. Fixes: Library sync exited error and server restart errors. Edited June 12, 2018 by Angelblue05 4
Angelblue05 4132 Posted June 15, 2018 Posted June 15, 2018 stable/betaVersion 3.0.30 Fixes: connection for self signed certificate external subtitles for content with special characters in them small bugs 3
Angelblue05 4132 Posted June 22, 2018 Posted June 22, 2018 (edited) stable/betaVersion 3.0.31 Changes: Suppress new content notification while video playback is ongoing. Update Music Leia database to 72. Do not update version if you haven't updated your Kodi Leia to Alpha 2. Fixes: Screensaver being set to None. Edited June 24, 2018 by Angelblue05 2
Angelblue05 4132 Posted June 26, 2018 Posted June 26, 2018 stable/betaVersion 3.0.32 Fixes: Transcode happening due to subtitles (should now direct play over HTTP as intended) 6
Angelblue05 4132 Posted July 9, 2018 Posted July 9, 2018 (edited) stable/betaVersion 3.0.33 Changes: Added the Kodi icon to display in your emby server (under active devices and devices tab) (Edit: This seems to not work for everyone. Will be corrected next build)Fixes: Suppress dialog "Not connected to your emby server" when add-on was triggered before being connected. Browsing content/photos with non-ascii characters Define "tvdb" as the rating type for tv shows. If you have an add-on that needs it defined, you'll need to repair your tv shows to force the fix into place. Trailers causing an error before playback Edited July 11, 2018 by Angelblue05 8
Angelblue05 4132 Posted July 26, 2018 Posted July 26, 2018 (edited) stable/betaVersion 3.0.34 Fixes: The kodi icon reported under active devices on your server. Edited July 26, 2018 by Angelblue05 3
Angelblue05 4132 Posted September 8, 2018 Posted September 8, 2018 (edited) betaVersion 3.1.08a This is a major beta release so you'll need to reset your database. I've been working on this update for the last few months during my free time. Test it out and report any issues or regressions, thank you! If you enjoy this update, please consider making a donation here http://ko-fi.com/A5354BI Note, this is alpha/beta, so expect bugs and resets and restarts. If you want to install this build without using the beta repo, you can grab all the zips using this method, everything is located in the public testing folder: You'll need the 3 dependencies installed first (v0.12), then installing emby for kodi https://github.com/MediaBrowser/plugin.video.emby/wiki/Emby-Repository I hope the wait was worth it. Changes: New hybrid mode: You can now select which library you want to sync to Kodi. Libraries that are not synced will still be accessible via dynamic plugin listing. Launch the addon and open the context menu on libraries for additional options. Faster sync times (in addition, if you are on the beta server 3.6x, you'll see a giant difference) The syncing process now creates a restore point. In the event the sync gives an error, you'll be able to restore your progress. Obviously if the problem persists, you should post your issue here. Support playlists and recordings via dynamic plugin listing -- maybe even live TV (since I don't have live TV, I can't confirm) Update/repair/remove per library basis (launch the add-on, open the context menu on the library of your choice). At the moment, to remove content that doesn't belong, you'll need to do a repair of that library. However, I'm looking to include this behavior in the update process as well. Just need some more time to get it done. Optional start up sync. If you have Kodi companion installed, your updates will be applied when Kodi is started. If you don't, then you can manually update libraries when you want, to grab the latest updates. Supports Leia Beta1. Moving forward, the add-on will be able to support every Kodi database. This will allow to support versions, even if they are not released yet. Multi server support: Additional servers will be accessible via dynamic plugin listing. Check the add server option when launching the add-on. You can now update your server information in the add-on settings. Support play next action from Emby Settings have been simplified Audio and subs will now be automatically set following your server user settings. The aspect of the addon that changes based on kodi version is dynamic. At Kodi startup, it will look if there's an update and apply it. You can manually check for updates for your Kodi version via addon settings > advanced > check for updates. Homevideos & photos type libraries are located under pictures add-ons. This is to prevent errors for picture content. Fixes: Artwork caching causing Kodi to crash during the initial sync Empty show detection Series pooling Boxset refresh Recently played for music Path validation for native playback mode Context menu should load faster Nodes -- They were one level too deep preventing skins from browsing beyond a certain level. Sleep/Wake errors Properly mask server addresses and tokens (except during the initial sync when everything is being setup). This can't be fixed if Kodi itself prints the information to your log (i.e. when playing content) Other minor fixes Translation will have to be redone, most strings have been changed. If you are interested in helping translate the project, contact me with the language you wish to translate. I'll provide you with the old strings so you can copy paste what still exists (their ids are the same) and translate the new strings. Edited September 9, 2018 by Angelblue05 12
Angelblue05 4132 Posted September 10, 2018 Posted September 10, 2018 (edited) betaVersion 3.1.11a Please refer to this post if you are still on 3.0.34. Changes: Update German translation Manually check for updates for your Kodi version. Under advanced settings > advanced > Check for updates Fixes: Patching process (includes android fix) Kodi companion disabled popup Seek detection (Check for updates for the fix or restart Kodi after updating) Local database reset to ask to reset music Crash during the library creation Crash on startup caused by special characters in library names and nodes Music - albums Other small fixes Edited September 10, 2018 by Angelblue05 7
Angelblue05 4132 Posted September 13, 2018 Posted September 13, 2018 (edited) betaVersion 3.1.13a Please refer to this post if you are still on 3.0.34. Once you have updated to this build, please run a Check for updates under the addon settings > advanced or restart Kodi this one time to ensure you have the latest Kodi-emby database version. It is possible this step is not necessary. Fixes: Profile switching asking to reauthenticate Remove items event (if you are on server 3.6x, do a reset of your local database) Hopefully the only time that you'll need to do that. Database changes are normally smaller, but this one was necessary to be compatible with server events in 3.6x Refresh boxsets task Music albums merging with no musicbrainzid, repair your music library to apply the fix. Display boxsets for dynamic listings Kodi hanging on exit sometimes Duplicates regarding synced libraries Keymap delete action Edited September 13, 2018 by Angelblue05 5
Angelblue05 4132 Posted September 14, 2018 Posted September 14, 2018 (edited) betaVersion 3.1.14a Please refer to this post if you are still on 3.0.34. Changes: Add option to display sensitive information in logs (for troubleshooting purposes)Fixes: Adding new tv shows Favorites Boxsets for plugin listing (it should display correctly now, and you'll be able to see the movies inside) Music rescan tags prompt (you need to repair one of your music library if you have that issue when entering the music library in Kodi). Edited September 15, 2018 by Angelblue05 6
Angelblue05 4132 Posted September 15, 2018 Posted September 15, 2018 (edited) betaVersion 3.1.17a Please refer to this post if you are still on 3.0.34. I will look to add the backup option again for the next build, including more submenus for dynamic listings. A reminder, please provide your Kodi log when reporting issues, so it's easier for me to troubleshoot. Fixes: Season fanart (update or repair your tv libraries) Missing tv shows and content patching system Update libraries Series pooling (repair your tv libraries to correctly apply series pooling) Path verification for native playback mode Subtitles encoding while transcoding Tip, you can sync repair, update, remove individual libraries via Launching emby for kodi. Then opening the context menu on the library you want. Edited September 16, 2018 by Angelblue05 7
Angelblue05 4132 Posted October 3, 2018 Posted October 3, 2018 betaVersion 3.1.25aPlease refer to this post if you are still on 3.0.34. More to come, keep reporting issues!Changes: Add live TV support (channels for now) -- Note this is just a dynamic entry, it's not a pvr replacement. ** Now supports server pre 3.6 ** Re-add screensaver being disabled for syncs settings Re-add download threads settings Add useful menu options for dynamic entries type home videos, movies (more to be added) Re-add backup option Add notification for large updates at startup (you can adjust the notification trigger in the addon settings > sync options) *Default is 100* When syncing your movie libraries, it will automatically trigger a boxset refresh for you. Fixes: Missing newly added music artists Start from beginning being ignored on Kodi Leia Server detection for dynamic entries Slowness for add-on playback and other dynamic actions Dynamic listing broken due to previous commit. Should be back to normal now. Kodi hanging on exit Series pooling Episodes being processed twice when processing libraries Transcode flac audio Artwork with adjustments based on add-on settings (might be longer to update libraries the first time because of it. It will cause artwork url to change) Convert credentials from 3.0.34 automatically Other minor fixes 7
